Altoids Gas Grill
Introduction: Altoids Gas Grill
This is a little propane grill I made out of a lighter an Altoids can and some other stuff it is very fun to use and cooks things like mini hot dogs really well
Step 1: Main Part
For the main grill part I cut out a hole in the top then drilled a small hole on one side of an Altoids can
Step 2: Grill Spokes
The grill spokes I made from an old coat hanger then used aluminum tape to tape them to the inside part of the hole in the Altoids can
Step 3: Propane
The propane is from a lighter I hacked you can learn how to hack one in my profile page thing
Step 4: Burner
The burner is an Altoids mini can with a bunch of holes drilled in the bottom and the top took off and a hole drilled in the side of it then I carefully hot glued it to the bottom of the big Altoids can
Step 5: Propane-burner
To get the propane into the burner I used a tube from one of those big lighters then put a small Lego tube around the nozzle. Then I stuck the not nozzle end onto the nozzle of the hacked lighter then stuck the nozzle end of the tube through the hole in the big Altoids can then stuck it into the small one and to get the propane flowing just press the small button on the lighter
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    you stole this from hm innovations
    Heh heh, uuhhh hate to tell you this but it's butane not propane. Propane must be kept under extreme pressure. But really cool build, and I am looking forward to building this
    This is really cool. I will have to make one
