Aluminum Bottle Alcohol Stove
 by hpstoutharrow
Featured
An Alcohol Stove made from Aluminum Bottles
There are plenty of aluminum can stove designs out there. This one is different in that it is not made from aluminum cans but rather from aluminum bottles (aluminum beer bottles to be specific) After building a few stoves myself I wanted to design one to address a few shortcomings of other can stoves:
1. Priming - A number of stoves require an external heat source to bring the alcohol to vaporization temperature. Some require heating the bottom for a few minutes or burning some alcohol in a separate "primer pan" or on the ground around the the can as a means to heat the exterior of the of the stove to achieve a self-sustaining burn.
2. Separate pot stands - A number of stoves have a low profile and are very compact however the smallest of the small require separate pot stands to cook with. Kind of defeats the purpose of a compact stove in my mind.
Sure there are side jetted designs that hold a pot however I wanted a design that would also address a third shortcoming.
3. Cold pan Flame-out - Of the can stove designs that do support a pot, I have seen them suffer from this condition. When a pan of cold water (fresh from the camp pump) is placed directly on a can stove, it acts as a large heat sink. Before the stove can warm the water, the cold pot cools the aluminum stove so much that it cannot maintain alcohol vaporization and the stove goes out.
Admittedly, there are are many great can stove designs out there; many are self priming (nothing new there) and some have integral pot stands. Each has pros and cons depending on your priorities. This is another design for consideration.
and besides, I just wanted an excuse to work with those cool aluminum beer bottles.
Update 9/15/09: Just posted an Instructable that that shows another stove related use for aluminum bottles http://www.instructables.com/id/Aluminum-Bottle-Tumbler-Cup-Cook-Pot/
Step 1: Aluminum Bottles
If you look hard enough you will find a local retailer that usually stocks at least a small quantity of these specialty aluminum beer bottles.
I prefer the use of these aluminum bottles over the traditional aluminum cans for the following reasons:
1. Stability - The overall diameter of a can is larger than a bottle, however, the bottles have a larger diameter where it counts, at the base were it contacts the ground. The wider base is important because we are making a stove to support a pot and every bit of width helps to prevent tipping.
2. Heavier Gauge - The bottles are a thicker gauge aluminum. The thicker metal is a little more challenging to work with (you can't cut it with a utility knife) however it brings a solid, durable feel that you just don't get from a can.
This also means more thermal mass to help counter the "cold pot flame-out" syndrome.
(Sure more metal is more weight however once you step away from a propane grill; a quarter of an ounce here or there is not my biggest priority. (By the way, don't forget to add the weight of a separate pot stand to those other designs)
The last photo show some of my trials with earlier aluminum bottle designs.
1-40 of 155Next »
Blacsdad says: Dec 16, 2012. 3:27 PM
I made it per your instructions and it works great. People ask me where I bought it! Thanks!
Default117 says: Sep 6, 2009. 9:30 PM
Flux Capacitors :]
murphypop in reply to Default117Apr 3, 2010. 5:56 PM
Epoxy :]
Algag in reply to murphypopApr 30, 2011. 7:08 AM
Beer :D
somebody12345 in reply to AlgagDec 21, 2011. 3:40 PM
Tape :D
JoshuaSmock in reply to somebody12345Dec 22, 2011. 8:01 PM
Superglue = [-]
c3ralki1l3r in reply to JoshuaSmockOct 2, 2012. 9:49 PM
Duct Tape (o)_
Gelfling6 says: Sep 17, 2012. 10:12 AM
I have 2 bottles already, but it seems bottles are becoming more and more scarce... I think they may've found the aluminum bottle was a little TOO popular for other uses, like this.. :-/
Gelfling6 in reply to Gelfling6Oct 1, 2012. 4:23 PM
Cancel that.. I now have 3!! Time to start building!
whait86 says: Sep 13, 2012. 9:14 AM
awesome 'ible
awesome 'ible
kbails84 says: May 11, 2011. 4:56 AM
can you just make and send me one!? I dont want to go through the trouble of this. How much would you charge!? lol
okto in reply to kbails84Jul 31, 2012. 11:32 AM
Why don't you just buy a camp stove?
Maxwell Yun says: Jun 15, 2011. 9:28 PM
You should put a piezoelectric lighter so that it can light with the push of a button.
DustyJK in reply to Maxwell YunMar 16, 2012. 6:27 PM
Great Idea
oldboyscout says: Feb 3, 2012. 3:11 PM
I like the design of the stove but I have one suggestion. I believe that pressurizing the stove would improve its performance. Two problems exist with most pressurized stoves. First, they require a priming bowl. Second, they require a syringe to add the fuel.
