Aluminium Casting Foundry
 by n1cod3mus
Contest WinnerFeatured
Making a foundry for melting aluminium (Aluminum for the US) out of a 13kg propane gas bottle
why am I making an instructable that many people have already done? well I thought it was an amazing Idea but I feel there was some room for better documentation, and a few little changes such as a lifting mechanism for the lid and no fire cement for the refractory.
Step 1: What you need
SAFETY NOTE: messing about with gas bottles or pressurized containers is very dangerous, do this at your own risk, but if you do decide to do it be safe, use your head, think about everything you do before you attempt to do anything. I have put in some tips as to what I have done in each step.
What you will need for this project
13kg gas bottle (UK), I got mine from freecycle.org from someone who didn't need it any more, in the US they are 12.4kg
Bag of sand
Fire clay
1.5 inch screws
a short length of steel pipe
nuts and bolts
a short length of hose
Charcoal
cotton wool
tools
Angle Grinder with cutting discs and grinding discs
A file
Cordless drill and wire brush attachment
Arc Welder with 6013 rods (we find these rods easier to start and use with less sticking)
an outside tap
gas regulator if you're in the UK or you gas bottle doesn't have a tap
a steel rod if your gas bottle doesn't have a tap or you don't have a regulator
brush
rags for cleaning
marker pen
extension lead for working outside
hammer
some extra info on the gas bottles in the UK can be found here including their dimensions.
http://www.calor.co.uk/customer-services/faqs/general-cylinder-queries/
the bottle I'm using has the following dimensions
Propane: 13kg Patio Gas 580mm 315mm
Step 2: Empty the tank
CAUTION: you are dealing with a pressurised container with flammable gas inside it
using your brush, brush any dirt or cobwebs off the bottle.
You need to make sure the bottle is empty, this bottle had a gauge on it which showed it to be empty but the weight of the bottle felt like it still had gas in it, and if you shook it you could hear the gas slosh around.
so i need to empty it, if you have a regulator or a bottle with a tap on it you can use this to empty it as far as you can, I would suggest you use the gas and not waste it if you can.
I didn't have a regulator and nothing that uses bottled gas so I have to vent it
WARNING: remember this is a pressurized container when you release the pressure it will change the pressure around you which can burst your ear drums, put cotton wool in your ears to protect them. also ensure you are in open space outside without ignition sources around, this could be anything that could make a spark or a flame.
I pushed my steel rod in to the top of the valve and pressed down, this released gas quickly, it slowed down as the gas got colder during the exchange process.
while I was doing this the air became saturated with propane which made me feel very dizzy so I wedged the bar under the handle of my shed.
once the gas slowed down I had a little fun, this you should never do, I ignited the gas, this was a very stupid thing to do, DO NOT DO IT, I videoed it so you don't have to.
the bottle got so cold ice formed on the outside of the bottle so much so that I could write in it.
you need to leave it for a long as possible, even when you can't hear gas escaping it may still be coming out, I would leave it over night with the bar in or the valve open if you have a tap or regulator.
I left my bottle for a few days after I emptied the gas out, when I pushed the bar back in it hissed, this was caused because of temperature changes.
at this point the bottle is NOT EMPTY it still has enough gas to give a fair bang, be careful.
now you need to have the valve open or the bar wedged in, then using your cordless drill or a hand drill, drill two small hole about 4mm in diameter. When I did this I was standing to the side just in case and I had the drill running slowly.
now you need to make the holes bigger, I only had a drill bit that was about 12mm. the two holes are to allow water in one and gas out the other.
using your pipe fill the bottle with water until water comes out of the other hole.
and guess what, it's still not empty there's still a little gas left at the top, I emptied half the water out then using a cooker lighter and keeping well back I ignited the remaining gas, it raged like a jet for a brief second, scared the life out of me.
leave the bottle half full of water this will help to weigh it down while you cut the top off.
