I got this idea from the original Altoids Guitar posted by bumpus. When I set out to make my own Altoids Tin Guitar, I decided to make an Instructable out of it.
Enjoy!
Step 1: Tools and Parts Needed
Parts Needed:
(1) Empty Altoids Tin
(3) Rulers, paint stir sticks, or I used banister rail spacers
(3) Guitar Strings (I used the top 3)
(1) Old BIC pen
(1) Some plastic (credit cards work well)
(3) 3/16 x 2 Eye bolts
(3) washers
(6) bolts
(1) piezo
(1) 1/8 mono jack
Tools Needed:
Drill with various drill bits
Gorilla Glue
Hot Glue Gun
Multitool
Needlenose plyers
Small plyers
Step 2: Make room for the neck
Make sure to outline the areas of the Altoids tin before you begin cutting. You need to make one cut at the base of the tin for the first ruler to slide into (see pic, sorry it's fuzzy).
WARNING! Make sure you are cutting on the correct side. You want the nice Altoids logo to be displayed correctly when playing it. I am right handed, so I made the cut on the right side of the tin.
I used a drill to put holes in the box. Then I used a small knife on my multitool to cut the box out.
Step 3: Cut holes for the strings and the 1/8 jack
Now you need to make holes for the strings. Again, mark the holes before you break out the drill. I used a 3/32 drill bit for this.
You also need to make a hole for the 1/8 jack. I used a slightly larger drill bit and then bored out the hole with a pair of needlenose plyers.
Step 4: Cut up the BIC pen
Now we are going to cut up a BIC pen. This will be used for the strings to rest on (instead of the side of the Altoids tin). You need to cut it down to about 1 and 1/2 inches in length. Then cut that in half and trim it down to fit on the end of the tin.
I also put 3 notches in the pen for the strings to rest in.
After that, get out the hot glue gun. Apply a nice layer of glue on the BIC pen piece and put it on edge of the lid, above the strings (see pic)
Step 5: Attach the 1/8 jack and insert the neck
You need to attach the 1/8 jack before you insert the neck. You want to make sure everything fits correctly. I mounted the 1/8 jack and put an adapter in it to be 100% sure everything would fit.
NOTE: If the ground plug touches the case, this will not work.
After you know everything will fit, put some Gorilla Glue on the bottom of the case and slide in the ruler (only 1/2 way or as far as you can go without hitting the jack).
After that glue was set, I covered the whole thing with glue from the hot glue gun. Just to seal everything up and make sure the ruler will not come apart.
Step 6: Working on the neck
Cut the plastic (an old Skype card worked for me) down to the width of the rulers. Bend the plastic. We are going to insert this between the top and middle rulers to guide the strings. You will want to make the bend a little larger than the height of your ruler.
Cut the other 2 rulers you have down about 1 inch smaller than what is sticking out of the Altoids tin. Get out the hot glue gun. Glue down the first ruler. Then glue the plastic down with the tab sticking up. Then glue down the final ruler on both the plastic and the middle ruler.
Step 7: Finish the neck
Now we need to add holes for the eye bolts. Measure and mark before drilling. I used a 3/16 drill bit. You want to make a V with the bolts. Put two close to the neck and one on the end. Then, insert the bolts with the nut and washer on the top side. One nut will go on the bottom (you can add washers if you want more support).
Step 8: Wiring up the piezo
Break the piezo from it's case. Be careful not to damage the piezo in the process.
Once it is freed, wire it to the 1/8 jack. Follow the diagram that came with your 1/8 jack to find out which is positive and which is negative.
Before I glued it to the case, I drilled a very small (1/16) hole in the lid. Center the piezo on the hole in the lid and hot glue it down.
Step 9: Almost done!
Now we just have to string it up. Insert strings into the holes on the end. Once they have all been inserted, close the lid. Loop each string over the BIC pen and then thread them into the eye bolts. I looped the string 3 or 4 times in the eye, then allowed the slack to twist around the body of the bolt.
To tune, just turn the eye bolts to add tension to the string. Then tighten the nuts to keep the bolt in place.
Then plug in and play!
1-40 of 184Next »
HardCoreHacker says: Oct 14, 2012. 9:13 PM
Alright, so i did this all tonight for a physics project tomorrow lol. I just want to say you can fit a 1/4" monojack in the altoids can if you: A) put the hole in the right spot. B) are willing to have a slight bulge at the bottom. I used a 1/4" just because I didnt have an "adapter". If your Radioshack doesnt think they have piezos or monojacks, look the items up online and tell them the catalog number. When I went in person they had no idea what a piezo was and swore they didn't have any monojacks or piezos, but when I gave them the catalog number they got it for me.
