3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids Survival Kit
Take an empty Altoid tin and jam-pack it full of survival tools!!!! This kit is designed to save your life in an unfortunate outdoor situation. Hopefully you won't have to use it but it is always a nice feeling having it in your pocket while camping, hiking, or backpacking. Also please be sure to check out the new video!
Step 1Supplies
For this instructable you'll need:
1 Altoids Tin (empty)-this will be used to store all the items in the kit
1 Large Trash Bag-this have many uses including a poncho, shelter, or whatever else you can think of
5 Rubber Bands-3 will be used to wrap around the trash bag, 1 for the fishing line, and 1 for the cord
4 Fish Hooks and 20 Ft. of fishing line- these can be used to make a fishing rod, with which you can catch fish to eat
10 Ft. of Cord- this can be used to help make a shelter, keep food out of reach of bears, or whatever else you might need it for
1 BSA Hot Spark-this is flint and steel combination that serves as a fire starter if your matches won't lite
5 Matches-used to start fires
1 Match Striker Piece-used to strike matches on
1 Birthday Candle-this can be used to coat the cotton balls in wax to make them waterproof or as a temporary light source
2 Cotton Balls-great for starting fires especially in coated with wax or petroleum jelly
Lets get started!
237 comments
1-40 of 237next »
Jul 28, 2011. 2:25 PMbikibikes says:
try putting in duck tape that is wraped around itself
Jul 7, 2011. 3:42 PMhossweightlifter says:
the only thing is ur probs gunna need a knife
Jul 7, 2011. 3:41 PMhossweightlifter says:
aright guys i am just annoyed how many people make these things and so many if them will never use them because they are nerds who never leave their computers but this one wasnt that bad it actually had some good ideas
Aug 4, 2010. 8:24 AMKnot71 says:
Can you buy the Altoids tins in the UK?
Apr 17, 2011. 10:03 AMchicken12175 says:
yes you can, you just have to look around:
http://www.instructables.com/answers/Buying-Altoids-in-the-UK/
Feb 24, 2011. 3:58 PMtaluntain says:
some cough drops come in the same type of tin
Sep 5, 2010. 11:17 AMDu7raz says:
actually any tin that size would work :D
Mar 1, 2011. 11:49 AM60to1 says:
Looks good! 2 quick things:
I use a "trick" birthday candle in mine, as they relight if they are blown out.
Also, I replaced the striker for my hot spark with a P38 can opener.
Feb 18, 2011. 5:24 PMairsoft+offbeat+everything=logan!! says:
why do you need matches if you have flint
Feb 24, 2011. 4:00 PMtaluntain says:
because you are suppose to have more than one way to start a fire just in case one way doesn't work it just a precaution so you won't be S.O.L
Nov 30, 2009. 4:07 PMpyro man says:
great survival kit! im a boy scout and i can protest that the hot sparks are great. they just take a little bit of practice to get just right.
Jun 15, 2010. 9:00 AMNicholas G. says:
I just started a BSA Group. Do you want to join? the url is: http://www.instructables.com/groups/BSA
Nov 27, 2010. 9:03 PMthe gizmoman says:
Boyscouts is such an alsome program it teaches unique and very useful skills and is really fun with the camping and backpacking trips I'm an eagle scout by the way
Nov 4, 2010. 6:13 PMbears0 says:
my dad is retired air force so i can go on the base and get all kinds of survival stuff
Jul 14, 2010. 5:54 PMkiller dragon says:
It would sort of be better if you put the cord inside of the tin because if you need the matches or something inside the tin you have to take the rubber band and cord off, take out what you want and than put it all back on.
May 15, 2010. 6:07 AMjoey99 says:
it seames very inconveavyant haveing to unwrap and wrap the cord to get to your stuff
Dec 23, 2007. 3:22 PMcloudchaos says:
one other thing if you can fit it all in a good size chunk of steel wool and a 9v battery (just make sure you insulate the battery ends to prevent fire and battery drain) very good for starting fires if you can't use a mag block or BSA HotSpark
Jan 21, 2008. 8:18 PMSnuffyDaPenguin says:
steel wool lights much easier than cotton balls or even a big clump of lint. I carry some around in my firekit when I go camping or where ever. It lights with even one spark from a flint, and then catches a hot flame. No need for a 9 volt, which runs the risk of explosion or catching the wool while in the tin.
Sep 17, 2009. 7:25 PMchadcad says:
The steel wool idea is a very solid one. One thing that I do is to take a small piece of it, flatten it out and wrap a piece of wax paper around it. I end up with a 3/4" x 3/4" square that's about a 1/16" thick. It fits pretty easily in just about any cell phone battery compartment. You ever need a fire just touch the steel wool to the terminals of your cell phone battery. The wax paper works pretty well as kindling too.
