loading
Step 3: Bottom Cuts
1. Cut the bottoms off of the three bottles. Cut two bottoms 1.5" tall and one bottom 1" tall
I found that because to the thicker aluminum, the bottles could not be cut easily with a utility knife.
A hack saw works well to make the cuts.
The fixture shown below helped to start the cuts and made sure they were straight around the can. Several turns with the blade pressed against the can started the cut; which was finished by carefully sawing around the outside of the can with a hack saw. (do not try to cut straight through the can as the blade will bend the edges of the can once it breaks through the skin.)
2. Finish the edge of the can to remove any sharp edges or nicks. Any nicks at the edge will initiate a split when the can is stretched.
Place emery cloth (sand paper for metal) on a flat surface. Place the entire edge of the bottle flat on the emery cloth and turn the bottle to evenly smooth the edge.
I decided to make a adjustable sliding cut jig. Outa wood scraps. <br>The red bar slides nicely &amp; stable cuts
<p>Ok, High Kudos to: HPSouthArrow.</p><p>this was a bit tricky &amp; as I wanted more fuel capacity, I missed the colonnade sizing a bit. Yet it , worked VERY well.</p><p>takes a minute to get the burn bowl hot , then burn on!</p><p>I used a Tea Plastic bottle to nicely hold teh can while spinning it to cut with old hack saw blade.</p><p>NOTE: be sure you are turning it INTO the angled teeth of teh blade. in 10 Minutes voli!</p><p>see the pic.</p><p>Slim49</p>
<p>Amazing!!</p>
Looks awesome for some old beer bottles! Great job!
<p>Here is another touch to consider. I managed to make a simmer ring for the stove out of an old cat food can rim, fit just to the diameter, with a small bent 'handle' fitted by cutting opposing slits into the top and bottom of the rim where it meets and joining the two pieces with JB weld. It rests on top of the bottom section, just, and I drilled in four 1/2 inch holes to correspond with about half the slots in the Collonade, about half way up. I start the stove to boil, then remove the pot and slide the simmer ring over top and align with the holes. It significantly reduces the flame output. I managed to boil two cups of water in five minutes and simmer for a further 20 minutes. Sounds like a batch of rice cooking time. Warning - you have to add the simmer ring quickly as the heat conducts fast.</p>
<p>Pic?</p>
<p>this is by far my favorite design for this type of homemade stove and I must say that not only does it seem like a good design (compared to the ones I have made in the past) but it also looks VERY cool</p>
<p>Just finished two stoves, one for me and one for a nephew. The dimensions of the 'beverage' cans displayed in this project have changed since this was posted so required smaller hole on the burner can, otherwise flawless.. However, this stove is brilliant! Thank you SO much for posting this project! </p>
<p>cool</p>
<p>Just made this stove over the weekend. Great project. My only question is that you mentioned it would burn an film canisters worth of fuel for about 10 minutes, i'm lucky if i can get that much to burn for 3. Any ideas on why it might be burning so fast?</p>
I'm curious as to how sturdy the colonnade is before you bend it for fit but after the holes have been cut. <br> <br>The reason I ask is that I have limited supplies and would like to try to combine the colonnade and base into a single component and roll the top edge to restrain the burn bowl. <br> <br>This would reduce it to two bottles and, if the colonnade holds up to be rolled, perhaps make the structure sturdier overall. Not that it isn't sturdy as heck already. <br> <br>Nice work. :)
I made it per your instructions and it works great. People ask me where I bought it! Thanks! <br>
Flux Capacitors :]
Epoxy :]
Beer :D
Tape :D
Superglue = [-]
Duct Tape (o)_
I have 2 bottles already, but it seems bottles are becoming more and more scarce... I think they may've found the aluminum bottle was a little TOO popular for other uses, like this.. :-/ <br>
Cancel that.. I now have 3!! Time to start building!
awesome 'ible
awesome 'ible
can you just make and send me one!? I dont want to go through the trouble of this. How much would you charge!? lol
Why don't you just buy a camp stove?
