Altoids Tin Travel Games - Pocket Size Fun
 by jphphotography
FeaturedContest Winner
Altoids tins are amazing things and here is yet another fun use for them. While this instructable includes a checker/chess board, tic-tac-toe, and backgammon the possibilities are really endless so feel free to add your own ideas.
Materials Needed:
Altoids 50g Tin (Rectangular)
Printer
Glue (Spray adhesive works well but a gluestick will also work)
Crazy Glue
Scissors
Fimo (for making your own game pieces)
Rare Earth Magnets
Hammer (optional, you'll see why in step 5)
Safety Glasses (if you need to bust up your magnets into smaller pieces)
Remember to vote if you like it!
*Important Warnings:
Magnets: Though this game is pocket size you should take care what you already have in your pocket when placing this game inside as it makes use of some very strong magnets. Some things like sensitive electronics, cameras, and especially credit cards with magnetic stripes do not play well with rare-earth magnets.
Choking Hazard: If you're making this for your kids (or with them) keep in mind that the game pieces are small and could pose a choking hazard to small children.
Step 1: Cleaning The Tin
Eat all the mints or dump them into a ziplock bag for consumption later, it never hurts to have a bag of mints in your car or desk at work.
Mint dust, while tasty,  can impede the glueing portion later on. Run the tin under a tap and then dry thoroughly with paper towel. If you have a can of compressed air it wouldn't hurt to give it a quick blast just to make sure its all gone.
Step 2: Print & Cutout The Game Surfaces
The attached template sheet is made to be printed on 8.5x11 paper in order for the game surfaces to be sized correctly. If you are having problems getting it to print properly try setting your print size to 100% at a dpi of 300.
Using scissors carefully cut the game surfaces out. There is also a blank template included if you choose to make your own instead of using the supplied ones.
Step 3: Glue The Game Surfaces To Your Tin
Apply adhesive to the back of the paper game pieces and affix them to the desired surface of the tin. Be sure that your mint tin is clean (back at step 1) othewise any mint dust may cause the glue not to adhere properly. Leave it sit and dry while you do the next steps.
Step 4: Make Your Game Pieces Part 1
You can get a little creative here, I chose to use some Fimo that I've had laying around for years and hadn't found a use for. The chess pieces can be difficult but since its your game you can make them look however you want. For the tic-tac-toe pieces I kept it simple with plain discs of different colors.
There are probably many ways to make the various game pieces you'll need so don't feel you have to follow this to the letter.
Below are the various pieces you'll need for each game:
Chess: One set for each side made of the following
8 Pawns, 2 Castles (Rooks), 2 Knights, 2 Bishops, 1 King, 1 Queen.
Checkers:
12 Checkers of one colour, 12 checkers of another colour
Backgammon:
Two sets of 15 checkers, Two sets of two dice, one doubling cube with sides numbered 2,4,8,16, 32, and 64
It would be a good idea to just use the backgammon checkers for regular checkers instead of making seperate pieces for each game.
Step 5: Make Your Game Pieces Part 2
Once your game pieces are all formed you'll need to affix a magnet to the bottom of them. Depending on the size of the rare-earth magnets you use you may have to break them up a little with a hammer to get smaller pieces ***WEAR SAFTEY GLASSES*** if you have to break them apart. [Edit] Alternately you could use two pairs of pliers and break them in have again and again until they are small enough, probably a safer method ;)
When I made mine I thought just fitting the magnets into the Fimo would be enough but as you can see in the attached image they'd fall out.
You can do it one of two ways:
1) You can do what I did and try to form-fit the magnets into your game pieces first, bake them, and then glue them.
2) Keep your game pieces flat on the bottom, bake them, then glue them in place.
Either way should work, my method was due to trial and error.
Step 6: Play
Hopefully now all the glue is dry and your ready to test out your new portable 4 in 1 Altoids travel game!
