Introduction: Aluminum 3DPrintMi - 3DPrinter Assembly Guide
Picture of Aluminum 3DPrintMi - 3DPrinter Assembly Guide
Aluminum 3DPrintMi is an open source, Reprap 3D Printer and the next iteration of the original3DPrintMi. As part of the Reprap movement, it has the ability to self replicate by printing a portion of itself and assembled together with fasteners.
For more information, please visit the links listed below:
Summary
After building the original 3DPrintMi, I continued to make improvements in an effort to reduce cost and further increase the ease of assembly. The Aluminum 3DPrintMi retains a few sub-components from the original design but with a few changes. The frame was redesigned using aluminum extrusion 2020s, significantly reducing assembly time, part count, and overall cost per unit. To improve the user experience in operating the 3DPrintMi, an induction probe was added into the final design, streamlining the bed leveling process. After printing 1000+ hours with the Aluminum 3DPrintMI and listening to other 3DPrintMi users, I have determined that it's current state is ready for release and, as usual, open source and free for the public. Enjoy the build!
Getting Started
This guide will provide you the step-by-step instructions on how to assemble the printer's frame, assuming that the user has already pre-assembled the electronics before hand. I highly recommend you review the pictorial guide to get a good sense of what to expect. The pictures are self explanatory and the written instructions are there to aid the assembly.
Step 1: Getting Started - Review Bill of Material and Collect Your Tools
Picture of Getting Started - Review Bill of Material and Collect Your Tools
Bill of Material
Before you start buying the materials, you will need to complete the BOM by selecting the desired selections based on your preferable budget, setup and convenience in sourcing the parts. The options are highlighted in orange and the parts will auto-update the price and source link so take your time selecting your material.
Sourcing the printed parts may be a bit tricky since you will have to search around for someone or someplace with a 3D Printer. Look around if there's a local Hackerspace nearby, most likely they have 3D Printers that you can use or pay someone to print them for you. If you can't find anyone, PM me and I can work something out.
Tools
  • Digital Caliper
  • Wire cutter (to cut zip ties)
  • Needle nose pliers
  • Slip joint pliers
  • 2.5mm/3/32" Hex screw or a thin Phillip screwdriver (depends what kind of M3 screws you use)
  • Reaming tool (to enlarge holes if part quality is low)
Step 2: Know You Printed Parts
Picture of Know You Printed Parts
These are the parts that make up the printer. They are ready to be downloaded and printed on any 3d printer that has a build area of at least 152mm x 152mm (6" x 6"). Refer to the BOM to see the number of printed parts needed.
The Printed parts are listed as follows:
  1. Y End Motor_AL
  2. Y End Idler_AL
  3. Y Carriage_A_Ver.2
  4. Y Carriage_B_Ver.2
  5. X End Motor
  6. X End Idler
  7. X Carriage
  8. Extruder mount
  9. 2020 Corner Brace
  10. Z Motor Housing_A
  11. Z Motor Housing_B
  12. Bottom Z Rod Brace
  13. Z Coupling
  14. Top Z Rod Stabilizer_A
  15. Top Z Rod Stabilizer_B
  16. Top Z Rod Brace
  17. Endstop mount
  18. Knob
  19. Y Carriage Extender_A
  20. Y Carriage Extender_B
  21. Spool Roller_A
  22. Spool Roller_B
  23. Filament Feed Guide
  24. Induction Probe
  25. Blower Fan Duct
  26. Blower Fan Holder
Step 3: Sub-assembly - 2020 Corner Brace
Picture of Sub-assembly - 2020 Corner Brace
Total: 14
Parts
  • 13 - 2020 Corner Brace
  • 26 - M3 x 10mm
  • 26 - M3 T-Nut
Notes
  • Do not tighten, leave it loosely fit
  • Some T-Nuts will need to be taken off the corner braces and installed into the frame
