3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids Tin 1/8" Stereo Mixer
Step 7Attach Ground Wire to Ground Tabs
1) Locate the ground tab on your audio jacks. This is the one that connects to the metal barrel on the jack, and is usually closest to the case when the jack is installed.
2) Attach the bare 22 gauge solid wire to the ground tab of the single output jack first and solder.
3) After soldering the first jack, replace it into its hole and determine where to make bend/attach the wire to the ground tab on the next jack.
4) Solder the next jack, and so on, until all the ground tabs are attached and soldered.
Hint: I like to wrap the wire around the tab and crimp with the needle-nose pliers before soldering.
Note: Do not worry about the bare copper ground wire touching the case, they are meant to be connected together
3 comments
Jul 13, 2010. 6:20 PMghg2 says:
noob question: did you cut any tab of the input jacks ? because it has 5 in step 1 and only 3 now ...
May 12, 2010. 8:30 AMtackdetack says:
 Just out of curiosity (might be a noob question) What if I were not using an altoids tin for my casing. Would there be a problem using a plastic casing in regards to the ground wire?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:richfiddler11