Apr 15, 2010. 11:13 AMstar folder says:
The battery from a Polaroid film pack will work with a small piece of steel wool, too.  It's flat and easy to keep packed.
May 27, 2008. 6:58 PMlocofocos says:
I though steel wool only burned in pure oxygen...
Jul 15, 2009. 10:39 AMthepelton says:
No, I discovered that when I tried to clean posts on my car battery with steel wool.
Nov 14, 2008. 2:38 PMn0ukf says:
FYI, it's not the steel that's burning, but the carbon in the steel. It's the same with flint and steel striking, it's not the flint that sparks, you're shaving steel off and the heat of friction is igniting the carbon in the steel.
Jul 15, 2009. 10:46 AMthepelton says:
Actually, the carbon starts first, but the iron will burn once the carbon has started. Solid pieces of iron don't burn because they are too massive: It would be like dropping a match on a log over a foot in diameter.
Jan 1, 2009. 5:33 AMShadowfury says:
Well, that, and the cerium and lanthanum mixture that they put in it.
@locofocos, N=awesome.
May 28, 2008. 7:17 AMcloudchaos says:
I will make a video tonight on how to start a fire with steel wool and post it.
May 28, 2008. 1:29 PMcloudchaos says:
Jan 23, 2009. 5:44 PMtemp says:
i can't really tell but it looks as if you left the steel wool packed pretty close together. It would work much better if you fluff it up.
Jul 15, 2009. 10:41 AMthepelton says:
It ignited for me accidentally in that car battery incident even though it wasn't fluffed up.
Jul 18, 2009. 9:30 AMtemp says:
It will still work but if you fluff it up it's easier and you can use less.
Jul 18, 2009. 12:16 PMthepelton says:
I suppose you're right, but the original idea when I applied it to the car battery was to clean the posts to improve the electrical flow. If I intentionally do it to start a fire, yes, I will fluff it up.
Jul 18, 2009. 2:00 PMtemp says:
Oh. That must of been funny to see.
Jul 20, 2009. 10:25 AMthepelton says:
I suppose, but not to experience.
Oct 27, 2008. 7:09 PMAznPanda says:
Heh i member this trick for like i think it is Lifetv or something it was on YouTube is where i learned it
Jun 30, 2009. 12:23 PMJ@50n says:
me too!
Jul 22, 2008. 1:19 PMjamesccostello says:
I don't mean to dis everyone's creative means of starting a fire, but I don't understand the needs for such creative fire-starting. I've found the most effective, waterproof, reliable, and easy method of starting a fire is to use a cheap pocket-sized lighter. It takes up about the room of several matches. Is a lighter for some reason not an acceptable means of starting a fire? Maybe I'm missing something.
Jul 13, 2011. 12:28 AMAero9 says:
It is true a lighter is a handy and effective tool for fire building, however I myself have always found satisfaction in a good old unorthodox fashion in which to ignite tinder. I do carry a Zippo with me, but flint and steel, steel wool, two rocks, two stick, magnifying glasses and other such means of fire starting always gave me a strong sense of accomplishment. Also when train hopping I don't really find myself carrying large amounts of cash that can be waisted on lighters when I can make a fire from the tools in my pack.
Jan 1, 2009. 5:41 AMShadowfury says:
Well, the difference between lighters and matches and flints, fire pistons, strikers, etc, is that lighters and matches last only so long. Things like fire pistons and flints can be used indefinitely, or until you break them. Strikers wear extremely slowly, and are very effective fire starters. So it's really up to you, if you're in a survival situation for say, a week or two, then yes, a butane lighter would be great. But, you never know, you could be out there for months, in which case, a lighter would be the worst fire-starting instrument you could possibly have. (next to matches, of course)
Jan 14, 2009. 7:42 PMjillg says:
but, as someone said earlier, you could ude the sriking part of the lighter to light fires with the igniter for a while longer.
Jan 15, 2009. 3:14 PMShadowfury says:
Yes, but the striker in the lighter is tiny. It is about 1/4cm long, and 1/8cm wide. It will last for a while, but ultimately wear until it is completely gone. It is also very difficult to start a fire using this method. You can use some tissue paper and cotton, but it is not always successful. I estimate a 50% success rate for that method, from experience, of course. In short, yes, you can use a fuel-less lighter to start a fire, however, you're just going to have to be patient to get a flame.
1-40 of 237next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:sardines454
