3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids Tin Guitar
Step 8Wiring up the piezo
Wiring up the piezo
Break the piezo from it's case. Be careful not to damage the piezo in the process.
Once it is freed, wire it to the 1/8 jack. Follow the diagram that came with your 1/8 jack to find out which is positive and which is negative.
Before I glued it to the case, I drilled a very small (1/16) hole in the lid. Center the piezo on the hole in the lid and hot glue it down.
14 comments
Dec 16, 2010. 2:13 AMkryptofacist says:
Does it have to be a piezo, or will a small speaker also work? Do you use a piezo because the guitar is very high in pitch?
Jun 28, 2011. 8:47 AMmentalman says:
The piezo is what what picks up the vibration in the box. it acts likt the pick-ups on a electric guitar But way cheaper. 8 buck o's at radio shack.
i built a two string I had to buy the piezo and the strings Everything else was in the house already.the fun is making it too. Then get a piece of pipe for your finger and play it like a slide and you'll love it. Serarch Diddley bow. and find out they are 1000's of years old.
Just DO it and enjoy making your own music.
Oct 16, 2010. 1:59 PMheyitscorty7 says:
So can you put hot glue on the piezo?
Apr 15, 2011. 3:25 PMfatchumba667 says:
read the instructable and youll see, the last 2 lines
Jul 6, 2009. 4:04 PMninjaoffigs says:
So can I find one at radio shack?
Apr 15, 2011. 3:19 PMfatchumba667 says:
yeah most likely, also window alarms have them. i live in australia and i went to dick smith and picked one up for $15 with 2 piezos in it
Jul 29, 2009. 6:59 PMDdv20 says:
Can you put in more than 3 strings?
Sep 1, 2010. 1:35 PM404_Error says:
Im working on one right now that has 4, so yes.
Apr 6, 2009. 9:22 PMamber05. says:
how piezo works as a microphone?
Nov 5, 2009. 6:23 AMdailodai78 says:
usually a piezo works as a buzzer for output. all it does is vibrates. if you do it in reverse by soldering the wires to an audio jack / speaker,  the piezo amplifies the vibrations you make after plucking the strings. Depending on where you pluck the string, each vibration will make a note. Try reading some information on guitar tuners. I hear they auto tune by measuring the vibration of the string being plucked.
Sep 26, 2009. 10:35 AMpanzuman says:
hey i bought a piezo and it has some sortof circuit board does that matter?
Jun 6, 2009. 4:24 AMtoil_and_spin says:
What is a piezo pickup? I've checked google and don't know how to get/find one.
Jul 19, 2009. 11:24 AMcdousley says:
get the big buzzer at radio shack
Jun 17, 2009. 9:01 PMkipfan23 says:
does the piezo go inside of the tin?
Mar 30, 2009. 9:14 PMjlxaa.5 says:
This is the best thing everrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! its a pain in the butt but it can play a good song you should get it!!!!!!!
Aug 29, 2008. 8:20 PMJonny Appleseed says:
where exactly did you drill the hole in the lid?
Oct 5, 2008. 9:52 AMjillg says:
i dont think it matters but when i do this im gonna put the hole kinda in the middle of the strings
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:jwilson27
I am very geeky. I love to do hardware stuff like electronics and robotics projects, as well as software (coding and such). I am a full-time net / sys admin, plus I balance being a manger in there s...
more »
