3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids Tin Speaker
Step 5Soldering Parts to PCB
  • altoids-speaker-parts.tif
There are numerous resources on the Internet that describe the process of soldering electronic components to PCBs. See, for example the soldering tutorial at ladyada.net. The order in which you install components doesn't really matter, although I have found working from smallest to largest them easiest. I assemble the board in the following order.
Jumpers
I use jumpers (small pieces of wire) in a few places instead of having a double sided board. There a several places in this design where I could not figure out a simple way of getting a wire from one place to another without crossing a second wire. Jumpers were my solution.
Note that the schematic calls for a second diode (D2) where power enters the LM386 chip. This was necessary when the circuit only consisted of the amplifier portion; I don't think it is necessary any more and I replace it with a jumper.
Chip holders
I put the chip holders in next. The two provide a relatively stable surface on which to balance the board upside down for future soldering. The orientation of the chip holders matters -- make sure the notched end is located as illustrated so that the chips are oriented correctly when inserted.
Small capacitors
The four small capacitors go in next.
Resistor
The resistor is positioned vertically
Diode
The holes for the diode should be 3/64. The spacing between holes is a little small so care must be taken fitting the diode in place. More important, however, is getting the orientation of the diode correct.
Large capacitors and inductor
These go in easily and form a sort of wall to support the battery holder. Care must be taken to ensure the correct orientation of the electrolytic capacitors. Note the location of the white strip on each capacitor. The orientation of the inductor does not matter.
Check your work
Be careful to orient the components properly. The orientation of the chip holders, the electrolytic capacitors and the diode matter. Check the layout diagram and the schematic or just make sure things match up with the pictures!
2 comments
Oct 14, 2010. 4:59 PMMotts says:
Would it be possible to add to and modify this into a sort of mini amp with a headphones jack?
Oct 16, 2010. 1:05 PMMotts says:
right, good plan. I have dozens of these tins anyway, no point in trying to conserve one. Thanks for the link!
Aug 31, 2008. 6:36 PMbuiocchi says:
why are there chip holders? just wondering what purpose they serve
Oct 11, 2008. 10:26 AMnarcoduck says:
When soldering, your using quite a high temperature. The miniature cicuitry in an IC chip can be damaged by this intense heating, and so most people use chip-holders, which are unaffected as they are only bits of metal and plastic. If you use one, but leave the chip in it while soldering, why even buy one in the first place? It's just a quick and simple way of avoiding damage to an expensive chip, as some 8 pin chips can cost up to 300 times the cost of a holder.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:matth3w
