A simple paper aeroplane became the most dangerous Instructable I've published for some time.
Seriously.
Remove these ads by
Signing UpStep 1Requirements & part 1 of Safety
I made this plane from an aluminium drinks can, using a heavy craft knife, scissors, a piece of scrap timber and a mallet.
There are serious risks during this Make, because the cut edges are very sharp. You may want to consider wearing gardening gloves to protect your hands, and make sure you know where your first aid kit is, because cuts from jagged metal can bleed quite profusely.
Steve
But first throw it in a hot fire for a few minutes before throwing if you happen to be aiming at people...
If you want to throw a hot-nosed plane, use a thin sheet of steel.
Steel would still burn you too, If you were to throw it with bare hands.
Sunshiine
Maybe soak fabric in PVA to make it stiff enough to hold the shape?
I was thinking the wing area would probably need to be expanded in proportion
to the weight ratio of the Al / Paper.
Intriguing concept, this one would drive me to try and try and try if I try it ;-D
A
If anybody else makes one, I hope they post a picture.
Just a thought - There's a lot of interest on the RC aircraft forums in Klein-Fogleman aerofoils, especially the KFM2 on smaller models. In its simplest form the KFM2 is a thicker section of wing for the first 40% of the chord which provides a low-pressure pocket behind the step and therefore, lift.
Quite easy to do on your tin can dart, Kiteman, and quite probably on paper aircraft (with OAE's skills).
