why am I making an instructable that many people have already done? well I thought it was an amazing Idea but I feel there was some room for better documentation, and a few little changes such as a lifting mechanism for the lid and no fire cement for the refractory.
Remove these ads by
Signing UpStep 1: What you need
What you will need for this project
13kg gas bottle (UK), I got mine from freecycle.org from someone who didn't need it any more, in the US they are 12.4kg
Bag of sand
Fire clay
1.5 inch screws
a short length of steel pipe
nuts and bolts
a short length of hose
Charcoal
cotton wool
tools
Angle Grinder with cutting discs and grinding discs
A file
Cordless drill and wire brush attachment
Arc Welder with 6013 rods (we find these rods easier to start and use with less sticking)
an outside tap
gas regulator if you're in the UK or you gas bottle doesn't have a tap
a steel rod if your gas bottle doesn't have a tap or you don't have a regulator
brush
rags for cleaning
marker pen
extension lead for working outside
hammer
some extra info on the gas bottles in the UK can be found here including their dimensions.
http://www.calor.co.uk/customer-services/faqs/general-cylinder-queries/
the bottle I'm using has the following dimensions
Propane: 13kg Patio Gas 580mm 315mm
Visit Our Store »
Go Pro Today »
the only time it would be an issue if the gas bottle was still sealed and i then started to heat it, your then looking as a pressure vessel which is dangerous, it would basically be a time bomb.
I found some at the above address. WS
Sadly, I lack the tools to build one myself but that doesn't mean I don't want one.
Incidentally, does anyone know where to easily find fire clay in the US? It doesn't seem to be an item carried by your average home improvement store (unless they have it listed under another name). I once built a forge from an old cast iron sink and have been interested in doing it again.
Look in Ceramics Monthly old editions (college library) for recipes. It is easy to make. Also refractory suppliers and ceramics stores will have it in stock. Not the low fire or 'artsy' stores, but a store that supplies clays and raw materials in bulk. look online or in the Yellow pages where you live.
Good luck,
Botnot
ps
(at random)
http://www.backyardmetalcasting.com/refractories.html
http://en.wikipedia.org/wiki/Fire_clay
http://www.artistpotters.com/anagama/castable.htm
http://www.traditionaloven.com/wwwboard/messages/3189.html
By the way, fire slowly at first. We 'candle', (very soft and low flame, sometimes overnight), until all of the H2O has dried out. Raid conversion to steam can burst off sections of the refractory, cause cracks, etc!!. We always fire slowly and progressively at first. The denser the castable, the slower we fire it. Most castables have the instructions on the package. Google is your friend!
Forgot to post that,
Thanks,
Botnot
I was very concerned though to read the description of how you began the modification of the gas cylinder. I am a former welding instructor having trained many apprentices and tradesmen over a number of years in NZ. I want to advise all instructable readers never to attempt to follow the same process to cut into a gas cylinder. Any attempt to modify an old cylinder in any way runs the risk of serious injury or death. I cannot stress this enough. There have been several incidents world wide where cylinders have exploded.
There is a much safer alternative for furnace bodies. I have made a number of successful furnaces and forges using the internal casing of old water heaters. These are about the same diameter of gas cylinders and are made from 3mm thick steel which can be cut very easily and completely safely using a cutting disc in an angle grinder. I have attached some photos.
Once again, a great instructable Chris but my advice is to never use old gas cylinders. You were very lucky.
Great project, and thanks for sharing to all,
Notbot
I have to agree though if i could have got hold of an old boiler this would have been safer, but i was working with what I had.
I have to admit I was crapping my self while i drilled it but I made sure the valve was depressed while i was drilling so i know there wasnt any pressure and i used the drill really really slowly to try and prevent sparks, i guess you could also run water over the area being drilled to prevent sparks.
Even running the drill slow there is a risk of explosion because the drill motor is constantly sparking.
If the afr is not correct there is little if any chance of an explosion.
If you had an air powered saw you could always cut it completely underwater.:)
We had a lot of problems with crucibles burning out the bottom. On the third try we used a small oxygen tank that we cut the top off of and it worked great.
http://castboolits.gunloads.com/showthread.php?t=79594
(p.s. I'm not British, I'm Australian)
It seemed like in the test pour video, that the aluminum was kinda jello-ish. I always understood it to be watery when melted. what about that?
