3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids Tin Guitar
Step 9Almost done!
Almost done!
Now we just have to string it up. Insert strings into the holes on the end. Once they have all been inserted, close the lid. Loop each string over the BIC pen and then thread them into the eye bolts. I looped the string 3 or 4 times in the eye, then allowed the slack to twist around the body of the bolt.
To tune, just turn the eye bolts to add tension to the string. Then tighten the nuts to keep the bolt in place.
Then plug in and play!
12 comments
Jul 30, 2011. 1:12 AMjschnoor says:
could I make it a bass? the strings would be hard on the whole thing, but would it still work?
Oct 15, 2011. 10:19 PMfunyman1234potato says:
Yess it would but you would need to put 2 pieces of felt over the piezo to keep the staticition fibre vibrations to ruin the amp. i did it and i made a violyn electric guitar DRUMS lol that was hard and steel drums
Mar 21, 2012. 6:33 PMTheJoshinator says:
Old comment, I know, but if you want a bass consider using nylon weed-eater string. It'll be lower tension, thus less wear and tear, and the piezo will still pick it up because it senses mechanical vibration rather than magnetic field fluctuation like a normal pickup.
Nov 22, 2009. 12:19 PMjunkevin says:
so how does the piezo work exactly? do the strings attach to it or what?
Jun 16, 2011. 11:01 PMbryandhispup says:
it acts like a microphone. a piezo is a sort of speaker for alarm sounds, when wired this way it will work ( just as a speaker will when wired this way) like a mic.
Dec 18, 2009. 12:51 PMJodex says:
You could attach it to the tin or to the neck. It pretty much doesn't matter. Simply with trying is the easiest way to find out where's the best.
Mar 25, 2011. 5:51 AMCaboose98 says:
is wondering, is it ok if i somehow hooked up a small speaker, would that work too?
Jun 16, 2011. 11:00 PMbryandhispup says:
yes it will act as a mic, the sound will be different from the piezo but you may like the tin-y sound it creates. kind of a steel guitar meets cigar box banjo sound...
Apr 15, 2011. 3:09 PMfatchumba667 says:
this is briliant! i got 2 piezos from a window alarm and made one of these, but with proper tuning pegs not hooks, and its fantastic! well done! and thank you!
May 6, 2012. 12:29 PMheyitscorty7 says:
Is it ok to put hot glue on the piezo?
Nov 27, 2010. 12:27 PMpsphaxzor says:
have you read the instructable?
May 3, 2009. 3:04 AMsupamunki says:
shouldnt the strings be higher?
Nov 22, 2008. 4:21 PMOatsnHoney says:
Awesomeeeeeeeeeeeeeeeeee!!!!!!!!!!!!
Mar 25, 2008. 9:46 PMgnargnar says:
oh man! adding the nuts to keep the tuners in place is genius. i built a slide guitar, but couldn't get the strings to stay in tune for the life of me! i'll be stealing this soon hopefully. much thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:jwilson27
I am very geeky. I love to do hardware stuff like electronics and robotics projects, as well as software (coding and such). I am a full-time net / sys admin, plus I balance being a manger in there s...
more »
