Step 2Screwing in the Can
After getting this marked, drill into the side of the can on both sides. Make sure it is centered a bit, because the long piece on antenna is going through here when you aren't using the ROMP. to see how big of a hole you need for this, compare the drill bit to the widest end of the antenna(the section we'll be using) and make sure the drill bit is a little bigger than it.
Then, you'll now have 2 holes in which you can place your antenna through.
Add Comment