1-40 of 62Next »
Nate230 says: Jun 13, 2013. 1:55 PM
Where can i get magnets?
jphphotography (author) in reply to Nate230Jun 13, 2013. 2:11 PM
I got mine from Dealextreme (http://dx.com/c/hobbies-toys-899/toys-for-all-ages-803/magnets-gadgets-835) but nowadays they're quite common, if you have a Lee Valley store in your area/country they sell them there I believe. Ebay or Dealextreme will be the cheapest by far though, any extras are handy to have around as fridge magnets etc. I've superglued some to random things so they'd hang on my fridge (scissors for example).
Frederbee says: Aug 18, 2012. 10:06 PM
For the magnets, when I was in elementary school we had earrings that were no-pierce. They would be shaped like the stud, about a 1/8" round cylinder, and would magnetically cling through the ear. These would be roughly the size you need
Frederbee in reply to FrederbeeAug 18, 2012. 10:08 PM
Or these if you go with the colour coding
http://www.claires.com/store/goods/Teens/cat310120/Clips-%26-Magnetics/p52199/Colored-Gemstones-Magnetic-Earring-Set-of-9/
jeditanker72 says: May 3, 2012. 11:58 PM
Nice to see Altoids used for something other than freshening your breath, or surviving the collapse of society. Great job!
xavec says: Jul 12, 2011. 12:54 AM
This is totally outstanding work. Nice job! now I just need to find a similar sized tin in the UK...
awsomeegan says: Jun 4, 2011. 1:35 PM
can you tell me how you guys get the top of the tins to smooth, all the tins i see have ALTOIDS raised and i dont know if you have to find a smooth one or if you flatten them some how
chilll2009 says: Dec 21, 2010. 6:49 PM
awesome idea.
I am Silas. says: Sep 2, 2009. 8:42 PM
You did an awesome job.
Archive555 in reply to I am Silas.Nov 19, 2010. 6:06 AM
Comment spam!
Seriously though, is this a double post gone terribly wrong, or did you intend to make four separate consecutive posts? :P
highvoltageev says: Jul 3, 2009. 8:12 AM
Pretty awesome idea, however I'd suggest picking a game other than tic-tac-toe considering it's such a flawed game (as long as the two people playing truly know how to play, it will always end in a tie).
dungeon runner in reply to highvoltageevJun 1, 2010. 6:34 PM
Yeah, that's always bugged me. One of the things they teach you in a computer science course is making a simple tic-tac-toe algorithm. I made one in two days:).
Now, if you want a real challenge, try Quantum tic-tac-toe. It was a game designed to help students understand quantum mechanics, so you can pretty much guess the level of strategy involved.
-Y
Archive555 in reply to dungeon runnerNov 19, 2010. 6:04 AM
That Quantum Tic-Tac-Toe just blew my mind.
Thank you good sir.
superMacaroni says: Sep 9, 2010. 1:25 AM
How about using allergy pills?
Archive555 in reply to superMacaroniOct 5, 2010. 2:02 AM
I'm not sure I understand.
Care to elaborate?
haugenka says: Jun 24, 2010. 9:21 AM
Great idea, well designed instructable – love the quality photos. The only thing I'd change is how to do the game boards. Printables are quick, for sure, but how do you make the paper durable/waterproof/etc.? I suppose you could shellac it on, or I think you could spray the tin white, then mask on the black bits, or burnish off the original paint, mask it and just spray the black parts. A bit more work, but then it'd last for camping, etc.
haugenka says: Jun 24, 2010. 9:09 AM
I'm thinking you could use the letters from an old typewriter to press into the fimo – Q for queen, etc. The only issue is the knights & king, but the king is usually designated with a cross, so you could use the plus or X. I'd still probably try to shape them a bit, but this would help and give it a nice industrial look...
klingonprins says: Feb 2, 2010. 9:29 AM
COOL!
i used the kiln oven in my school to make the pieces for chess out of clay.
but i didnt want to make the actual figures (i tried the first time and the cracked in me pocket), i just made black and white checkers with K, Q, B, H (horse), R, and P, and i play every weekend on the train to the nyc with my friends.
jphphotography (author) in reply to klingonprinsFeb 2, 2010. 12:08 PM
Right on! Glad to hear it worked for you and that you're getting some good use out of it. Nice idea marking the simple pieces instead.