Ninjakaib says: Sep 1, 2012. 8:52 PM
This is so cool.
jschnoor says: Jul 30, 2011. 1:12 AM
could I make it a bass? the strings would be hard on the whole thing, but would it still work?
funyman1234potato in reply to jschnoorOct 15, 2011. 10:19 PM
Yess it would but you would need to put 2 pieces of felt over the piezo to keep the staticition fibre vibrations to ruin the amp. i did it and i made a violyn electric guitar DRUMS lol that was hard and steel drums
TheJoshinator in reply to funyman1234potatoMar 21, 2012. 6:33 PM
Old comment, I know, but if you want a bass consider using nylon weed-eater string. It'll be lower tension, thus less wear and tear, and the piezo will still pick it up because it senses mechanical vibration rather than magnetic field fluctuation like a normal pickup.
beehard44 says: Mar 21, 2012. 12:51 AM
If i would make one, i'd make it 4 holes and use bass strings
And maybe reinforce things a bit
Aron313 says: Mar 20, 2012. 1:15 PM
Im going to make one a learn how to play heartbreak station on it hehe! :P
Alex Mercer says: Mar 20, 2012. 6:36 AM
Thanks for this instructable. I like it and I will give five stars.
ididabarrelroll says: Jul 29, 2011. 6:13 PM
I lol'd
404_Error says: Aug 27, 2010. 7:40 PM
does anyone know if this would work with nylon strings - does the piezo act as a pickup, or a microphone?
mentalman in reply to 404_ErrorJun 28, 2011. 8:48 AM
The peizo will pick up any virbation That's the beauty of it. SO nylon should just make a different sound You may love it.
kryptofacist says: Dec 16, 2010. 2:13 AM
Does it have to be a piezo, or will a small speaker also work? Do you use a piezo because the guitar is very high in pitch?
mentalman in reply to kryptofacistJun 28, 2011. 8:47 AM
The piezo is what what picks up the vibration in the box. it acts likt the pick-ups on a electric guitar But way cheaper. 8 buck o's at radio shack.
i built a two string I had to buy the piezo and the strings Everything else was in the house already.the fun is making it too. Then get a piece of pipe for your finger and play it like a slide and you'll love it. Serarch Diddley bow. and find out they are 1000's of years old.
Just DO it and enjoy making your own music.
llcoolj4886 says: Jun 19, 2011. 12:19 PM
hay can u make me one i will pay u ??????
mentalman in reply to llcoolj4886Jun 28, 2011. 8:42 AM
You can look up Diddley Bow on yoo toob and learn how simple they are to make.
i made one with all hand tools that everybody has around the house . and making it your way is half the fun. radio shack has the piezo unit for about $8 bucks.
you will need some sort of amplifyed to plug it into. but ya probably have that in your home music system.
mentalman says: Jun 28, 2011. 8:39 AM
HEY that's cool You can Look up Diddley Bow on YooToob and see how they are made too TRY using a pipe with yours so you can slide it You will love the sounds and tune you can get I have been playing my 2 string stick for 6 mo.and still am no good but have a real blast.
junkevin says: Nov 22, 2009. 12:19 PM
so how does the piezo work exactly? do the strings attach to it or what?
bryandhispup in reply to junkevinJun 16, 2011. 11:01 PM
it acts like a microphone. a piezo is a sort of speaker for alarm sounds, when wired this way it will work ( just as a speaker will when wired this way) like a mic.
Jodex in reply to junkevinDec 18, 2009. 12:51 PM
You could attach it to the tin or to the neck. It pretty much doesn't matter. Simply with trying is the easiest way to find out where's the best.
Caboose98 says: Mar 25, 2011. 5:51 AM
is wondering, is it ok if i somehow hooked up a small speaker, would that work too?
bryandhispup in reply to Caboose98Jun 16, 2011. 11:00 PM
yes it will act as a mic, the sound will be different from the piezo but you may like the tin-y sound it creates. kind of a steel guitar meets cigar box banjo sound...
bryandhispup says: Jun 16, 2011. 10:54 PM
you may consider reenforcing the holes, as, eventually, they will pull thru from tuning.
bryandhispup says: Jun 16, 2011. 10:51 PM
can you get a better pic of this step?
heyitscorty7 says: Oct 16, 2010. 1:59 PM
So can you put hot glue on the piezo?
fatchumba667 in reply to heyitscorty7Apr 15, 2011. 3:25 PM
read the instructable and youll see, the last 2 lines
ninjaoffigs says: Jul 6, 2009. 4:04 PM
So can I find one at radio shack?
fatchumba667 in reply to ninjaoffigsApr 15, 2011. 3:19 PM
yeah most likely, also window alarms have them. i live in australia and i went to dick smith and picked one up for $15 with 2 piezos in it
fatchumba667 says: Apr 15, 2011. 3:09 PM
this is briliant! i got 2 piezos from a window alarm and made one of these, but with proper tuning pegs not hooks, and its fantastic! well done! and thank you!
Icexist says: Dec 17, 2010. 4:08 PM
heyitscorty7 says: Sep 4, 2010. 11:29 AM
Is it ok to put hot glue on the piezo?
psphaxzor in reply to heyitscorty7Nov 27, 2010. 12:27 PM
have you read the instructable?
megajohn says: Nov 15, 2010. 9:13 AM
Can you(or if you can, how) put an electric guitar humbucker instead of the piezo?
Ddv20 says: Jul 29, 2009. 6:59 PM
Can you put in more than 3 strings?
404_Error in reply to Ddv20Sep 1, 2010. 1:35 PM
Im working on one right now that has 4, so yes.
SasquatchKid says: Jul 23, 2010. 1:14 PM
Made an aqustic one
Mr.Coolpants says: Oct 4, 2009. 6:07 PM
what if we dont have a hot glue gun??
McGyver2 in reply to Mr.CoolpantsFeb 7, 2010. 11:56 AM
Use Super Glue or find a way to Duck Tape it
Charlie1337 in reply to McGyver2Jun 18, 2010. 6:34 PM
And its Duct tape
Whales in reply to Mr.CoolpantsNov 14, 2009. 6:56 AM
 Go buy one??
supamunki says: May 8, 2009. 11:36 PM
well how do u get the strings to be attatched on the inside
1-40 of 184Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
