Aluminium Milling
8,128
142
23
Posted
Introduction: Aluminium Milling
I have been building a funky bike shed that I call a Bike Wardrobe and I needed to mill a slot in some 5mm thick aluminium sheeting for the locking throw bolt.
A quick search on YouTube taught me how to do it and I was amazed at achieving this for the very first time!
Come with me and I will show you how to do it as well...
Step 1: Bits That You Will Need
MATERIALS
Aluminium [aluminum] sheet, mine was 5mm thick.
Off cuts of MDF or ply for jig
Some screws
TOOLS
Electric router, I use a 1/2" router though a 1/4" should do also
High speed steel [HSS] router cutter for wood, I used a plunge cut one with cutter profiles on the bottom as well as the side, width to suit the milled slot.
Screwdriver
Cordless/power drill
Selection of drill bits + countersink
Step 2: Prepare Your Router
Remove the plastic base plate from your router.
Cut a piece of ply/MDF [I used 4mm thick] to a larger size than the base of the router to allow it to be screwed to the jig.
Cut a slot from it to allow the cutter to plunge freely and to enable you to see the progress of the milling.
Carefully mark the fixing holes from the base of the router and drill and countersink the ply for re-fixing back onto the base of the router.
Step 3: Make Your Jig
A jig is just a device that holds your tool [router] and guides the material [aluminium].
I required a strip of aluminium about 50mm wide which I cut by hand!
The jig design will be dependent on the shape and size of the piece of aluminium that you need to mill.
I cut two pieces of 6mm thick MDF and fixed them to a thicker 18mm MDF to hold the aluminium strip though allowing it to slide without any play side to side.
The router and its ply base was screwed to this MDF jig centrally as I needed the slot in the middle of the strip.
The whole jig was screwed securely down to the work bench, important that there is no movement in the jig.
Fix a screw at either end of the aluminium strip at the desired extent of the slot to act as stops.
I was fortunate to have a tapped hole that I inserted a bolt into to make the sliding of the strip easier, sticking a tab of duck tape to the aluminium strip should work as well.
Check that all is screwed down securely, that the router will plunge the full depth that you require and that the aluminium strip will slide.
Step 4: Mill
Please wear ear defenders and eye protection, you know it makes sense!
Switch on and slowly plunge until the cutter cuts into the aluminium.
I found that only a fraction of a millimeter was possible to mill at each pass.
Listen to the sound of the cutter to determine that the cutter was not being put under any strain.
Slowly slide the aluminium strip until it reaches the stop and return to the starting position.
Repeat the process until at the desired depth.
For my 5mm thick piece it probably took about 12 to 14 cuts to mill all the way through. Deeper milling should be possible up to the depth of the router cutter.
Release the plunge and switch off the router.
Step 5: Fantastic!
Remove the aluminium strip from the jig...
...and you have a perfect milled slot.
FANTASTIC!
This Instructable resulted from my recent project the Bike Wardrobe that I designed and built with my design company pricklysauce.
I love learning new skills and I am still amazed that within a few minutes of searching the internet and YouTube that you can learn enough to tackle something that you have never done before.
I hope that you have enjoyed this Instructable and maybe you will also learn a new skill! If you liked it, your vote in the Beyond The Comfort Zone Contest would be really welcomed. Thanks.
If you would like to check out the build of the Bike Wardrobe please click here to go to my YouTube channel, where you will also find my Its a Rubbish Challenge videos where I try to make interesting things out of the stuff that we throw away.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
23 Comments
thank you for proving something I've thought for awhile, that a router can be used as the basis for a vertical milling machine
Seems to work well, though please remember this one only works with aluminium.
Please check out comments below that mentions the type of aluminium to use, though I have no idea what type I used for the project!
Next step : make yourself a CNC Router. A complete 'metal plate cutter' kit is available over at www.OpenBuilds.com. I made a large (52" x 20") : myOX @ http://openbuilds.org/builds/myox-a-4-x-2-ox-cnc-w... buying parts from here & there, following their base OX as a model and using my full size router.
You will be able to cut just about any shape, pockets, etc. in wood, plastic and aluminum.
Hey Serge - a CNC build is on my list! I have just bought an Arduino to start playing around at converting an old drafting table into a basic plotter/cutting table, then onto a full size ply sheet CNC machine. My hope would be to use it for cutting things like aluminium and plastics as well.
Thanks for the link to OpenBuilds, looks like a good site.
That's a great idea : converting your old drafting table into a plotter / cutting table. It would make for a great Instructables.
OpenBuilds got me into CNC as I always thought it would be too difficult and expensive. The OX design is an economical and practical approach used by many DIY/Makers to make their own machines.
Wow.. that worked perfectly! Can you figure out how to cut in the X and Y direction using this method? I could see if you figured that out being a good way to cut big slots, and square recesses.
Checkout www.OpenBuilds.com. You might want to build yourself a CNC Router ...
This is nice.. but for quickly cutting out a box shaped hole, It's overkill. I Just want to be able to put a block of metal down, hack out a hole with my eyeball, and then go on with my project.
I will look into this since eventually I like to take over space all territory beyond.
If all you want is to do the odd pocket once in a blue moon, it would be overkill. But you might get bit by the bug to do more and tricker designs, ... ;) It's then that you will start looking into making your very own CNC machine.
While the CNC does the pockets and cuts, you work other aspect of projects... The eyeball, fingers, etc. staying at a safe distance.
Hey Cheezedog, I guess the easiest way would be to make one slot and re-position the router over the jig to make a second pass to the full width of the slot that you want.
Otherwise with a bit of thought I am sure a jig could be made up that would allow for X+Y cutting.
Just be aware that the whole assembly has to be tightly secured down as Jonmero pointed out below, no freehand milling.
If you figure it out let us know how you got on.
