Altoids Tin Guitar
Altoids Tin Guitar
I got this idea from the original Altoids Guitar posted by bumpus. When I set out to make my own Altoids Tin Guitar, I decided to make an Instructable out of it.
Enjoy!
Step 1Tools and Parts Needed
Parts Needed:
(1) Empty Altoids Tin
(3) Rulers, paint stir sticks, or I used banister rail spacers
(3) Guitar Strings (I used the top 3)
(1) Old BIC pen
(1) Some plastic (credit cards work well)
(3) 3/16 x 2 Eye bolts
(3) washers
(6) bolts
(1) piezo
(1) 1/8 mono jack
Tools Needed:
Drill with various drill bits
Gorilla Glue
Hot Glue Gun
Multitool
Needlenose plyers
Small plyers
178 comments
1-40 of 178next »
Jul 30, 2011. 1:12 AMjschnoor says:
could I make it a bass? the strings would be hard on the whole thing, but would it still work?
Oct 15, 2011. 10:19 PMfunyman1234potato says:
Yess it would but you would need to put 2 pieces of felt over the piezo to keep the staticition fibre vibrations to ruin the amp. i did it and i made a violyn electric guitar DRUMS lol that was hard and steel drums
Jul 29, 2011. 6:13 PMididabarrelroll says:
I lol'd
Aug 27, 2010. 7:40 PM404_Error says:
does anyone know if this would work with nylon strings - does the piezo act as a pickup, or a microphone?
Jun 28, 2011. 8:48 AMmentalman says:
The peizo will pick up any virbation That's the beauty of it. SO nylon should just make a different sound You may love it.
Dec 16, 2010. 2:13 AMkryptofacist says:
Does it have to be a piezo, or will a small speaker also work? Do you use a piezo because the guitar is very high in pitch?
Jun 28, 2011. 8:47 AMmentalman says:
The piezo is what what picks up the vibration in the box. it acts likt the pick-ups on a electric guitar But way cheaper. 8 buck o's at radio shack.
i built a two string I had to buy the piezo and the strings Everything else was in the house already.the fun is making it too. Then get a piece of pipe for your finger and play it like a slide and you'll love it. Serarch Diddley bow. and find out they are 1000's of years old.
Just DO it and enjoy making your own music.
Jun 19, 2011. 12:19 PMllcoolj4886 says:
hay can u make me one i will pay u ??????
Jun 28, 2011. 8:42 AMmentalman says:
You can look up Diddley Bow on yoo toob and learn how simple they are to make.
i made one with all hand tools that everybody has around the house . and making it your way is half the fun. radio shack has the piezo unit for about $8 bucks.
you will need some sort of amplifyed to plug it into. but ya probably have that in your home music system.
Jun 28, 2011. 8:39 AMmentalman says:
HEY that's cool You can Look up Diddley Bow on YooToob and see how they are made too TRY using a pipe with yours so you can slide it You will love the sounds and tune you can get I have been playing my 2 string stick for 6 mo.and still am no good but have a real blast.
Nov 22, 2009. 12:19 PMjunkevin says:
so how does the piezo work exactly? do the strings attach to it or what?
Jun 16, 2011. 11:01 PMbryandhispup says:
it acts like a microphone. a piezo is a sort of speaker for alarm sounds, when wired this way it will work ( just as a speaker will when wired this way) like a mic.
Dec 18, 2009. 12:51 PMJodex says:
You could attach it to the tin or to the neck. It pretty much doesn't matter. Simply with trying is the easiest way to find out where's the best.
Mar 25, 2011. 5:51 AMCaboose98 says:
is wondering, is it ok if i somehow hooked up a small speaker, would that work too?
Jun 16, 2011. 11:00 PMbryandhispup says:
yes it will act as a mic, the sound will be different from the piezo but you may like the tin-y sound it creates. kind of a steel guitar meets cigar box banjo sound...
Jun 16, 2011. 10:54 PMbryandhispup says:
you may consider reenforcing the holes, as, eventually, they will pull thru from tuning.
Jun 16, 2011. 10:51 PMbryandhispup says:
can you get a better pic of this step?
Oct 16, 2010. 1:59 PMheyitscorty7 says:
So can you put hot glue on the piezo?
Apr 15, 2011. 3:25 PMfatchumba667 says:
read the instructable and youll see, the last 2 lines
Jul 6, 2009. 4:04 PMninjaoffigs says:
So can I find one at radio shack?
Apr 15, 2011. 3:19 PMfatchumba667 says:
yeah most likely, also window alarms have them. i live in australia and i went to dick smith and picked one up for $15 with 2 piezos in it
Apr 15, 2011. 3:09 PMfatchumba667 says:
this is briliant! i got 2 piezos from a window alarm and made one of these, but with proper tuning pegs not hooks, and its fantastic! well done! and thank you!
Dec 17, 2010. 4:08 PMIcexist says:
Sep 4, 2010. 11:29 AMheyitscorty7 says:
Is it ok to put hot glue on the piezo?
Nov 27, 2010. 12:27 PMpsphaxzor says:
have you read the instructable?
Nov 15, 2010. 9:13 AMmegajohn says:
Can you(or if you can, how) put an electric guitar humbucker instead of the piezo?
Jul 29, 2009. 6:59 PMDdv20 says:
Can you put in more than 3 strings?
Sep 1, 2010. 1:35 PM404_Error says:
Im working on one right now that has 4, so yes.
Jul 23, 2010. 1:14 PMSasquatchKid says:
Made an aqustic one
Oct 4, 2009. 6:07 PMMr.Coolpants says:
what if we dont have a hot glue gun??
Feb 7, 2010. 11:56 AMMcGyver2 says:
Use Super Glue or find a way to Duck Tape it
Jun 18, 2010. 6:34 PMCharlie1337 says:
And its Duct tape
Nov 14, 2009. 6:56 AMWhales says:
 Go buy one??
May 8, 2009. 11:36 PMsupamunki says:
well how do u get the strings to be attatched on the inside
Nov 14, 2009. 6:59 AMWhales says:
 On one end of a guitar string they have a little"nub"(i'm not sure if they have a name..) that you use to fix it near the sound hole of a guitar you just open the altoids case and feed trough the end with no nub. the nub should catch on the little holes and not come through.
Apr 5, 2010. 8:39 PMKingJaymz says:
I suppose you could also tie a knot on the end of a string if you have a chopped down one.  It'd probably take a two pair of pliers to get it tied, but you knot it good enough and it would substitute for the "nub."
Slainte
Mar 17, 2010. 12:30 PMRobot Lover says:
you mean the bottom 3. it is a common mistake, i even mistake it sometimes. its like this, the bottom is the top and the top is the bottom
Mar 9, 2010. 9:09 PMs0meth1ng0re0ther says:
if the altiods side isnt the right way will it not work?????
Jan 28, 2010. 8:37 AMgrimfig says:
I'm not sure if this has been discussed or not yet, but wing nuts are a much better option that just the normal nuts.
Jan 19, 2010. 6:43 PMbellachester says:
 ok, so I bought 1/8 inch mono jack at radio shack and it has no guide. its product number 274-0251. There are 3 prongs. any help?
1-40 of 178next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:jwilson27
I am very geeky. I love to do hardware stuff like electronics and robotics projects, as well as software (coding and such). I am a full-time net / sys admin, plus I balance being a manger in there s...
more »