Step 4: Sub-assembly - Endstop Mount
Picture of Sub-assembly - Endstop Mount
Total: 2
Parts
  • 2 - Endstop Mount
  • 2 - M3 Hex nut
Notes
  • Use slip joint pliers to insert M3 Hex nuts
Step 5: Sub-assembly - Knob
Picture of Sub-assembly - Knob
Total: 8
Parts
  • 8 - Knob
  • 8 - M3 Hex Nut
Notes
Step 6: Sub-assembly - X Carriage
Picture of Sub-assembly - X Carriage
Parts
  • 1 - X Carriage
  • 1 - Extruder Mount
  • 6 - M3 Hex Nut
  • 4 - M3 x 25mm
  • 3 - LM8UU (Optional to install now, can wait until later on)
Notes
Step 7: Sub-assembly - Z Motor Housing
Picture of Sub-assembly - Z Motor Housing
Total: 2
Parts
  • 2 - Z Motor Housing A & B
  • 12 - Square Nuts
  • 2 - Bottom Z Rod Brace
  • 8 - M3 x 18mm
  • 16 - M3 x 10mm
  • 2 - Nema17 Motor
  • 2 - Vinyl tubing
  • 8 - M3 Hex Nut
  • 8 - M3 Washer
Notes
  • Skip the Nema17 Motor installation until the frame assembly
Step 8: Sub-assembly - X End Motor
Picture of Sub-assembly - X End Motor
Parts
  • 1 - X End Motor
  • 2 - LM8UU
  • 1 - GT2 16 teeth
  • 1 - Nema17 Motor
  • 4 - M3 x 10mm
  • 2 - Zip Ties
Notes
  • Do not press fit the M8 Hex Nut yet, it will go on the threaded Z rod
  • Use Zip Ties to secure LM8UU Bearings
Step 9: Sub-assembly - X End Idler
Picture of Sub-assembly - X End Idler
Parts
  • 1 - Y End Motor
  • 2 - LM8UU
  • 2 - F608ZZ Flanged Ball Bearing
  • 1 - M8 x 35mm Cap Screw
  • 1 - M8 Hex Nut
  • 2 - Zip Ties
Notes
Step 10: Sub-assembly - Y End Idler
Picture of Sub-assembly - Y End Idler
Parts
  • 1 - Y End Idler
  • 4 - M3 x 10mm
  • 2 - M3 x 18mm
  • 4 - Square Nuts
  • 2 - M8 Washer
  • 1 - M8 Hex Nut
  • 2 - M3 Hex Nut
Step 11: Sub-assembly - Y End Motor
Picture of Sub-assembly - Y End Motor
Parts
  • 1 - Y End Motor
  • 7 - M3 x 10mm
  • 2 - M3 x 18mm
  • 1 - Nema17 Motor
  • 1 - GT2 16 teeth pulley
  • 4 - Square Nuts
  • 2 - M3 Hex Nut
Step 12: Sub-assembly - Z Coupling
Picture of Sub-assembly - Z Coupling
Total: 2
Parts
  • 2 - Z Coupling
  • 8 - M3 Hex Nut
  • 8 - M3 x 18mm
  • 8 - M3 Washer
Notes
Install 8mm lead screw during frame assembly
Step 13: Sub-assembly - Top Z Stabilizer
Picture of Sub-assembly - Top Z Stabilizer
Total: 2
Parts
  • 2 - Top Z Stabilizer (A & B)
  • 2 - Top Z Rod Brace
  • 4 - M3 Washer
  • 3 - M3 x 10mm
  • 4 - Square Nuts
  • 4 - M3 x 18mm
  • 4 - M3 Hex Nut
Step 14: Sub-assembly - Spool Holder
Picture of Sub-assembly - Spool Holder
Total: 2
Parts
  • 2- Spool Holder (A & B)
  • 4 - M3 x 10mm
  • 4 - Square Nuts
  • 8 - F608ZZ Flanged Ball Bearing
  • 4 - M8 x 35mm Cap Screw
  • 4 - M8 Hex Nut
  • 4 - M8 Washer
Step 15: Sub-assembly - Filament Guide Holder
Picture of Sub-assembly - Filament Guide Holder
Parts
  • 1 - Filament Guide Holder
  • 1 - M3 x 10mm
  • 1 - Square Nuts
Step 16: Subassembly - Y Carriage
Picture of Subassembly - Y Carriage
Parts
  • 1 - Y Carriage A
  • 1 - Y Carriage B
  • 2 - Y Carriage Extender A
  • 2 - Y Carriage Extender B
  • 8 - Sub-assembled Knob
  • 4 - LM8UU
  • 6 - M6 Thin Hex Nut
  • 2 - M6 x 110mm Cap Screw
  • 4 - M6 Washer
  • 12 - M3 Hex Nut
  • 12 - M3 Washer
  • 8 - M3 x 18mm
  • 4 - M3 x 25mm
  • 1 - 200 x 200mm HeatBed
  • 1 - 200 x 200mm Glass
  • 1 - 200 x 200mm 28 gauge galvanized steel sheet
Notes
  • Use 28 gauge galvanized steel sheet for Induction Probe setup
  • Drill out hole with 1/4" drill bit If using 1/4" Cap Screw instead of M6
Step 17: Sub-assembly - Blower Fan
Picture of Sub-assembly - Blower Fan
Parts
  • 1- Blower Fan Holder
  • 1- Blower Fan Duct
  • 1 - Blower Fan
  • 2 - M3 x 25mm
  • 2 - M3 Hex Nut
  • 1 - M3 x 10mm
Step 18: Sub-assembly - Induction Sensor
Picture of Sub-assembly - Induction Sensor
Parts
  • 1 - Induction sensor (SN04-N probe)
  • 1 - Induction Sensor Holder
  • 2 - M3 Hex Nut
  • 2 - M3 x 18mm
Step 19: Assembly - Framing Y & Z Axis
