3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Altoids tin ipod case
in this instructable you will learn how to make an altoids tin in to a ipod case. this is my first one so please leve feedback on how to make better.
Step 1What you need
what you need
  • C:\Documents and Settings\Stephen\My Documents\My Pictures\053007_17161.jpg
  • C:\Documents and Settings\Stephen\My Documents\My Pictures\ipod_nano_2g_3.jpg
yoy will need
1. an ipod nano or anything else you can get to fit (ipod mini is to big) The 3rd gen ipod (short and fat) will fit in too, but you will have to change the way you cut the foam. the newest ipod may fit, but i haven't tried it.
2. A drill bit as big as the end of a pair of headphones and a drill.
3. Styrofoam(to pad the ipod nano)
4. duct tape
36 comments
Oct 5, 2011. 2:24 PMrushandroulette says:
great! but now i cant get my my ipod out o.o''
Nov 23, 2009. 6:21 PMMacaylastutorials says:
this is a really good idea, but the duct tape, thats the problem, duct tape doesnt look that great in it,and it can also damage your ipod, so I came up with a solution: buy thin memory foam, heat up a hot glue gun until its just hot enough to squirt the glue out, and put a layer of the foam on the top and bottom of your tin, this forms the shape of the ipod nicely too!
Oct 1, 2009. 7:01 PMbassclarinet23 says:
I made my own, which is slightly different. Mine has a clip, as well/
Sep 19, 2009. 10:08 PMhackysacker says:
you should make another one with speakers coming out the back. That would be pretty sweet
May 31, 2009. 5:33 AMRed Monkey says:
Expanding foam might make good padding. Just squeeze it in the tin, sit the ipod in it and trim when dry. You'd probably have to coat the ipod in something so it didn't stick to the foam though.
May 31, 2007. 10:51 AMrerat says:
Nice, it's a little sloppy though. A little more effort and you could have something much nicer looking. Here's one I made for my Z:M, before I discovered Instructables.
(does img code work here?)
[IMG]http://i51.photobucket.com/albums/f382/rerat15/DSCF5523.jpg[/IMG]
http://i51.photobucket.com/albums/f382/rerat15/DSCF5524.jpg
[IMG]http://i51.photobucket.com/albums/f382/rerat15/DSCF5521.jpg[/IMG]
Sep 28, 2008. 7:10 PMSolderguy says:
My first mp3 player was a 256 MB creative player. Ah, memories.
Aug 13, 2008. 3:37 PMDirt Rider says:
thats really nice
Apr 27, 2008. 5:10 PMPSPerson says:
that fabric is pretty creative (pun intended)
Sep 27, 2008. 7:25 PMmikaylad12344 says:
this is soo cool i think ill make one :)
Aug 13, 2008. 3:36 PMDirt Rider says:
i made somthing like this once but i lost my ipod so i cant use it lol
Aug 8, 2008. 7:49 AMItsTheHobbs says:
The new new one fits even better.
Aug 5, 2008. 9:24 AMRye2121 says:
i made mine with fabric instead of duct tape because it looks nicer. i also wrote the names of great bands on the top lid with all different colors of sharpie. it looks great!
Jul 16, 2008. 8:42 AMthe Mrs. says:
pretty good! next time check the spelling and stuff, because it can take away from the instructable, but otherwise it was fantastic...
Jun 15, 2008. 7:13 PMmason0190 says:
WOW i cant wait until they get one for the ipod classic >:(
Feb 20, 2008. 8:58 AMFireFairy-Jessica says:
Nice! I'll decorate mines with fabric.
Feb 16, 2008. 9:16 AMdrummonkey92 says:
its extremely hard to find altoids in the uk, but we have a time share in florida so wenever i go out on holiday, i buy masses of altoids in different size cases lol
Sep 21, 2007. 10:20 PMtheatre_tech_guru says:
there is a tape called gaffers tape that wont melt or leave residue on your ipod. i would use that
Dec 2, 2007. 10:46 AMcry_wolf says:
That is a very expensive tape, i used it a lot for audio and visual things at my school.
Nov 30, 2007. 5:11 PMConstructo Man says:
I fixed it. It looks awesome, and it was only a hack job loosely following ur instructions. GREAT INSTRUCTABLE! Anyway, here are some pics. They're backwards because I used a webcam to take them. BEHOLD, THE ITOIDS!
Nov 29, 2007. 10:43 PMConstructo Man says:
Mine came out terribly. I used a reamer to make the hole and the top and bottom of my ipod have the crap scratched out of them, even though I padded it with tape.
Jul 30, 2007. 4:35 PMthreecheersfornick says:
Just a thought... wouldn't the metal cut into the insulation on the headphone wire? You might want to pad that.
Nov 17, 2007. 11:24 AMjoebloggs27 says:
If you have a soldering iron you could use that to melt some rubber around the hole, I've tried it and it works really well
Nov 17, 2007. 12:25 PMthreecheersfornick says:
Hm, sounds good. Except my mp3 player just died. D':
Nov 3, 2007. 6:23 AMbuterSBob29 says:
I'm getting one of the new ipod nanos with video this Christmas
Nov 5, 2007. 2:01 PMYerboogieman says:
i'd just get an mp4 player from frys
Oct 31, 2007. 1:20 PM!Andrew_Modder! says:
Altoids tin ipod NANO case
Jun 15, 2007. 9:02 PMchatterbox14730 says:
Its a great idea, and i will use it, but not if my ipod gets gooey, that would be a downer.
May 30, 2007. 6:35 PMGreenDay says:
Errr... I did this with my creative and was meaning to get around to making an instructable out of it. Oh well... One of my suggestions would be to make the headphone jack hole slightly larger, and put a thin layer of styrofoam between it and the altoids tin. This insulates it from drops. You could also use expanding foam and just carve it out (or even have the i-pod in there with something like waxed paper on its back). I wouldn't use duct tape, because as thecheese says it 'll leave it gooey and nasty.
May 31, 2007. 6:25 AMGreenDay says:
I've got the zen micro. There's a enough room to fit it with a bit of styrofoam.
May 30, 2007. 10:09 PMjackfr0st says:
hmmm, i made one of these along time ago...maybe you saw it in my instructable!
May 30, 2007. 6:22 PMTheCheese9921 says:
duct tape will most likely make it gooey and nasty, I would use just use foam pretty nice
May 30, 2007. 6:32 PMadmanrocks says:
well original instructables are better
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:banknut
