If you decide to make one of your own please post a picture in the comments! I'd love to see what you guys are coming up with. The propane version is coming soon! :D
Step 1: Materials
1 Altoids sours tin
4x 1.5" sheet metal screws with wide heads (or 4x washers to match)
8x nuts to thread on screws
70mm metal computer fan guard (similar style to the one shown)
92mm metal computer fan guard (similar style to the one shown)
* I scavenged my fan guards from an old computer power supply. They just happened to be the correct size
** I think these are the same fan guards that I'm using: 70mm and 92mm
Tools
Dremel tool with cutting wheel
Drill with bit slightly bigger than screws
Tin snips
Pliers/Needle nose pliers
Screwdriver
Safety goggles and gloves
Step 2: Remove bottom of tin
After you have the holes use a Dremel tool and cutting wheel to remove the center of the tin, leaving 2-3mm of metal around the holes you just drilled. Remove enough metal so that the "tabs" with the 4 holes can easily bend outwards without altering the shape of the tin or breaking off. When the metal is removed bend these tabs out slightly (~15 degrees)
Be careful of the sharp edges when you are cutting and bending, and always wear appropriate safety gear!
Step 3: Upper grill notches
When you are done test fit the large grill and make sure it snaps in and out nicely.
Step 4: Legs and lower grill (briquette rack)
First you need to connect the legs. Put all 4 screws through the holes and secure them with a nut, but only thread one completely through. Do not tighten this nut either just yet, it should be loose.
Next put the grill on the leg and loosely thread another nut on it about halfway down.
For the remaining legs you'll need to screw the nuts in about halfway, align them with the holes in the grill, and then push them all the way through securing them with a second nut on the end. You will probably need to bend your tabs a little more at this point to get the alignment just right.
At the end of this step tighten the top nut on all of the screws to secure the legs to the tin.
Step 5: Alignment
Step 6: Lid
Step 7: All done!
To use simply remove the top rack, set a briquette on the lower rack, reinstall the top rack and light the briquette from the bottom. In no time it should be fired up and ready to go!
Don't forget to post pictures of your grill in the comments! =)
Visit Our Store »
Go Pro Today »
It's a bit bigger. Holds 4 charcoal briquettes.
I also made a lid and used a drawer handle on top.
I grilled up some salmon today. It was ok. I think it needs to be hotter to get that delicious seared flesh thing going.
Thanks.
you can use instead of the Altoids tin. Made one today and it turned out great!
I have one of those tins, and I made one, but with shorter feet.
I just need to know...
I have a website that sells stuff just like this and much more. please tell lots of your freinds obout my website @ www.krazykontraptionz.com
Joe
http://www.frozencpu.com/products/9406/ffg-21/70mm_Fan_Grill.html?tl=g47c221s996
http://www.frozencpu.com/products/2615/ffg-05/92mm_Fan_Grill.html?tl=g47c221s542
