I recently got a new desk and and I had a lot of trouble with my optical mouse and its not functioning with the surface.
I did a lot of research and found that new optical mice work very well on Teflon coated materials. Immediately I bolted up the stairs and grabbed my mothers T-Fal frying pan. Upon trying it out i realized how responsive and precise the mouse was now reacting (not to mention the Teflon pads of the mouse on the Teflon top is slick as butter) . After looking at some Teflon pads online i thought... "hey, there expensive.... imma build one of those." The next day I stopped at Wal-mart an picked up a Teflon Coated pan.
Remove these ads by
Signing UpStep 1Materials
This cost me about $25
You should replace it with one that has a guard for cutoff disks. That way when the disk breaks, you won't end up with shards of hardened sand inside of you
www.ikea.com/us/en/catalog/products/10133052
Pretty large, so it could double as a laptop tray, and mouse pad?
-Bob
Alphonsus... I am your father!
wait 15 on your profile.... are you sure your my dad? i want a dna test
I know with a glossy finish counter top (Veneer over particle board), that my optical mouse will track, and also looses it's precision to an extent during design sessions in Photoshop, or Adobe Flash.
Let me know if you have any comment on this.
Good design, better look. Simple, clean, and obviously functional.
The pad was heated with my wife's hair dryer while on the desk and the sheet lost all tendency to curl. Flat, thin, slick and CHEAP!
Seems like another instructable... USB heated teflon coated mouse pad. Shouldn't be too hard either, put feet on the pad to raise it off the desk a quarter inch then epoxy 4 x 10 ohm, 2W resistors to the bottom in a 2 series x 2 parallel configuration for 10 ohms (500mA from 5V USB power) total, add USB connector and a couple wires.
Or turn on the furnace. ;)
Metal objects tend to feel colder even at room temp, since they suck heat away from your body faster than less-conductive materials. So even in a warm house, a heated aluminum mouse pad might not be a bad idea.
