It holds 25, count 'em, 25 items...and counting
Pocket size, neat and organized, ready to go, easy open/close.
Remove these ads by
Signing UpStep 1The "ingredients"
--Items I have
empty Altoids tin
matches
matchbox
gum
small flashlight
fishing line
duct tape
b-day candle
small candle
small compass
foil
ziploc
safety pins
wire
medical tape
gauze
bandaids
alcohol wipes
plastic container
tire puncture repair patch
needle
thread
signal mirror
rubber band
dental floss
razor blade
safety pins
--Other useful items that I don't have yet
emergency whistle
flint & steel striker
--Useful items that won't fit in the tin
Swiss Army Knife(or other multi tool-mine is Greatland Brand)
Someone commented on adding a mirror, not necessary, As I pointed out in my published piece, simply polish the inside of the lid and make a small hole in the center. Then the lid becomes a functional signal mirror.
Why don't you glue your mirror onto the outside back of the tin, that way it's not taking up any space inside?
Place your tin inside of the Ziplock (fold the bag around the tin, squeezing out the air before sealing) and then securing with the rubber band.
You should then have enough room for a small wrapped tampon - Lilette's have ones without the applicator. This can be used for an emergency water filter to remove a lot of sediment and larvae or it can be used for tinder (just pull away small amount of the cotton) and even the thread can be pulled apart and used.
I guess you could wrap your duct tape around the outside of the tampon too.
Just my pennyworth.
Super Glue to patch up things and make arrows, etc.
Flexible magnifying card, plastic, flexible, and really small, can start a fire.
Pencil, so you don't go mad, you can draw things and make observations.
Sandpaper, to sharpen things.
Little screwdriver, so you can take apart any other things you have.
Batteries, to power makeshift radios and LEDs
LED: use with batteries to make an effective flashlight.
Bandaids, to heal u
Nails, different sizes, to build shelters and make arrowheads.
Safety pins, to use as fishing hooks (?)
Towelettes, they have alcohol, so they burn well, and can also kill bacteria. Plus if you breathe in the fumes you get high :D
That is all.