Step 3: Chop the top off
Originally I was going to remove the valve before I started this part but I had trouble getting a spanner around it as there is a safety valve on one side and the gauge on the other, I pulled the gauge off with pliers but it had a long brass section sticking out which got in the way. on the other 2 sides was the handle.
If you can get a spanner around your valve I would recommend heating the bottle where the valve connects, they seal these valves with a liquid weld which will return to liquid when heated up, this will make it a little easier to get off. I would also recommend using a length of steel pipe on your spanner to give you extra leverage.
ok back to the cutting, you need to allow enough on the top of the bottle for about 2 inches of refractory, I measured up 5 and a half inches from the top of the centre seem and marked them with a mark pen.
cut along the marked line using your angle grinder with a cutting disc, I managed to con my brother in to doing most of the work for me while I cooked him dinner ;-)
once the top has been cut off grind off the sharp edges with a grinding disc
here is by brother grinding the sharp edges off.
Step 4: Handle and vent
ok now cut the handle off close to the top of the bottle, you may have to hold the top down with your foot while you do this, be careful not to cut your toes off.
grind off the sharp edges and any excess metal left on the bottle.
mark out the hole for the vent and then cut this out with the angle grinder as well. Circle is 8cm in diameter and will be formed in the refractory later on, now all we need is a easy to cut hole so I put a square around it slightly larger which should help later on so the steel of the bottle doesn't heat up too much when the foundry is running.
place the handle in its position and put a spot weld it to hold it in place, now use your cordless drill with the wire brush to get rid of the paint around where we need to weld this will make it much easier to do, it is possible to do it with the paint in place if you start on a place without any but it's easier and you get a stronger and cleaner weld if you remove the paint first. use a hammer to get rid of the slag from the weld and make sure it's a good weld.
its worth noting at this point that if you won't have a welder you could just drill holes and use a bracket and some screws or bolts to place the handle. I don't have a welder  but my brother was here to do some welding on my car so I got him to weld the handle for me.
I had some concerns that the handle might heat up so I cut it at an angle to try and keep as much steel out of the way of the vent as I could.
I marked a rough angle by hand and started cutting, then ground the cut using the angle grinder to remove the sharp edges.
here is a really short video of my brother welding.
Step 5: Preparing for the refactory
we need to prepare the gas bottle for the refractory, we will need to put screws in to hold the refractory in place once it has dried.
turn the body of the gas bottle on its side and drill 3 holes in a line up the gas bottle, the first one near the bottom should be higher than the level the refractory will be, which is 2 inches thick so you want your first hole to be a bit higher up than that. also make sure your centre hole should be above the weld line.
do this all the way around the gas bottle, I have lined mine up with where the base connects to the body.
then you need to counter sink those holes to reduce the amount of screw head that sticks out.
then screw all the screws
you will need to repeat this with the lid, make sure you don't put them too close to the edge as they will end up sticking up above the refractory. you will also have to put some in the lid pointing down.
now we have the problem of holding in the refractory within the lid so it doesn't fall out, we will do this with some wire, making a web by wrapping wire around the screws, making sure we leave a void in the middle which will become our vent later on.
I wrapped the wire from the outer screws and down to the lower screws to create triangles, then all around the top screws in a circle, and then across from one top screw to the opposite one, all of this will reinforce the lid and hold it in place.
Step 6: Lifting pedel
I thought about adding a hinge to the back but I thought it might not be wise as this may encourage me to reach over the hot furnace so I decided on a method where I could swing the lid off to the side.
I also didn't want to have to lift the lid by hand as this would be clumsy so I thought I would make a foot pedal to lift the lid and then I could use the handle to pull it aside keeping my hands and arms well away from the fire avoiding accidents.
So the first thing I needed to is create a frame for the pedal and lifting plate, I managed to salvage some metal that used to be racking that my next door neighbour had thrown out which is ideal for what I need.
I cut 2 lengths the width of the gas bottle plus the width x 2 of the metal I am using, and another 2 which are slightly longer to allow for movement.
I bolted these together to form a square frame, the rear of the frame i mounted upside down so there is a lip to hold the pole I am going to use to lift the lid.
I then drilled holes in the base of the gas bottle and bolted the frame to it so I had more of the frame towards the front.
Step 7: Air Inlet (the tuyere)
I needed to cut a hole for the air inlet pipe (the tuyere), this should be slightly higher than the level where the refractory will go.
I first started using a hole cutter drill bit to cut the hole, without reading the packet, I blunted the bit as it was only for light metal use so I switched to the angle grinder. the hole was cut off centre so it was towards the back of the gas bottle, the purpose is so that when air is pushed in it will circulate around the inside.
I had some pipe in the pile of junk which I cut at an angle so it would be flusher to the refractory lining, and cut it to length.
I brushed both the pipe and the gas bottle ready to weld
Step 8: Lifting pole and brackets
I would be using the same pole that I used for the air inlet to make the lifter and the brackets.
using the angle grinder I cut a slit down the length of the pipe and then cut 3 pieces to about 3 inches long, 2 for the main body of the gas bottle and one for the lid.
using a file I make sure there wasn't any sharp bits, then pulled them open slightly to allow a piece of the same pipe to fit inside them.
Step 9: Finishing the Lid and Welding the Air Inlet
I welded the air inlet pipe all the way round so there's no air holes.
Welding the brackets was tricky as the pipe I was using was thin walled but I managed to pool the weld between the pipe and the gas bottle.
The original plan was to weld a cap on the top of the bracket that was attached to the lid so the pipe at the back would be loose inside but would lift the lid, this didn't work as expected and only lifted the back of the lid, I then inserted a larger pole and welded that to the bracket and lid, this worked much better. I also cut the rear pipe to the height of the handle, this will help later with the refractory mix when we ram it in the lid.
this is the first time I have used an arc welder so my welds are not too pretty but they hold up, I will get better with more practice.
Here is a video of the lift mechanism working.
Step 10: Testing the refactory
I wanted to make sure the refractory mix I intended to use would work correctly before I mixed up a big batch and wasted a load of fire clay.
The mix I will be using is the same as what David Gingery specified in his book about making a home foundry.
2 Parts Sand
1 Part Fire Clay
Measured by volume not weight.
here is a video of the test I did, I made up the mix and rammed it in to a large tin (originally for baby milk, in the US it's about the same size as a coffee tin) so I basically made a mini furnace. Using my girlfriends hair dryer for blowing air in the inlet.
so by the colour of the glow on the tin I can assume that I was getting between 800 - 900 degrees C aluminium melts at around 660 degrees C so it looks like the charcoal furnace will be Ideal.
In the video I say the top is crumbly, it turns out it was just a little sand dust, and it was solid enough.
Step 11: Making the inner mould
we need to work out what the diameter of the inner mould should be to do this I take the diameter of the gas bottle and minus off twice the width I want the refractory to be which is 5cm twice that is 10cm the width of the gas bottle is 31.5cm so our inner mould needs to be a 21.5 cm in diameter.
On a scrap of wood or board draw a circle with a diameter of 21.5cm and draw 2 D shapes on the inside of the circle which will form a handle in the middle of the circle.
drill holes in the points of the D's, use the holes to start the jig saw and cut out the 2 D's then cut out the circle.
You need to make 2 of these so just trace round the original and cut it out in the same way, I cut out 3 with the intention of using one in the centre section, I was originally trying not to use a sheet of metal but my attempts at using hard board failed so I reverted back to having to use the metal to form the outside of the mould.
Now it's important when working with sheet metal to wear gloves, I got over excited and forgot this and took a chunk out of my finger which bled through the plaster I put on it. :-( see the picture as a reminder to wear gloves.
what you need to do is wrap the metal around the 2 wooden forms, using duct tape to hold it while you roll it, this requires a fair bit of strength depending on the thickness of the metal your using.
The idea of this mould is It's suppose to be collapsible so it can be removed without damaging the refractory, according to David Gingery's book on making a home foundry, we shall see.
Step 12: Mixing and ramming the refactory
the refractory is mixed in a ratio of 2 parts sand 1 part fire clay by volume.
Using a small bucket measure out your ingredients in to a mixing container and mix them together, your aiming for the sand and clay to clump together when squeezed but not be wet or sticky, it shouldn't stick to your hand and it should break cleanly.
shovel some of the mix in to the bottom of the gas bottle and ram it down using a piece of wood, you need to make sure you ram this very hard and get all the air out you can. You need to do this until the bottom is to the level of the bottom of the air inlet pipe, and fairly level.
I started this with the screws still in place but they seemed to be getting in the way so I took them out and as the refractory got over there level I put them back in.
Place the inner mould in the gas bottle and try and get it as centred as possible.
using a garden trowel put some mix in around the mould and ram it down, you may want to use a hammer to tap the wooden ram to make sure it's packed in tight. you want to build up the outer wall in layers don't just fill it up then ram it do it in parts until you reach to top.
if at any point you wish to stop, I stopped because it was late in the evening, cover your work with foil to keep the moisture in you don't want it to dry out until you're ready to fire your mix.
the flash on the camera has made my sand look yellow, it's not yellow it's actually a red / orange colour.
for the lid I put duct tape over the hole and popped a brick under the hole, using a postal tube as a hole mould I then rammed as much as I could in to the lid. to remove the postal tube just slowly twist it and pull gently upwards as you do.
Step 13: Removing the inner mould and firing
to remove the inner mould cut the duct tape off the top and remove the wooden spacer do the same at the bottom, cut the duct tape on the side.
You will have to squeeze the metal cylinder to part it from the side and carefully lift it out, this might be a little tricky and will need a little strength.
ok now comes the final bit, this will take some time, you need to start a fire in it, you can do this with charcoal and lighting fluid like a BBQ, I just put some newspaper and the scraps of wood from cutting out the wooden spacers I also broken up and put the spacers in.
you just want to have a fire in it for now, do not start the hair dryer through the air inlet, you want the refractory to dry out gradually if you heat it too fast the steam will blow out bits of the refractory and you will get large cracks. You might get a few cracks in your refractory but that's ok they shouldn't be too big.
Run it for a couple of hours without extra air and without the lid on, we need to harden the lining of the bottom section first. then put the lid upside down on top, this will stop the refractory just falling out and the heat from the fire will help harden the lid.
now you can put your hair dryer on through the air inlet on low power, once the lid has dried out enough, put it on the furnace properly and leave it for about half an hour with low power on the hair dryer then turn it up for a few hours, the lining should glow.
here is a video safety tip for when your firing your refractory.
here is a video I did while firing the refractory.
video showing the refractory glowing
Step 14: Test melt
I used a tin can as a crucible, this was only for one melt, it wouldn't be suitable for every melt tin cans tend to burn through.
I had a couple of scrap pieces for the test, some off cuts of rod and rails, a coke can, an ornament and some other little bits.
once all the bits had melted I left it a little while to get hotter so it wouldn't just cool in the crucible, unfortunately I hadn't considered the ground being cold so some of the metal started to set in the bottom which made me put down the camera.
I managed to cast 2 ingots from what I had, it would have been 3 had the metal not started to cool in the bottom of the can, but the point is that it works.
from these tests I have concluded that best fuel would if you're using charcoal like I am then the briquettes are the best to use, the lump wood charcoal  produced a lot of sparks. You could of course use propane if you made a burner.
here is a video of the melt and the pour.
1-40 of 50Next »
blenz says: Jul 19, 2012. 10:21 PM
It is pretty funny reading all of the posts talking about how dangerous this all is. A couple of years ago the city had to change the supply tap from the main gas line to my house. Anything with these lines has to be welded, but they don't shut down the gas main. They drilled a hole into the main and lit it on fire until he was ready to weld in the new tap! For the old supply tap he did the same after he hammered in a steel plug! the entire time he was welding a 2 foot tall jet of flame was searing the cold February air. When it was all done he checked for leaks, you guessed it by playing his lit welding torch over all of the repair areas. So lets just all agree that "dangerous" is a relative term :)
firesirt in reply to blenzAug 17, 2012. 7:00 PM
If you think about it, you need oxygen for propane to burn, so it really isn't dangerous until it is well mixed with air.
AJMansfield in reply to firesirtAug 21, 2012. 10:47 AM
The only real risk is that the additional heat from welding the tank could cause the tank to rupture (from increased pressure), and spill out gas fast enough for the flame jet to travel far enough from the container to damage stuff (like yourself). Generally, its really only dangerous if the burst of flame is unexpected.
n1cod3mus (author) in reply to AJMansfieldSep 10, 2012. 4:06 PM
that couldnt happen as I drilled 2 holes in the top and emptied the gas out of it, by the time I came to welding it the top had been cut off.
the only time it would be an issue if the gas bottle was still sealed and i then started to heat it, your then looking as a pressure vessel which is dangerous, it would basically be a time bomb.
murban1 says: Sep 5, 2012. 8:07 AM
Here in the USA if you go to your local propane suppler and ask for a bottle that is no longer certifiable and tell them it is for a special project often they will often give it to you for nothing. Saves them the cost of having to dispose it.
Bald2 says: Jul 19, 2012. 8:10 PM
In the past I have had to repair by brazing the odd car gas tank. I think this dangerous operation can be made a lot safer by dropping a few chucks of dry-ice in the tank and leave one vent hole opened and let the CO2 purge bit before you start. With that in place my hand doesn't shake nearly as bad with the torch.
n1cod3mus (author) in reply to Bald2Jul 20, 2012. 4:19 PM
dry Ice is harder to come by in the UK
blenz in reply to n1cod3musAug 18, 2012. 4:43 AM
Really!? Why have they made it hard to find? (No criticism just plain curiosity :)
n1cod3mus (author) in reply to blenzAug 18, 2012. 3:06 PM
its not avaliable in supermarkets here, it would take a while to source it
blenz in reply to n1cod3musAug 18, 2012. 8:18 PM
I'm sorry to hear that, If I could I would ship you a whole carton of the stuff! Thanks for the 'ible by the way I hope I get a chance to try it this winter.
WareShoals says: Jul 29, 2012. 5:58 PM
Great instructable. For those of you looking for fire clay check out ebay: http://www.ebay.com/itm/Super-32-Refractory-Mortar-50-pound-container-/130470068688?pt=LH_DefaultDomain_0&hash=item1e609f41d0
I found some at the above address. WS
Nirgal38 says: Jul 19, 2012. 9:36 AM
Wonderfully detailed and well documented from beginning to end. That's the way all 'ibles should be.
Sadly, I lack the tools to build one myself but that doesn't mean I don't want one.
Incidentally, does anyone know where to easily find fire clay in the US? It doesn't seem to be an item carried by your average home improvement store (unless they have it listed under another name). I once built a forge from an old cast iron sink and have been interested in doing it again.
botnot in reply to Nirgal38Jul 21, 2012. 1:06 PM
Hi,
Look in Ceramics Monthly old editions (college library) for recipes. It is easy to make. Also refractory suppliers and ceramics stores will have it in stock. Not the low fire or 'artsy' stores, but a store that supplies clays and raw materials in bulk. look online or in the Yellow pages where you live.
Good luck,
Botnot
ps
(at random)
http://www.backyardmetalcasting.com/refractories.html
http://en.wikipedia.org/wiki/Fire_clay
http://www.artistpotters.com/anagama/castable.htm
http://www.traditionaloven.com/wwwboard/messages/3189.html
botnot in reply to botnotJul 21, 2012. 1:21 PM
If unable to find fireclay, you can use Aluminum Oxide, [alumina]. It’s works really well. Sand blasting companies use Alumina and sometimes throw it away.
By the way, fire slowly at first. We 'candle', (very soft and low flame, sometimes overnight), until all of the H2O has dried out. Raid conversion to steam can burst off sections of the refractory, cause cracks, etc!!. We always fire slowly and progressively at first. The denser the castable, the slower we fire it. Most castables have the instructions on the package. Google is your friend!
Forgot to post that,
Thanks,
Botnot
n1cod3mus (author) in reply to Nirgal38Jul 20, 2012. 4:18 PM
you could try pottery of ceramic suppliers, I got mine on ebay but im in the UK, if anyone else is in the UK clayman supplies do fireclay sometimes
weldor in reply to Nirgal38Jul 19, 2012. 11:45 AM
Call a furnace or a boiler repair company. You may also find it at a local ceramics supply store.
Kiwi 2 says: Jul 19, 2012. 11:31 PM
Very well written and you have made a good job of the little furnace.
I was very concerned though to read the description of how you began the modification of the gas cylinder. I am a former welding instructor having trained many apprentices and tradesmen over a number of years in NZ. I want to advise all instructable readers never to attempt to follow the same process to cut into a gas cylinder. Any attempt to modify an old cylinder in any way runs the risk of serious injury or death. I cannot stress this enough. There have been several incidents world wide where cylinders have exploded.
There is a much safer alternative for furnace bodies. I have made a number of successful furnaces and forges using the internal casing of old water heaters. These are about the same diameter of gas cylinders and are made from 3mm thick steel which can be cut very easily and completely safely using a cutting disc in an angle grinder. I have attached some photos.
Once again, a great instructable Chris but my advice is to never use old gas cylinders. You were very lucky.
botnot in reply to Kiwi 2Jul 21, 2012. 12:52 PM
Nice work! I spent a long time building offhand glassblowing equipment. 'Sometimes' the layer of glass on the inside of water heater casings can vitrify at higher temps and begin to degrade the castable lining from the back. INot to say that it will cause cause problems, but it can.
Great project, and thanks for sharing to all,
Notbot
n1cod3mus (author) in reply to Kiwi 2Jul 20, 2012. 4:21 PM
the gas bottle was empty, with no pressure, I drilled 2 holes using a battery operated drill, I would have used a manual hand drill if I had one, I did this slowly, then filled it with water to get rid of the gas which worked. no big bang.
I have to agree though if i could have got hold of an old boiler this would have been safer, but i was working with what I had.
AJMansfield in reply to n1cod3musAug 21, 2012. 10:50 AM
Which is almost EXACTLY the procedure used for industrial construction that is used before welding a tank like that. The only real difference is that they would leave the tank's walls intact, and use the tanks own valves instead.
n1cod3mus (author) in reply to AJMansfieldSep 10, 2012. 4:00 PM
the valves on the UK tanks are one way and you need a regulator to use them, unlike the US tanks which seem to come with a tap attached.
I have to admit I was crapping my self while i drilled it but I made sure the valve was depressed while i was drilling so i know there wasnt any pressure and i used the drill really really slowly to try and prevent sparks, i guess you could also run water over the area being drilled to prevent sparks.
Thoth says: Jul 19, 2012. 10:22 AM
Couldn't you have used a wrench (spanner in the UK) just to remove the entire valve assembly, which would have made emptying out the gas much easier and safer?
Even running the drill slow there is a risk of explosion because the drill motor is constantly sparking.
n1cod3mus (author) in reply to ThothJul 20, 2012. 4:23 PM
I wanted to do this but on one side is a safty valve which got in the way, and the other side was a level gauge which was in the way. but to get it out you have to melt the liquid weld they use on the valves and this is best done with heat, not a good idea with a gas bottle
weldor in reply to ThothJul 19, 2012. 11:44 AM
They are instaled with some sort of a locking sealer. I use my recipricating saw to cut off the valve. If you are concerned about the spark/gas thing turn a garden hose on the saw blade to basically seal the cut and you should be fine.
loopingz in reply to weldorJul 20, 2012. 9:33 AM
I would be scared a this point, because on very low gas just some air inside would make some good explosion ratio...
weldor in reply to loopingzJul 23, 2012. 12:03 PM
for ignition of lpg or propane type fuels you need somewhere in the vicinity of a 14to1 air fuel ratio. That is where the water comes in. As I said before, it seals the air out and keeps what little trace gas is left in the bottle in the bottle. I ALWAYS bleed the bottle to zero psi and let it sit with the drain/bleed plug opend or removed over night before I ever start cutting.
If the afr is not correct there is little if any chance of an explosion.
If you had an air powered saw you could always cut it completely underwater.:)
n1cod3mus (author) in reply to loopingzJul 20, 2012. 4:25 PM
the most likely out come would be a jet flame until the air got enough inside the bottle to ignite and then it would eat up the oxygen and just raw out of the holes like a jet engine. if anyone has seen those jam jar jet engines its the same just a lot scarier lol.
bg_askins says: Jul 20, 2012. 8:04 AM
i take my empty tanks to the local propane company and have them purged with argon for $5
n1cod3mus (author) in reply to bg_askinsJul 20, 2012. 4:21 PM
good advice
radarguy says: Jul 19, 2012. 5:49 PM
This is SUPER SUPER DANGEROUS! Please recommend against this. Unless you can remove the valve and flush the remaining gas out before grinding you have a potential bomb!
n1cod3mus (author) in reply to radarguyJul 20, 2012. 4:18 PM
which is what I did, flushed it out with water
thisisradionick says: Jul 19, 2012. 7:55 AM
I have been working on a foundry with some people. http://www.hammerspacehobby.com/2012/05/flower-pot-foundry-test-run.html
We had a lot of problems with crucibles burning out the bottom. On the third try we used a small oxygen tank that we cut the top off of and it worked great.
n1cod3mus (author) in reply to thisisradionickJul 20, 2012. 4:16 PM
i'm in the process of writing an instructable on making your own ceramic crucibles, sort of following Vince Gingerys method in his book, but my own way as i dont have a wood lathe yet.
tatagatha says: Jul 19, 2012. 7:28 AM
I made a charcoal furnace last summer. I had a really hard time keeping the temperature consistent. Have you had issues with it swinging wildly? Maybe my refractory was poor. I've made an electric one this summer, but havent fired it up yet... yet! I'm hoping it will be more consistent and the electric radiant heat to be gentler on the crucible. Also, if you are first making ignots from known alloys, check out this little tip:
http://castboolits.gunloads.com/showthread.php?t=79594
n1cod3mus (author) in reply to tatagathaJul 20, 2012. 4:14 PM
havnt had an issue, but then I have no method of measuring the temp, but it melts the aluminium and keeps it molten
loafers says: Jul 19, 2012. 9:42 AM
Bloody good job mate, brilliant instructible with with both a great outcome and documentation. You even used the better spelling of Aluminium haha, the word Aluminum urks me for some reason (not meaning to offend the American English speaking population, ours probably urks you guys). I reckon I should give that a go, a real ripper that is.
(p.s. I'm not British, I'm Australian)
pedalmonkey says: Jul 16, 2012. 6:00 PM
Don't feel bad that you haven't gotten many hits yet. Give it some time. There have been a few other furnaces on here that were similar but this is probably the best I've yet seen . Good job on the ible!
n1cod3mus (author) in reply to pedalmonkeyJul 17, 2012. 5:13 AM
thanks for the compliment
heathbar64 says: Jul 17, 2012. 4:07 AM
Nicely done! plenty of details as if you really expected us to build one from your ible. I've always meant to cast aluminum, and maybe this will motivate me to actually do it.
It seemed like in the test pour video, that the aluminum was kinda jello-ish. I always understood it to be watery when melted. what about that?
n1cod3mus (author) in reply to heathbar64Jul 17, 2012. 5:02 AM
also you have to bear in mind that the surface tension would be different than water, hence why it sort of domed in the pan.
1-40 of 50Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
