Step 7Cooking the Bread
Place the Altoids tin on top of the rack and let the lid of the tin rest on itself so that if pressure builds, it wont explode. (This has never happened to me, but hypothetically it could!)
Depending on how much dough you put in the tin, the process of cooking your bread should take 12-15 minutes. The cooking time also takes into account how close or far away your flame is from the bottom of the tin. I like mine to be just under the tin without actually licking the bottom of it.
After about ten minutes of cooking look at your bread. The top of it should be starting to firm up. At 12 minutes take a toothpick and stick it in the center of the tin. If the toothpick comes out smoothly, with no batter stuck to it, then its safe to say your bread is ready! If your toothpick gets stuck, close the lid again and let it cook for another two or three minutes.
It is a good idea to let the tin cool for about 25-30 seconds. That should be enough time to cool it off if your flame wasn't touching the tin. Turn the tin over and tap the bottom of it until your bead pops out. If you didn't use olive oil, you may have to pry it out with a small stick or your fingers.
6
comments
Add Comment
KittyF
says:
Add Comment