I would like to suggest a solution to both of these concerns. On the jet deck, instead of cutting a large diameter hole, mount two (2) of the beer bottle caps one on each side of the jet deck. Drill one 1/8 inch hole and one 3/16 inch hole through both bottle caps and the jet deck. Drill the holes as far apart as possible with enough room left for installation. Fabricate a sheet metal strip from a soft drink can large enough to cover both holes. Through the 1/8 inch hole install a blind rivet to fasten the upper bottle cap, the jet deck, the lower bottle cap and the thin sheet metal strip. Cut the head off a hollow 3/16 inch rivet leaving a small diameter tube. Install the tube into the 3/16 inch hole using epoxy to insure a tight fit and seal. Be careful not to get any adhesive on the thin sheet metal strip. Cut the length of the tube so that it can be installed flush with the bottom bottle cap and 1/8 inch or so higher than the surface of the upper bottle cap. Cut the necks from two (2) bottles and screw them into the bottle caps mounted on the jet deck. Cut the lenght of the necks so that they touch the base and the colonade. Cut a hole in the colonade smaller than the opening of the upper neck. Take a wooden dowel rod and bend the top of the colonade down to fit around the bottle neck.
To use the stove, pour fuel into the top of the stove. The 3/16 inch tube will allow the fuel to enter the lower pressurized chamber but since the upper end of the tube is higher than the bottom of the bottle cap a little fuel will be left in the upper bottle cap. The metal strip attached to the lower bottle cap may need to be adjusted so that the fuel flows easily into the lower chamber. Light the stove. The upper bottle neck serves as a primer bowl. When the stove is primed, pressure will build up in the lower chamber and force the metal strip against the 3/16 inch tube and seal the lower chamber. This will give you a pressurized jet stove that doen not require a separate priming bowl and does not require a syringe to add the fuel.
delmerp says: Jan 31, 2012. 8:07 AM
This author has lots of great ideas!
I found my Bud Light bottles at a local groccery store that ordered a case for me from their distributor. A little pricey, but I was then able to build several copies.
Just be sure to patiently stretch the bottoms with your pvc coupling; if not they will tear during assembly.
My son and I do some backpacking, and this works well even in winter. I use a piece of tinfoil for a windscreen, which is almost a necessity.
Of course, you could purchase an alcohol stove, but that's not really the point now, is it?
fczinkhan says: Oct 3, 2011. 10:58 PM
There is no way that your PVC pipe is 1.5" in the pictured bottle. Maybe the actual pipe is 1.5", but whatever is on the end, you failed to specify. The bottles are around 2.25" in diameter at the base. You cannot get a 1.5" pipe to even swivel in the 1" tall base piece to stretch it out. You just need to edit this section to include the larger fitting at the end of your pipe. Thanks for this 'ible, great job.
Kycirion in reply to fczinkhanJan 14, 2012. 10:28 AM
He did specify. He used a 1.5" PVC pipe FITTING to widen the aluminum cup. A PVC end cap or a straight coupler is what you need to add to the pipe. A 1.5" inch straight coupler is 2.215" in diameter and easily fits in the cup with room to rock it and press against the metal. The straight coupler works best since it has a somewhat sharp edge, the end cap has a radius on the edge and doesn't work very well.
max69power says: Jan 10, 2012. 2:57 PM
i user a 3/4 inch paddle bit to make the holes you just need to go very slowly. thanks for the great instrubles. your project looks great how long did it take you total time.
somebody12345 says: Dec 21, 2011. 3:36 PM
if you add salt to the alcohol you can see it in the light.
Sabretoothlime says: Sep 10, 2011. 1:35 PM
If you have a drill press you can use it like an arbor press. Heating the bottom piece will also help when you press fit the top. Or you can freeze the top piece and try to tap it in with a rubber hammer. Also, there is a special lining in all aluminum bottles, I used a muffle furnace set at 600 degrees to burn this lining out.
acoleman3 says: Jul 7, 2011. 10:44 AM
it would help to heat the base with a propane plumbers torch to eliminate the work hardening created by teh manufacturing process. this would return the aluminium to a relaxed state and soften it up a bit.
