Altoids Tin Stove w/ Pot Rest by die_dunkelheit
Featured
The Pot Rest featured in this Instructable is intended as an improvement on lo-tec's Instructable "Altoids Tin Alcohol Stove" and picks up where lo-tec's Instructable ends by showing the steps necessary to add this functionality to your Altoids Tin Alcohol Stove. So you'll need to complete lo-tec's Instructable "Altoids Tin Alcohol Stove" to make yourself a stove first.
Step 1: Materials
To complete your Alcohol Burner Pot Rest you'll need a few simple tools and materials...
Materials:
1.) Aluminum Flashing
2.) Pop Rivets (or other fastener)
3.) Washers (about 20)
Tools:
1.) Tin Snips
2.) File
3.) Pop-Rivet tool
4.) Drill w/ drill the correct size for your pop-rivets (mine are 1/8")
5.) Hacksaw
6.) Marker
robanna says: Mar 16, 2010. 9:32 AM
You could save a bunch of weight by making the supports out of two 'V's that hook together to make sort of an 'X'
Let me try it in asci art:
Sort of...
Bend the two strips (step 2) into 'U' or 'V' shapes. Make slits 1/2 way through so they interlock. Am I making sense?
Oh, here's a quick sketch:
stormy0314 says: Jul 6, 2011. 12:24 PM
I think it would improve the whole if just the support were notched and not the can. That way more alky could be added.
Cracknel says: Sep 7, 2010. 5:00 AM
This design is better!
Nice idea ;)
robanna says: Mar 16, 2010. 9:36 AM
Also, in step 5 I would cut the supports 1/2 way and the can 1/2 way so that the supports sit on the bottom of the can instead of a bit above the bottom. It might add some support.
Toshikazu says: Feb 28, 2010. 12:08 PM
To imrove on stability, could you possibly cut a slit/groove on the bottom of the pot rest to allow it a slight amount of overhang?  I realize this would be a pain to do with the angles but if it's actually holding on "around" the lip of the altoids can it would probably be a bit more sturdy!  Maybe 1/8" or 1/4" down?
thehumannapkin says: Jan 7, 2010. 12:37 PM
THAT IS NOT CALLED A ALTOIDS TIN IT IS CALLED A "SENBON"
JK
lemonie says: Jan 7, 2010. 1:50 PM
Look again: you can see "Altoids" stamped on the lid.
L
die_dunkelheit (author) says: Jan 7, 2010. 4:53 PM
He was jokingly referring to a comment on my first Instructable Knife Throwing, where someone incorrectly told me I had used an incorrect word to describe something.
lemonie says: Jan 7, 2010. 5:01 PM
Yes but "Senbon"?! this kid is on another planet I think? It's a nice build, I don't see any justification for CAPS
L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
