Step 13Done! Testing and Troubleshooting.
- attach the output jack to a known good powered speaker
- attach an working mp3 player to each input in turn.
Problems?
If something doesn't seem to be working check these things:
1) Do you get sound with mp3 player, cable(s) and powered speaker without the mixer?
2) Double check wiring. Is everything wired correctly, per instructions?
3) Any cold solder joints? (solder joints that look good but don't really connect) Try resoldering any suspect connections.
4) Any shorts? Shorts are accidental connections caused by wires touching each other. Look carefully and pull apart wires that look like they might be touching.
For a headphone splitter you would be better off not using the resistors. The resistors are only required for mixing multiple sources together.
Rich
Ps: sorry for any grammer and errors
If you want to experiment (at your own risk) and as long as you don't take the resistor values below the resistance of a typical set of headphones (again, 16-32 ohms), then you shouldn't cause any damage to either players or headphones and you can gauge the sound quality/volume trade-offs for yourself.
http://www.roccat.org/Products/Gaming-Sound/ROCCAT-Kave-5-1/ is the headset, im guessing 10KOhm as it says on the tech specs but im not sure. im looking to fuse together the 5.1 3.5mm outputs on both my PC and a decoder box from my xbox, and also the headset signal from the xbox controller through the fronts.
Thanks
i have a tin that hopfully ill be able to put 4 different circuits in, 1 for each channel. yeah ill have 9 inputs in total as ill have an extra input on the front speakers from the output of my xbox controller, on a adaptor i have for it.
Thanks for uploading the instructions btw :)
2) There is one solder point near the output jack where my solder point on the output jack and my solder point where I soldered the 2 resisters together accidently got soldered together (So basically, what should be two solder points are now one). I hope that was a thorough explanation. Also, I am confident that it is the output jack which is the problem, because I tried all of the inputs and they are all working the same. Thanks for any information you may have.
I was just trying to keep it simple & cheap, and honestly I've been using one of these in a car for several years and have never had a short. With the lighter resistors
But I don't blame you for wanting to make it neater/more rugged -- go for it!
I thought it would be cool to pour melted paraffin in to ruggedize it, stick a wick in there and have an emergency candle too.
1) makes it a little easier to connect all the output sides of the resistors together in 1 "solid" wire.
2) I consciously decided not to include a schematic in this project, since it is so easy to build and it might intimidate some folks. So I thought positioning the resistors that way would keep some builders from getting confused about which side the next resistor should connect to.
So do whatever you want, as long as the circuit is equivalent.
Being an EE myself, I appreciate what you're saying: a schematic is the most concise way to describe a circuit and in your place as a consumer of someone else's how-to (which I frequently am) I would also prefer a schematic to a blow-by-blow account.
As the writer in this case, I choose an approach I *thought* would be accessible to a wider range of instructables.com readers. At the same time, I did put a schematic diagram in the FAQ section for the cognoscenti -- did you see that? Maybe it should have been under a more obvious heading like "Schematic", huh?
Glad you kept at it,
Rich
No, I completely get the approach, and I can appreciate it, I would probably have done the same thing too.
Do your jacks have switched contacts on the tip and ring by any chance? There would be 5 terminals on the jack instead of 3. That could cause some weird problems if you picked the wrong terminals...
The best I can recommend is to double check your wiring against this schematic, there's not really a lot that can go wrong if the wiring is correct.
So I hope that means you got it working?
Rich
thanks for this great instructable!
You have to understand that the bare copper wire and the case are already connected together electrically on purpose. So it doesn't make a bit of difference whether the wire touches the case randomly or not.
The ground tabs of all the jacks are tied together through the case and you could almost get away without the copper wire. However, a good solid ground is critical for quiet audio circuits and the connection between the jack and the case is not reliable, so the copper wire is there to provide a rock solid return path.
OTOH, if any of the resistor leads touches the case, you will definitely have a problem.
Let me know if this is not clear,
Rich
if thats true, then basically this is like a passive "mixer" yes?
Yes, it's not only like a passive mixer, it is a passive mixer.
And if you read through the text, you'll see that it's not meant to drive low-impedance devices like speakers or headphones, only high-impedance inputs. Amplification is done after the mixer.
It doesn't make any difference at all if the other inputs are active or quiet, you still need the resistors.
Here's why: When you tie several outputs together directly, each one "sees" the others as a low-impedance load, and what's worse, each additional device you add lowers the total load impedance seen by each device (parallel resistances or impedances divide).
Why is this bad? The lower the load impedance, the more power the device's output must try to provide. That's where distortion and/or destruction come in.
Here's an example to understand the basic relationship:
- put a 1k ohm resistor across a 9V battery:
high impedance->low current->low power->no problem
- put a piece of bare wire across the same battery:
very low impedance->high current->high power->bad things/smoke
If you only want to use one input at a time and have some objection to using resistors, you might be better off making a selector switch using a 2-pole multi-position rotary switch like this:
http://www.radioshack.com/product/index.jsp?productId=2062536&CAWELAID=107598141
thanks for the fun weekend project.
Two thumbs up.
