Introduction: Aluminium Keyring
This is a small quick project I use in my after school Engineering club for Yr9 students (13year olds). As with all my instructables its achievable by all and results in a quality product that works well. It only takes 1-2 hours to make depending on ability of student, this makes it a real confidence builder.
This project was used as part of a enterprise activity where students made various products to sell on a market stall, this was to raise funds to finance an electric car they wanted to build.
Learning Objective
By making an aluminium keyring KS4 GCSE students will learn and apply knowledge in a practical situation. This knowledge covers accurate use of the measurement dials on the X axis of a metal lathe, how to accurately drill to a given depth, chamfer and face off a component. This project was used as part of a enterprise activity where students made various products. By using this project in their enterprise activity students gain entrepreneurial skills and begin to see the link between time to make / materials cost Vs sale price.
Step 1: Working Drawing
A working drawing is a 2D drawing that shows you the dimensions needed to make a product or component.
Step 2: Using the Lathe
- Put your work piece (Ø12mm aluminium rod) into the lathe chuck
- You should have approximately 50mm sticking out the chuck
- You must never leave the chuck key in the chuck as this is very dangerous
- Ensure the correct cutting tool is in position and that it is at the correct angle for facing off
Step 3: Centre Drill
• Centre drill the end
Step 4: Drilling
• Drill Ø4mm x 15mm deep
Step 5: Sanding
- Sand outer surface
- Be very careful not to touch the spinning chuck with your fingers
Step 6: Grooves
- Set the cutting tool to the correct angle
- Decide where the first groove will be
- Advance the tool forward to create the first cut, it should be approximately 2mm deep
- Bring the cutting tool back and rotate the X-Axis 4mm (two turns)
- Repeat the cutting process
- Create three grooves
Step 7: Parting Off
- Set the parting off tool to exactly 900
- Part off
Step 8: Chamfer
- Set the parting off tool to 450
- Create a chamfer on both ends
Step 9: Cutting Cable
- Decide how long you want the cable to be (mine was 80mm)
- Use wire cutters to cut cable
Step 10: Glue
- Mix a pea sized blob of epoxy resin and carefully put into the hole
- Fold the cable over and put the ends into the hole
Step 11: O-rings
- Roll on the o-rings
- Enjoy :)
ShopBot Challenge
The Teacher Contest
