Step 9Almost there
If you're like me, you like to use alot of extra wire, so you will want to keep that in the can, I hot glued mine to the inside of the top. Also, if you have an extra switch, like my bass boost, you will want to mount that in a pile of glue to keep it from making contact with the metal of the case (this will cause a disturbance in the force (audio)). You may need to cut away some metal to make the case open and close smoothly. Also, there will be a volume adjuster on the chip, I didn't bother to make this adjustable from the outside of the can, but you can if you want to, you should tweek it until you get the sound you want by adjusting the volume and tone on your guitar and the volume on the chip, some combinations
give you a distortion-like effect that you may like.
comment
Add Comment
Add Comment