Cheers
klingonprins in reply to jphphotographyFeb 5, 2010. 9:27 AM
thanks.  i will send some pics of the kit i made when i get my camera fixed, but you can probably guess.  it was a waste of time to make all of the figures like real.  i make chess peices as a hobby and sell them on the street markets in my city, and i can get around $500 for something like them and an easy wood board.
depotdevoid says: Aug 15, 2009. 11:45 AM
Great idea, I just made one, and it rocks!
jphphotography (author) in reply to depotdevoidAug 15, 2009. 1:02 PM
Glad you liked it, you should post a few pictures I'd love to see it!
depotdevoid in reply to jphphotographyAug 15, 2009. 3:21 PM
Well, I found a little time to get this done, so here are the pictures. The last one has my own little addition, a deck of mini playing cards. Thanks for the idea, I intend to use this as a sub-component to an upcoming instructable, and I'll make sure to attribute it to you and link back to this 'ible. Thanks, Ian
lorewheelock in reply to depotdevoidDec 24, 2009. 1:56 PM
awwwww i love it!!
depotdevoid in reply to jphphotographyAug 15, 2009. 2:20 PM
Will do, the Fimo is baking and will be done soon, I'll probably post a few pictures tonight.
I am Silas. says: Sep 2, 2009. 8:41 PM
Thank you jphphotography!
I am Silas. says: Sep 2, 2009. 2:06 PM
What would be an alternative for Fimo?
jphphotography (author) in reply to I am Silas.Sep 2, 2009. 3:02 PM
Fimo is a "polymer clay", I believe an alternative would be a product called "sculpey" http://www.sculpey.com/
You can also try googling Polymer Clay and see if anything else comes up.
I am Silas. says: Sep 2, 2009. 1:55 PM
Excuse me but what is Fimo?
panascakes says: Aug 24, 2009. 1:16 PM
CrazyRainChild says: Aug 13, 2009. 11:45 AM
For chess pieces you could have each piece be a different color rather than shape. Then one team could have circle pieces and one team could have square pieces. That way you would not have to try to shape the pieces.
jphphotography (author) in reply to CrazyRainChildAug 15, 2009. 1:02 PM
At first when I read your comment I thought that would take way too many colours but after thinking more about it you're right. Unfortunately I only had 2 colours so I was stuck. You'd need 6 colours but if you were mixing them you could probably do it with less, say if you just picked up Red, Yellow, Blue for example. Thanks for the suggestion.
thegreatash says: Jul 29, 2009. 9:56 AM
u r gr8 at photography
jphphotography (author) says: Jul 20, 2009. 12:10 PM
Thanks for all the positive feedback guys, remember if you really like this project I'd appreciate a vote for the "pocket size" contest. Voting buttons are up at the top of the screen. Thanks again James PS If any of you make this project feel free to post a picture of how it turned out!
amakerguy says: Jul 18, 2009. 6:13 AM
hey thanks I like it. I'm going to make it! (I have 2 big tins and 2 smalls tins)
MLB Baseball Guy says: Jul 7, 2009. 8:27 AM
Wow.. looks cool. It's always nice to have several games in one box. Thanks for the instructable!
skatelong says: Jul 3, 2009. 5:40 PM
Does anyone know were to get altoids in NZ???
jphphotography (author) in reply to skatelongJul 5, 2009. 3:36 PM
I wish I could help you out but I have no idea. You may however be able to order a case of them off ebay or a similar site. The tins are great for projects so you'll probably use all the tins up eventually ;)
pinsNneedles says: Jul 3, 2009. 7:06 AM
It looks very professional. That sheet magnet can be very strong,i have it for fridge magnets and they are solidly fixed,you have to pull pretty hard to release them. I think for chess,you could print out the chess pieces and then stick them to it,it would make for more compact counters for the games. Snakes and ladders and Ludo would be good .
jphphotography (author) in reply to pinsNneedlesJul 3, 2009. 1:23 PM
The sheet magnet as a whole is pretty strong yes, however when cut down into small circles the strength is vastly reduced. I tried it and it just didn't work, however maybe others will have better luck with different sheet magnets. I agree with some of the other comments that it could work quite well for being able to swap out game boards. Thanks for all the comments everyone, I'm glad this one was a hit!
1-40 of 62Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
