Altoids Portable Phone Charger Easiest
Published
Introduction: Altoids Portable Phone Charger Easiest
About: i love to build stuff, self teaching myself more and more.
I apologize in advanced for working off a completed project, the painting wasn't good, I wasn't using a good spray paint for it.
Step 1: Items Required
1. Altoids Tin
2. Drill with bit
3. Car Phone Charger
4. 9 Volt Battery Clip
5. 9 Volt battery
6. Hot Glue Gun
7. Spray Paint (optional)
Step 2: Drill the Hole
Drill the Hole for the USB connector...
Step 3: Strip the Car Charger
Strip the car charger, revealing the circuit.
Step 4: Glue the Board Into the Tin
Glue the board into the tin, it should fit snug into your hole for the USB.
Step 5: Solider or Hot Glue
Solder or hot glue the positive lead to the spring, and negative to the outer rings.
Step 6: Hook It Up and Your Completed
Your done, now charge your phone and check out my other Altoids instructables!!!
Warning: If the 9 volt battery goes too low, a iPhone will give you an indicator saying that charging is not supported with this device
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    6 Comments
    This is great! Do you have any issues with heat as it's charging? -I'd like to do a leather or leather-covered version (gettin' fancy!) but I would worry about heat build up...
    The car adapters are more efficient. Heat wont be a concern. I'd be more concerned with the 9v battery dying, they have low capacity ):
    I don't have hot glue I ran out and I'm not well at soldering what can I paste it with ? Tape?
    how do u do that like get everthing off the bord
    No, I have no issues with heating, if used for a prolonged time the battery will get warm, not hot. I would love to see that completed project, send me the picture! Thanks for the response!