Picture of Assembly - Framing Y & Z Axis
Parts
  • 3 - Aluminum Extrusion 2020
  • 4 - Sub-assembled Corner Brace
Step 20: Assembly - Framing the Y Axis
Picture of Assembly - Framing the Y Axis
Parts
  • 9 - Square Nuts
  • 1 - Sub-assembled Corner Brace
Notes
Use Square Nuts on the Z Motor Mount
Step 21: Assembly - Z Motor Mount
Picture of Assembly - Z Motor Mount
Parts
  • 2 - Sub-assembled Z Motor Mount
  • 1 - Aluminum Extrusion 2020
Notes
Remove Nema17 Motors from the Z Motor Mount in order to tighten screws
Step 22: Assembly - Y Ends
Picture of Assembly - Y Ends
Parts
  • 1 - Sub-assembled Y Idler
  • 1 - Sub-assembled Y Motor
Step 23: Assembly - Top Z Stabilizers
Picture of Assembly - Top Z Stabilizers
Parts
  • 2 - Sub-assembled Corner Brace
  • 2 - Sub-assembled Top Z Brace
Step 24: Assembly - X Gantry
Picture of Assembly - X Gantry
Parts
  • 1 - Sub-assembled X Carriage
  • 1 - Sub-assembled X Idler
  • 1 - Sub-assembled X Motor
  • 4 - 8mm Smooth Rods
  • 2 - Z Coupling
  • 2 - M8 lead screw
  • 8 - Zip Ties (Large Size)
Step 25: Assembly - Y Carriage/Build Plate
Picture of Assembly - Y Carriage/Build Plate
Parts
  • 2 - 8mm smooth rod
  • 1 - Sub-assembled Y Carriage (No HBP & Glass)
Step 26: Assembly - Belt Drive
Picture of Assembly - Belt Drive
Parts
  • 8 - Zip ties (small size)
Step 27: Assembly - X & Y Endstop
Picture of Assembly - X & Y Endstop
Parts
  • 2 - End-stop
Notes
One end-stop for each axis (X & Y)
Step 28: Assembly - MBE Extruder
Picture of Assembly - MBE Extruder
http://www.thingiverse.com/thing:1236065
Step 29: Assembly - Direct Drive Vert-Xtruder
Picture of Assembly - Direct Drive Vert-Xtruder
Files for the Direct Drive Vert-Xtruder available on my thingiverse page
http://www.thingiverse.com/thing:137806
The Hotend used is the E3D V6
http://e3d-online.com/
Step 30: Assembly - Spool Holders & Filament Guide
Picture of Assembly -  Spool Holders & Filament Guide
Parts
  • 2 - Sub-assembled Spool Holder (A & B)
  • 1 - PTFE Filament Tube
Notes
Install PTFE Filament Tube and cut to length
Step 31: Induction Probe Setup
Setting up the induction probe for auto-leveling will take some time. I create a step-by-step tutorial on my blog couple months back along with a list of other sources that helped me get it going. The induction probe can be replaced with a simple mechanical switch for the Z stop but once you use the auto-leveling feature, you never want to go back. Follow the blog and should have it up and running in no time.
http://gyroe3dprinter.blogspot.com/2015/02/aluminu...
Step 32: Assembly Complete
Picture of Assembly Complete
Congratulations! You have completed assembling your very own Aluminum 3DPrintMi.
All you have to do now is hook up any available 3D Printing electronic board and there are numerous tutorials online that you can follow. Good luck and happy printing!
Jacksmithy1955 (author)2016-08-03
HI
I am thinking of possibly making this over a https://www.instructables.com/id/eWaste-60-3DPrinte...
But i was wondering how much it cost you in total, bearing in mind i dont currently have access to a 3d printer
Cheers
vsams14 (author)2016-05-26
I remember I tried to make the original one but it wasn't so great - wobbly and unstable. But that was 3 years ago and many of my parts rusted over. Might try this version this summer. Can I modify existing parts from the original 3dprintmi to make this one?
wolfstep made it! (author)2016-02-09
I made the original printer and it is still going strong! I cant wait to start this newer version! If it is anything close to the original, I know I wont be disappointed. Thank you for making this printer so easy to build and understand.
About This Instructable
6,338views
71favorites
More by gyronictonic:Aluminum 3DPrintMi - 3DPrinter Assembly Guide3DPrintMi - Assembly GuideCoreControl DIY
Add instructable to:
