Step 2: Using The Lathe
  • Put your work piece (Ø12mm aluminium rod) into the lathe chuck
  • You should have approximately 50mm sticking out the chuck
  • You must never leave the chuck key in the chuck as this is very dangerous
  • Ensure the correct cutting tool is in position and that it is at the correct angle for facing off
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