threecardmonty in reply to acoleman3Jul 23, 2011. 2:22 AM
I'm not too sure on the numbers for aluminum heat treat (I work mostly with tool steels) or the average temperatures produced by the various fuels used in this, but it's at least hot enough to boil water, and if allowed to air cool, should result in an annealing process every time it is used. I've made thinner gauge aluminum camp stoves, but have never had a problem with cracking due to work hardening, but like OP mentioned, it's best to avoid/remove any crease points or sharp edges to void tearing the metal, and a good overall sanding is a good idea to prevent any paint/plastic from coming into contact with high heat, especially when cooking.
chase.carlton in reply to threecardmontySep 8, 2011. 3:40 PM
Remember, kiddos: aluminum is typically normalized the opposite of steel. You need to heat and quench to get rid of internal stresses. That said, it's not necessary for this sort of thing.
btimmerman says: Aug 21, 2011. 1:57 PM
could you please tell me the weight of this stove... im going ultra light and i love this plan but im looking to get a msr pocket rocket witch comes in at 3oz. if this is lighter or the same could you please let me know
JoshuaSmock says: Aug 4, 2011. 1:47 PM
so I built this instructable and it works like a charm, I used the venom bottles like I mentioned earlier. It's not as pretty as the one shown, I was kind of getting impatient while making it, but it's functional. I used high temp silicone to seal all the seams. Still need to make the colonnade though.
cwturtle says: Jul 3, 2011. 5:09 PM
The only place that stocks those aluminum bottles is Walmart.
JoshuaSmock in reply to cwturtleJul 28, 2011. 11:01 AM
Venom Energy drink has a thick gauge bottle
acoleman3 says: Jul 7, 2011. 10:47 AM
out of curiosity, why is it tht the mouth of the neck needs to touch the bottom.
JoshuaSmock in reply to acoleman3Jul 28, 2011. 10:59 AM
Most likely for compression to aid in the evaporation of fuel.
cullenc1993 says: Jul 14, 2011. 9:59 PM
Yeah I would love to buy one of these from somebody. As long as you can get it to work as well as is advertised and preferably looks the same also. Send me a message and let me know you price and we'll work something out.
kbails84 says: May 9, 2011. 7:47 PM
Hey, I love this product, However I am having some trouble with the flow of the pieces. Is there a chance you could email me each individual part or attach an image of the whole stole pulled apart so as to better make sure that each piece is complete. Thank you
Airth says: May 8, 2011. 8:01 PM
I've been all over town, from convenience stores, liquor stores, groceries and everything in between--looks like no one makes the longneck bottles anymore!
alexsparrow says: Apr 22, 2011. 6:55 PM
can't you just use an oil filter
caddywumpus says: Mar 19, 2011. 10:28 AM
Wow I just completed my first instructable build... and WOW.... are my hands bruised and swolen. Stretching the bottoms so that on could telescope into the other one was almost as hard as drinking the Bud Light (I'm a New Castle/Guinness/Chimay Beer Fan). Between the construction and sanding all of the paint off the bottles it took me 11hrs. Would have been less if I didn't live in an apartment, had access to power tools, and wasn't drinking while building. After completing I took the stove out to the back deck to try it out. I didn't have any alcohol so the only thing I could think of was charcoal lighter fluid. It appears to work.. but I wouldn't suggest ever using lighter fluid... Now I have a lot of black soot covering the top half of my stove that I previously sanded to a beautiful brushed aluminum look. The main problem that I encountered was as the stove warmed and the jets began to sputter it seemed to skip the jets and ignited the fuel that was evidently seeping from where the base and the jet deck meet.  So the whole stove was on fire from the bottom joint to the top with a  bright orange flame (probably from using the lighter fluid).  Any suggestions besides not using lighter fluid?
triumphman says: Mar 7, 2011. 1:21 PM
I have never seen a metal bottle her in southern New York. No one carries metal bottles here. So I'm stuck without a paddle or a canoe. Maybee New Jersey has them? I'll look there next! Thanks for a great instructable!
MrRedBeard says: Feb 16, 2011. 2:30 PM
I made a very simple/crude version of this stove for a 3 day hike that ended yesterday. The stove worked beautifully and only used about an ounce to bring ~1 liter of water to a boil.
I used an aluminum pepsi bottle and it only contains 2 pieces. I used mine to boil water in an MSR 1.1L pot with no discoloration.
Johnclave says: Feb 15, 2011. 1:46 AM
That is a new stuff shown here we all know that alcohol is a flammable but its can be used in such a way is really some thing amazing thanks for sharing this
alcoholism disease
clarkkent1521 says: Feb 14, 2011. 2:06 PM
Advise please: I'm having trouble widening the base or the colonade. What am I not doing right? Any other suggestions to make this process easier?
1-40 of 155Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
