loading
Step 3: Shroud bolts
The alternator is held in-place by 4 bolts in the shroud, and a strap that holds it down to the stand that it's on. These are 10mm bolts, and only 1 is readily accessible by a mortal. Go ahead an take it out. There is one below that is right behind the intake manifold. If you're careful you can get that one as well. The other two screws are blocked by other motor parts, so we're going to have to do some more tearing down.
Pretty sure the battery going flat on concrete is an urban myth that originated about 40 years ago when auto batteries had hard rubber cases. Still not too sure about how it was supposed to discharge, but storing a battery on a nice cool concrete floor is probably the best thing for it. I have stored batteries this way for many years (charging them every couple of months) and they have always worked fine. One of them was under my bench for about 3 years after being salvaged from a wreck, and is now in it's 5th year under the hood of my car. Not definitive proof, but a pretty good argument.
Not a myth, It's the cold from the concrete that does it, lead acid batteries and cold are not good bed fellows.
<p>What BS, the concrete floor isn't any colder than say, Minnesota. It was the old rubber cased batteries and the salts in the concrete that were the basis of the story. New plastic cased batteries have no such issuses. </p>
I'm unsure about your particular VW, but many of the air cooled engines used a generator, not an alternator. From time to time, generators need to be polarized with the voltage regulator or they will not charge. Generators get replaced a lot when all they need is polarizing. Not to say yours didn't need replaced, just my 2 cents. Awesome job though.
Thanks! It was an alternator, and I did some subsequent testing once I had it out.<br><br>Thanks for the tip, and the feedback!
Good job. But, you didn't explain how you determined the failure in the alternator. The test you described on the first page does not accurately show anything beyond the condition of the bearings of the rotor. If you have no voltage across the rotor windings, the alternator will not produce anything. Alternators are very robust, especially those from Wolfsburg. They have no moving parts except the rotor which cannot be overloaded, and thus rarely fails. If the stator diodes are OK, then the commonest reason for a problem is the <strong>voltage regulator</strong>. The Voltage Regulator monitors the condition of the battery and when the voltage decreases it turns on the rotor winding by connecting the battery to the alternator.<br> <br> The greater the need at the battery, the more voltage is across the rotor winding. If the voltage regulator fails, the battery goes dead. If the battery was not charged before installation, it will not charge either. (Although, the car will run fine on the drive home!) If the alternator has a built-in regulator then you have fixed the problem, whatever it is. &nbsp;If the battery was charged.<br> <br> Articles like this, however, are very valid and important &nbsp;instructables. &nbsp;They explain how-to repairs for automobiles. &nbsp;Often a handman (woman) hesitates to fix his car because (s)he has never done this before.
As I read the instructable this is exactly what I was thinking.<br><br>Not only is it a faulty alternator a common misdiagnosis, but in fact a failed voltage regulator is a very common problem. That said, it does depend on the particular alternator you are replacing as it is common to find both alternators with a built-in voltage regulator as well as with an external voltage regulator. if the voltage regulator is built in, then the solution is in fact replacing the entire unit.
Thanks for the feedback. I basically did not get very detailed in my diagnosis due to my own ignorance :) I saw that the old alternator was putting out 0V at the B+ terminal, and that's about as far as I can go. Perhaps I need to educate myself in this area. <br><br>Thanks again!
I cannot say for certain about your alternator, but I had an alternator fail on a Chevy 350 cu. in. V-8. My battery was much older than yours with side post connectors. Someone had over-torqued one of the side posts and it was partially broken off inside. According to the Chilton manual I had, a bad internal battery connection can cause an alternator to fail. That failure causes the rotor to short out. The test in that case was to use an ohmmeter on the slip rings to read the resistance in the rotor windings. The resistance was to be 1.5 ohms, which is tiny. Anything less meant the windings had shorted out. Mine read 0 ohms. Anyway, a new battery and a new alternator fixed me up. It sounds like your battery is still OK.<br><br>Thank you for your Instructable. I do not have a VW, but I may someday have a friend who will need help with his.
Thanks for your feedback Phil!
Good 'ible, nice to see some aircooled stuff on here.
Just fyi: I had a volkswagen in which I replaced the alternator and after doing so the fan started rattling in a rhythmic fashion (you'll know it if you hear it). After months of frustration an old man at a volkswagen shop informed me that there is supposed to be a shim the thickness of about three business cards between the stand and the alternator. So cut a piece out of the back of a notepad and put it in there. Problem solved. Now you know, just in case.
great tip! thanks :)
Glad to make suggestions. I only do so because I have such traumatic memories of this experience. It was awful! I had replaced the squirrel cage, messed with shims, tightened every nut. I even drilled holes and put screws in the squirrel cage in order to balance it. The second I put that shim in there, problem solved! But boy...the mountain I had to climb before I found that old guru. Phew! I loved that car, but it was a quirky little bugger.
Very clear, concise instructable! I don't own a VW but I feel I can take this task on thanks to this!! Great job!<br><br>A neat way to test an alternator: With the engine off, check the voltage across the battery. If it is above 12V, you're in good starting shape. If it is below that, this test will not work and it is probably your battery.<br><br>Start the engine and check the voltage across the battery again. It should be above 13V. Give it some gas and increase the RPM's; you should see the voltage fluctuate between 13-15V. If there is no increase in voltage from the first 12V measurement, there is no voltage coming from you alternator.<br><br>To test amps, you need to run the multimeter inline. I would suggest taking it to Autozone since they test an alternator for free!<br><br>Great job!
Loved your ible. it brought me back to when I had a 77' beetle that I got in 86'. rebuilt the engine twice. And made me remember why I ALWAYS carried ALL of my tools needed to work on the car. One day on the way home from work my belt came off. I pulled into parking lot put my old belt that I had saved for just such an occasion and back an the road in less then 10 min. <br>Thanks
Good times, right? :) Thanks for your feedback!
It would be neat to see pics of that :)
Ah Dud, thanks this one brought back some fond Memories of my first ride back in 1978 mine was 69 VW Bug, however I replaced the Engine with a 4/11 Porch Engine, it took a little Modification of the Engine Comp and had to Mod the Trans-axles, I kept snapping the off the the 6 bolts at the CV joint, also had to use the friction and pressure plate from the 4/11 want more info feel free to contact me.
About This Instructable
34,215views
28favorites
License:
More by hirod3:Paracord Shoelaces with aglets Alternator Replacement - Volkswagen Upright (Type I) Motor Paint your own car for under $200 (or how I learned to love Rustoleum)
Add instructable to:
