loading
Step 6: Lifting pedel
I thought about adding a hinge to the back but I thought it might not be wise as this may encourage me to reach over the hot furnace so I decided on a method where I could swing the lid off to the side.
I also didn't want to have to lift the lid by hand as this would be clumsy so I thought I would make a foot pedal to lift the lid and then I could use the handle to pull it aside keeping my hands and arms well away from the fire avoiding accidents.
So the first thing I needed to is create a frame for the pedal and lifting plate, I managed to salvage some metal that used to be racking that my next door neighbour had thrown out which is ideal for what I need.
I cut 2 lengths the width of the gas bottle plus the width x 2 of the metal I am using, and another 2 which are slightly longer to allow for movement.
I bolted these together to form a square frame, the rear of the frame i mounted upside down so there is a lip to hold the pole I am going to use to lift the lid.
I then drilled holes in the base of the gas bottle and bolted the frame to it so I had more of the frame towards the front.
I was brickies mortor to make the insulation. I may have made a mistake. Can anyone help? Perhaps I will need to start again. I am worried about it exploding! I also used an air compressor to push the air in. Perhaps this will lead to disaster also?
the air compressor should be ok for the air, but the mortor might be an issue, concrete does have a tendency to explode when heated if there are air or water bubbles in it. I would redo the refractory if you can just for safety.
This is SUPER SUPER DANGEROUS! Please recommend against this. Unless you can remove the valve and flush the remaining gas out before grinding you have a potential bomb!
<p>Although I would recommend against cutting it without flushing it out, it is not actually all that dangerous. I cut open an old propane tank a ways back and the sparks from the grinder ignited the propane. Instead of an explosion it simply made a whooshing sound as a blue flame jetted from the slot I had made with the grinder.</p>
which is what I did, flushed it out with water
It is pretty funny reading all of the posts talking about how dangerous this all is. A couple of years ago the city had to change the supply tap from the main gas line to my house. Anything with these lines has to be welded, but they don't shut down the gas main. They drilled a hole into the main and lit it on fire until he was ready to weld in the new tap! For the old supply tap he did the same after he hammered in a steel plug! the entire time he was welding a 2 foot tall jet of flame was searing the cold February air. When it was all done he checked for leaks, you guessed it by playing his lit welding torch over all of the repair areas. So lets just all agree that &quot;dangerous&quot; is a relative term :)
i worked a survey job on a main gass line running east west across the US and the pipe being several feet tall they were attaching a few foot tall pipe to that exactly how they did it, literally welded a pipe tap onto an active main gas line. its all in the techique and how safe and careful you are. needless to say there have been alot of deaths by normal people without training that cut into and welded to propane tanks and blew themselves up. just be incredibly careful
If you think about it, you need oxygen for propane to burn, so it really isn't dangerous until it is well mixed with air.
I believe the gas has to be around 7% compared to the amount of air for optimal ignition
<p>Exactly. Which is why gas cylinders are so safe. There is an interesting mythbusters episode on this</p>
The only real risk is that the additional heat from welding the tank could cause the tank to rupture (from increased pressure), and spill out gas fast enough for the flame jet to travel far enough from the container to damage stuff (like yourself). Generally, its really only dangerous if the burst of flame is unexpected.
that couldnt happen as I drilled 2 holes in the top and emptied the gas out of it, by the time I came to welding it the top had been cut off. <br> <br>the only time it would be an issue if the gas bottle was still sealed and i then started to heat it, your then looking as a pressure vessel which is dangerous, it would basically be a time bomb.
<p>This is a great instrtuctable, and sorry for tooo late post, but I just want to say thankyou for this great y very well illustred instructions, N1cod3mus !!!!!!!<br><br>Some pics of my results :</p>
https://www.instructables.com/id/Forge-Furnace-Propane-Jet-Burner/
nice furnace, glad my instructable helped, I am going to build a new one as I had to ditch mine when I moved house. I will be running the next one on propane I have made the burner already which there is an instructable for.
Wonderfully detailed and well documented from beginning to end. That's the way all 'ibles should be. <br> <br>Sadly, I lack the tools to build one myself but that doesn't mean I don't want one. <br> <br>Incidentally, does anyone know where to easily find fire clay in the US? It doesn't seem to be an item carried by your average home improvement store (unless they have it listed under another name). I once built a forge from an old cast iron sink and have been interested in doing it again.
Sodium silicate (aka to us old timers as 'water glass') and vermiculite mixed into a thick slurry. Slowly heat to 200 deg F. Tbe Sod. Sil turns to glass. If you drill holes and use a screw through the hole (secured by the nut) as an anchor point for stainless wire strung like a 'net' to help the slurry stay in place. You can use safety wire or mig wire. Stainless will not rot away and is quite resistant to heat as well
Hi, <br>Look in Ceramics Monthly old editions (college library) for recipes. It is easy to make. Also refractory suppliers and ceramics stores will have it in stock. Not the low fire or 'artsy' stores, but a store that supplies clays and raw materials in bulk. look online or in the Yellow pages where you live. <br>Good luck, <br>Botnot <br>ps <br>(at random) <br>http://www.backyardmetalcasting.com/refractories.html <br>http://en.wikipedia.org/wiki/Fire_clay <br>http://www.artistpotters.com/anagama/castable.htm <br>http://www.traditionaloven.com/wwwboard/messages/3189.html
If unable to find fireclay, you can use Aluminum Oxide, [alumina]. It&rsquo;s works really well. Sand blasting companies use Alumina and sometimes throw it away. <br> <br>By the way, fire slowly at first. We 'candle', (very soft and low flame, sometimes overnight), until all of the H2O has dried out. Raid conversion to steam can burst off sections of the refractory, cause cracks, etc!!. We always fire slowly and progressively at first. The denser the castable, the slower we fire it. Most castables have the instructions on the package. Google is your friend! <br>Forgot to post that, <br>Thanks, <br>Botnot <br>
you could try pottery of ceramic suppliers, I got mine on ebay but im in the UK, if anyone else is in the UK clayman supplies do fireclay sometimes
Call a furnace or a boiler repair company. You may also find it at a local ceramics supply store.
After much research your instructable was the most detailed and well written. I've built a foundry in a similar style using a small oil drum instead of a gas tank, which is slightly larger. I used the same recipe for the refractory and in doing the curing fire a vertical crack has developed in one side (probably from drying it too quickly). It's a little less than an eighth of an inch thick, but runs a third of the inner height. Do you think it'll significantly affect the foundry?
it will probably be ok, you could use some fire cement to plug it.
Very well written and you have made a good job of the little furnace. <br> <br>I was very concerned though to read the description of how you began the modification of the gas cylinder. I am a former welding instructor having trained many apprentices and tradesmen over a number of years in NZ. I want to advise all instructable readers never to attempt to follow the same process to cut into a gas cylinder. Any attempt to modify an old cylinder in any way runs the risk of serious injury or death. I cannot stress this enough. There have been several incidents world wide where cylinders have exploded. <br> <br>There is a much safer alternative for furnace bodies. I have made a number of successful furnaces and forges using the internal casing of old water heaters. These are about the same diameter of gas cylinders and are made from 3mm thick steel which can be cut very easily and completely safely using a cutting disc in an angle grinder. I have attached some photos. <br> <br>Once again, a great instructable Chris but my advice is to never use old gas cylinders. You were very lucky. <br> <br>
the gas bottle was empty, with no pressure, I drilled 2 holes using a battery operated drill, I would have used a manual hand drill if I had one, I did this slowly, then filled it with water to get rid of the gas which worked. no big bang. <br> <br>I have to agree though if i could have got hold of an old boiler this would have been safer, but i was working with what I had.
<p>It is not at all safe to drill holes even if you think there is no pressure. A minute amount of gas + plenty of oxygen + spark from drill bit = explosion. Filling totally with water means no oxygen = no explosion possible. Under any circumstance - unless somehow air can be trapped under the water, and the spark can reach it.</p>
Which is almost EXACTLY the procedure used for industrial construction that is used before welding a tank like that. The only real difference is that they would leave the tank's walls intact, and use the tanks own valves instead.
the valves on the UK tanks are one way and you need a regulator to use them, unlike the US tanks which seem to come with a tap attached. <br> <br>I have to admit I was crapping my self while i drilled it but I made sure the valve was depressed while i was drilling so i know there wasnt any pressure and i used the drill really really slowly to try and prevent sparks, i guess you could also run water over the area being drilled to prevent sparks.
Nice work! I spent a long time building offhand glassblowing equipment. 'Sometimes' the layer of glass on the inside of water heater casings can vitrify at higher temps and begin to degrade the castable lining from the back. INot to say that it will cause cause problems, but it can. <br>Great project, and thanks for sharing to all, <br>Notbot
Tampering with LPG cylinders or converting them to any other use as shown here is highly dangerous and can result in serious injury or death. Furthermore, Calor branded cylinders are, and always remain, Calor's property and as such, any conversion is unlawful and could result in Calor taking legal action or, if appropriate, in criminal prosecution. Please remove these photos, video, instructions and link to the Calor website from this site (and anywhere else it might appear online) immediately. Failure to do so may result in Calor taking legal action against you. Thank you in advance for your cooperation.
I will remove the link, but I'm not removing the photos, you can take me to court if you like. but the contract for that cylinder was with its original owner who gave it to me. I suggest you go find them ;-)
Here in the USA if you go to your local propane suppler and ask for a bottle that is no longer certifiable and tell them it is for a special project often they will often give it to you for nothing. Saves them the cost of having to dispose it.
In the past I have had to repair by brazing the odd car gas tank. I think this dangerous operation can be made a lot safer by dropping a few chucks of dry-ice in the tank and leave one vent hole opened and let the CO2 purge bit before you start. With that in place my hand doesn't shake nearly as bad with the torch.
dry Ice is harder to come by in the UK
Really!? Why have they made it hard to find? (No criticism just plain curiosity :)
its not avaliable in supermarkets here, it would take a while to source it
I'm sorry to hear that, If I could I would ship you a whole carton of the stuff! Thanks for the 'ible by the way I hope I get a chance to try it this winter.
Great instructable. For those of you looking for fire clay check out ebay: http://www.ebay.com/itm/Super-32-Refractory-Mortar-50-pound-container-/130470068688?pt=LH_DefaultDomain_0&amp;hash=item1e609f41d0 <br>I found some at the above address. WS
Couldn't you have used a wrench (spanner in the UK) just to remove the entire valve assembly, which would have made emptying out the gas much easier and safer? <br> <br>Even running the drill slow there is a risk of explosion because the drill motor is constantly sparking.
They are instaled with some sort of a locking sealer. I use my recipricating saw to cut off the valve. If you are concerned about the spark/gas thing turn a garden hose on the saw blade to basically seal the cut and you should be fine. <br>
I would be scared a this point, because on very low gas just some air inside would make some good explosion ratio...
for ignition of lpg or propane type fuels you need somewhere in the vicinity of a 14to1 air fuel ratio. That is where the water comes in. As I said before, it seals the air out and keeps what little trace gas is left in the bottle in the bottle. I ALWAYS bleed the bottle to zero psi and let it sit with the drain/bleed plug opend or removed over night before I ever start cutting. <br> <br>If the afr is not correct there is little if any chance of an explosion. <br>If you had an air powered saw you could always cut it completely underwater.:) <br>
the most likely out come would be a jet flame until the air got enough inside the bottle to ignite and then it would eat up the oxygen and just raw out of the holes like a jet engine. if anyone has seen those jam jar jet engines its the same just a lot scarier lol.
I wanted to do this but on one side is a safty valve which got in the way, and the other side was a level gauge which was in the way. but to get it out you have to melt the liquid weld they use on the valves and this is best done with heat, not a good idea with a gas bottle
Nicely done! plenty of details as if you really expected us to build one from your ible. I've always meant to cast aluminum, and maybe this will motivate me to actually do it. <br>It seemed like in the test pour video, that the aluminum was kinda jello-ish. I always understood it to be watery when melted. what about that?
it was very waterish but once you do the first pour you get a bit that cools in the air so it sticks out. <br> <br>the stuff at the bottom was because I put the crucible down on a cold surface so it stuck to the bottom. I shouldnt have been using a can anyway, it was just to demonstrate it would work. <br> <br>and yes i do expect you to build one! all ibles should be written as if you are directing the person on how to make one, this way you get the full information, its all about how you did it so others can follow you and where possible improve on your methods.
I think a clay based crucible would be best for this I wonder how a small clay pot would do
I think it would be ok, I have used flower pots before to direct the flow of thermite which burns around 2700 degrees celcius, the pots cracked but I put that down to rapid temp change from ambinate to 2700 lol <br> <br>due to the above experiments in the past i'm going to be using terracotta pots ground up as my grog for making the cruicbles, mixed with some fire clay and potash feldspar as a binding agent like proper ceramics use. <br> <br>I'm not sure if i'm going to glaze it or not, apparently if you glaze them they last longer but its not a requirement.
also you have to bear in mind that the surface tension would be different than water, hence why it sort of domed in the pan.
i take my empty tanks to the local propane company and have them purged with argon for $5
About This Instructable
75,745views
378favorites
License:
Bio: One day I shall own a Delorean.
More by n1cod3mus:Giant Wooden Connect Four Butterfly Coat Rack from off cuts Silcone Matrix Mould / Cavity Mould
Add instructable to:
