I know there are plenty of USB chargers out there for you to build. But here's one that doesn't use a voltage regulator or an IC chip to power it. The basic concept is to use 4 - AAA rechargeable batteries (1.2V a piece) to power the USB and a couple of solar cells to charge the batteries. If you've done the basic math you're probably wondering how 4.8V (4 x 1.2) is going to power a USB device which requires 5VDC. Well that's actually how I came up with the idea. I have another charger I made using a 9V battery and a 5V regulator. It will charge my iPod until the battery runs low. When I test the voltage output at the USB with a spent 9V, it will be spitting out 4.7V. So that's the cut off point. 4.8V is still within the tolerance for a USB device to charge. So I tried a 4-cell setup on my breadboard and it worked! I tested the voltage at the USB socket and (to my surprise) it was at 5.2V. I put my voltmeter on each battery and they were cranking out 1.3V at full charge. This is great! The tolerance of a USB happens to be just right for these four cells. So the solar part was sort of an afterthought for charging the batteries (they are rechargeable anyway).
If you'd like to try to make one yourself, here's what you need:
4 - AAA Battery Holder
USB Socket (female)
Solar Panel (3V output minimum, around 5V max)
Blocking Diode (not LED)
Some resistors (This is somewhat optional. You need them if you want your iPod/iPhone to recognize your charger. I'll explain exactly which ones to use later.)
DPDT Toggle Switch
Small Perf Board (Also optional)
Soldering Iron
myk
I am looking to have something that can charge my phone while i am outside but want it as small and light as possible. I figured if i removed the batteries i would just need to make sure i had enough power from the solar panels to come in and some sort of charge regulator right?
Thanks for the help.
http://www.instructables.com/id/Altoids-Smalls-Solar-Powered-USB-Charger/
Plz answer as soon as you can.
If you're paying $30 for an iPod cord, you haven't looked around much. I get them online for about $2.
try here: http://www.miniinthebox.com/cables_c4611?keyword=ipod+cable
I still wouldn't cut it unless it was broken anyway. If you need a female usb I found them somewhere for around $.25 a piece (+ shipping)
But if that's the way you are going I would say the best way to tell which wire is + or - would be the color. Ground (or -) is usually black and + is usually red. If you saw where they came off the cigarette charger, the outside part is ground and the tip of the charger is +. If all else fails you can use the trial and error approach.
I think that is about right. A BLACK WIRE came off of the SIDE of the board near the back (cigarette lighter end) and there was a METAL ROD that came off of the CENTER of that end (it is right after a resistor...i think...if those are labeled "R" 1) and that one was connected to a spring that was sticking out from the board. Any help is appreciated. If not, that's ok. Thanks
The black wire should be ground. The other wire is then positive. That is most likely a fuse and not a resistor between the tip and the spring.
Or you could just use the already-made circuit board with enough solar cells to power it. You would need another 4.5v solar cell in the series to do this. (13.5v total would not be enough to damage the circuit by the way). If your intention is to have the solar cells charge batteries that will operate the circuit than you can just adapt my design.
I hope this helped.
--- myk
myk@haikuordie.com
The blocking diode is really your choice. I would suggest using a germanium or Schottky diode because they have a low voltage drop. Any diode will do besides an LED.
