3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids Tin Wallet
Altoids Tin Wallet
This versatile candy tin can also be used as a wallet! In case you haven't already discovered, standard credit cards and ID's fit perfectly into the venerable Altoids tin. Check it out! This is super easy, and aside from taking time to eat all of the candy, this can take as little as 1 minute or up to several hours depending on how complex you want to get.
My idea contains no fancy construction, original ideas, MSG, or preservatives.
Customize it! Ladies, you can add a strap to carry on the town, or guys paint it matte black and add a custom hot rod emblem like I did.
Wallet challenge - looks like someone posted one while mine was in progress! Great minds think alike - oh well on with the instructable!
Step 1Gather your items
Gather your items
You will need the following:
1. One Altoids tin, or several.
2. Rubber bands, paper binder, elastic hair ties, or a recycled inner tube to use as your binding mechanism ( or a million other combinations I can't think of. I can envision complex opening mechanisms and the like, led's or whatever.
3. Optional: Recycled plastic to create an ID holder for inside the lid.
3. Stuff to put in it!
35 comments
Aug 4, 2011. 2:28 PMamelder says:
what did you do with the ALTOIDS indention? did you just ignore it or somehow flatten it?
Nov 26, 2011. 9:42 PMsjoobbani says:
The older tins didn't have the indentation...
FYI the older tins are the ones that have the strait color border around the lid, not the fancy shaped and pointed one.
Jul 26, 2010. 12:48 AMtwitchy909 says:
thats what i thought
Sep 15, 2009. 4:51 PMokgo125 says:
My friend though that R.F meant rat fart ;)
Aug 24, 2009. 3:29 PMshadowcat17 says:
would this shield cards from an RFID scanner?
Jul 9, 2009. 10:36 AMcrackjr says:
sweet with the rat fink aka big daddy roth dude
Apr 20, 2009. 5:18 PMpaperman5 says:
i used to have that same exact flash drive...
May 23, 2007. 10:16 PMKnittingFreak says:
Merlin: Is there any way to make the lid fit tighter, so you don't have to use bands to keep the tin from falling open?
Apr 27, 2007. 6:28 PMieatsnowmen says:
That is such a myth.
Feb 26, 2009. 3:10 PMdaltonjcw says:
no, it killed my cards. sad
Jun 8, 2007. 1:19 AMVery Keri says:
I saw an episode of Myth Busters where they tested out wallets and bill folds with magnets in them. The magnets were not a problem even after they carried them around in their pockets all day. You don't need anything stronger than refridgerator magnet for something like this anyway. I know I'm posting kinda late on this topic...
May 2, 2007. 9:53 AMpr0xie says:
It is not really a myth, but history. The old mag-stripes are easily erased with magnets. The newer types are not. "High coercivity stripes are resistant to damage from most magnets likely to be owned by consumers." From -http://en.wikipedia.org/wiki/Magnetic_stripe_card
Mar 26, 2008. 8:51 PMArx Fortis says:
There are several variables in play here such as the type of card, the strength (magnitude) of the magnet, period of exposure, and nature of the exposure. The common hotel key-cards still use the old-type mag stripes. Those cards are intended to be re-used. These cards can be made unreadable by magnets as small as the one in your cell phone speaker if held close enough...especially if it rings. :) Even the newer credit strips can be erased/damaged by a powerful enough magnet (such as a neodymium magnet) or a powerful electric drive motor. Lastly, the way in which the card is exposed to the magnet can also come into play. If a card is gradually brought into a relatively weak-to-moderate magnetic field, and gradually removed from the field, the stripe may retain enough of its originally encoded magnetism to be read. However, if a card is near an electromagnet at the instant it is turned on and/or off, the field can cause a sort of "scrambling" of the mag stripe making it pretty much unreadable. This last concept can be noted using standard cassette tapes and an electro-magnet. Put a cassette tape right next to an electro-magnet and turn it on and off a few times. Then put the tape in a player. You will hear all kinds of crackling and popping on the tape. If you had turned on the magnet, then gradually moved the tape to and away from the magnet several times, the tape would sound much "cleaner" - although in either case whatever was on the tape would be erased. :
Dec 16, 2008. 6:40 PMMaxxron says:
I had a magnet in my pocket that erased a hotel key card not too long ago. So if you are going to stay in a hotel with keycards, leave them out of a wallet with magnets built into it.
Feb 7, 2008. 3:13 PMTommi Potx says:
Absolutely Brilliant!!
Feb 26, 2009. 3:09 PMdaltonjcw says:
i must have heard you wrong, What?
Sep 1, 2008. 12:41 PMmastercreator says:
how did you get that decal on it. ps please look at my instructables im new here
Jul 8, 2008. 5:57 PMcdizzle says:
cool design what type of paint did u use
May 17, 2008. 12:40 AMJJrulz says:
lol, keeps things nice and quiet in the tin, that way they dont hear you coming untill its too late
May 13, 2008. 7:35 PMninjabob7 says:
Just don't put your cards in without giving them something to grab. They go in, but they don't come out no matter how much you whack the bottom of the tin.
Mar 5, 2008. 4:52 PMkeureban says:
How did you get the Rat Fink picture? Rat Fink is cool
Mar 1, 2008. 4:03 AMGjdj3 says:
Very cool. I think this looks way cooler than a duct tape wallet.
Aug 8, 2007. 12:25 AMKevvixx says:
I really like the paint and the decal. I'm gonna have to do that. Also I like the Plastidip idea.
Jul 22, 2007. 11:14 PMadamthiede says:
how to make an altoids tin wallet: 1) Take altoids tin 2) Stuff your booty inside 3) carry it around
Apr 27, 2007. 10:13 PMclimber_geek says:
I've seen a lot of really ugly wallets made from recycled stuff but this one looks good. The matte black paint and decal made all the difference. And the rubberized paint is a good idea. I will go paint all my altoids boxes now. I use them to store stuff but for me it is too hard and fat to use as an actual wallet.
May 12, 2007. 7:30 PMclimberslacker says:
climber geek, as you can see i climb to, were are you located. I would be glad to climb and geek w/ you. as always 31337
May 15, 2007. 9:44 PMclimber_geek says:
hello climberslacker, right now I'm in boulder, CO. What about you? Yes I do want to climb, hopefully I'll be able to accomplish more climbing than geeking this summer. Eldo, Boulder Canyon, RMNP!
May 16, 2007. 3:42 PMclimberslacker says:
uhh im in san diego, not far from j-tree.!!!!!! same about the summer bit
Apr 27, 2007. 8:09 PMCalltaker says:
GEnerally, as far as I know, only electromagnets are really an issue wtih mag strips, but then again, why take chances :) Nice instrucable. I think I may have to take this one and run a little. Need to get some more altoids :) ~C
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:merlin1974
