loading
Step 2: Like a Hot Knife Through Bubble Wrap
thats my BernzOmatic butane torch, i got it for about $20 from a local Orchard Supply Hardware. pretty cool piece of kit that can be a torch, couple different soldering iron tips, and a hot knife; add in the sponge and solder inside that case and it's really useful for soldering where electrical outlets aren't.
you light the iron by pushing a spring loaded collar forward, which exposes that left hole you can see in the second pic. turn the power to 4 and hold a flame to the hole. after a few seconds the catalyst inside the tube (between the two holes you see) gets hot and you can release the collar and the iron is on. be careful because the exhaust port is that right hole, and as you can see it will vent directly down onto whatever youre hot knifing. if i didn't hold the knife at a steep angle the exhaust would have melted my bubble wrap
be careful you dont make the same mistake i did and trace the outer perimeter of the tin and cut to that, i should have made everything about one row of bubbles smaller so it would fit inside the case.
<p>Very cool case, I've got one question, can you make holes in the case for the USB and power so it sticks out?</p>
i dont know for sure that thats not sarcasm, but i couldn't find any Arduino Altoids carrying cases (except ones with holes for the USB and charging cable) so thanks for the compliment =]<br><br>i dont know why but the comments on the pic of my hot knife got shifted up and slightly to the right, but the big square should be on the black ring my thumb is touching. its pretty clear what hole is what for the other pic comments
This is new an exciting, there are no other altoids tin cases for the Arduino.
About This Instructable
10,468views
30favorites
License:
More by RowdyPants:Altoids Arduino Case
Add instructable to:
