3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids Tin Speaker
Step 2Schematic and PCB Layout
As noted in the introduction, the circuitry surrounding the Maxim MAX 756 and LM386 chips is directly from their respective datasheets. The schematic and the PCB were designed using the freeware version of the EAGLE Layout Editor from CadSoft.
6 comments
Dec 29, 2010. 4:35 PMPazzoPazzo says:
(removed by author or community request)
Jun 17, 2010. 10:05 AMDelta25 says:
is needed the 9 volt imput or you only need de AA battery?
Mar 26, 2010. 10:24 AMchicken12175 says:
is there any way i can use an LM311 chip as the amplifier. can you do a schematic for this chip please as this is the only chip i can get easily. BTW great guide!
Mar 28, 2010. 2:19 AMchicken12175 says:
OK
cheers for the advice and will try to get an LM386 chip
Dec 9, 2009. 6:28 PMAKninja04 says:
Why do you wire the input coming from the audio jack to the negative input on the lm386 instead of the positive?
Dec 9, 2009. 6:34 PMAKninja04 says:
Also, where do all of those grounds connect back to? Sorry if these are very novice questions.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:matth3w
