3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids Tin Speaker
Step 3Making and Preparing the PCB
There are numerous resources on the Internet that describe the process of creating PCBs.
Transfer
I had (and still have) considerable difficulty getting consistent transfers onto the copper board. I currently use Press-n-Peel Blue Transfer Film from Techniks.com. I have also tried following the process detailed by riccibitti with little success (my impatience). It seems as if everyone has a preferred and flawless method, and none of them work well for me! I end up using a Sharpie to fill in the mask. This is overall the weak link in the making of PCBs.
Etching
After several frightening attempts at etching with Ferric Chloride over a pan of warm water in my kitchen, I moved into a chemistry lab and used the technique described in the Instructable Stop-using-Ferric Chloride. The materials were cheaper, more readily available (local hardware store and CVS), cleaner and safer. The initial etching was fast and aggressive, although I had some trouble with subsequent batches.
Cutting
I don't have a good method for cutting PCBs. Suggestions and recommendations would be appreciated.
Drilling
To drill the holes I used a Dremel tool with drill extension and a 1/32" bit for most holes. For the diode and holes for the speaker, battery, switch, and audio connection, I used a 3/64" bit. Bits are from Lee Valley.
3 comments
Nov 3, 2009. 8:15 AMadumas says:
hi is it possible you could send me the schematic and PCB versions. I'd like to make some modifications. My email address is zbayoff100@yahoo.com. Thanks
Apr 29, 2009. 5:30 PMchristopherlita says:
what size does this image need to be?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:matth3w