You should put a piezoelectric lighter so that it can light with the push of a button.
Great Idea
I like the design of the stove but I have one suggestion. I believe that pressurizing the stove would improve its performance. Two problems exist with most pressurized stoves. First, they require a priming bowl. Second, they require a syringe to add the fuel.<br>I would like to suggest a solution to both of these concerns. On the jet deck, instead of cutting a large diameter hole, mount two (2) of the beer bottle caps one on each side of the jet deck. Drill one 1/8 inch hole and one 3/16 inch hole through both bottle caps and the jet deck. Drill the holes as far apart as possible with enough room left for installation. Fabricate a sheet metal strip from a soft drink can large enough to cover both holes. Through the 1/8 inch hole install a blind rivet to fasten the upper bottle cap, the jet deck, the lower bottle cap and the thin sheet metal strip. Cut the head off a hollow 3/16 inch rivet leaving a small diameter tube. Install the tube into the 3/16 inch hole using epoxy to insure a tight fit and seal. Be careful not to get any adhesive on the thin sheet metal strip. Cut the length of the tube so that it can be installed flush with the bottom bottle cap and 1/8 inch or so higher than the surface of the upper bottle cap. Cut the necks from two (2) bottles and screw them into the bottle caps mounted on the jet deck. Cut the lenght of the necks so that they touch the base and the colonade. Cut a hole in the colonade smaller than the opening of the upper neck. Take a wooden dowel rod and bend the top of the colonade down to fit around the bottle neck.<br>To use the stove, pour fuel into the top of the stove. The 3/16 inch tube will allow the fuel to enter the lower pressurized chamber but since the upper end of the tube is higher than the bottom of the bottle cap a little fuel will be left in the upper bottle cap. The metal strip attached to the lower bottle cap may need to be adjusted so that the fuel flows easily into the lower chamber. Light the stove. The upper bottle neck serves as a primer bowl. When the stove is primed, pressure will build up in the lower chamber and force the metal strip against the 3/16 inch tube and seal the lower chamber. This will give you a pressurized jet stove that doen not require a separate priming bowl and does not require a syringe to add the fuel.
This author has lots of great ideas!<br><br>I found my Bud Light bottles at a local groccery store that ordered a case for me from their distributor. A little pricey, but I was then able to build several copies.<br><br>Just be sure to patiently stretch the bottoms with your pvc coupling; if not they will tear during assembly.<br><br>My son and I do some backpacking, and this works well even in winter. I use a piece of tinfoil for a windscreen, which is almost a necessity.<br><br>Of course, you could purchase an alcohol stove, but that's not really the point now, is it?
There is no way that your PVC pipe is 1.5&quot; in the pictured bottle. Maybe the actual pipe is 1.5&quot;, but whatever is on the end, you failed to specify. The bottles are around 2.25&quot; in diameter at the base. You cannot get a 1.5&quot; pipe to even swivel in the 1&quot; tall base piece to stretch it out. You just need to edit this section to include the larger fitting at the end of your pipe. Thanks for this 'ible, great job.
He did specify. He used a 1.5&quot; PVC pipe FITTING to widen the aluminum cup. A PVC end cap or a straight coupler is what you need to add to the pipe. A 1.5&quot; inch straight coupler is 2.215&quot; in diameter and easily fits in the cup with room to rock it and press against the metal. The straight coupler works best since it has a somewhat sharp edge, the end cap has a radius on the edge and doesn't work very well.
i user a 3/4 inch paddle bit to make the holes you just need to go very slowly. thanks for the great instrubles. your project looks great how long did it take you total time.
if you add salt to the alcohol you can see it in the light.<br>
If you have a drill press you can use it like an arbor press. Heating the bottom piece will also help when you press fit the top. Or you can freeze the top piece and try to tap it in with a rubber hammer. Also, there is a special lining in all aluminum bottles, I used a muffle furnace set at 600 degrees to burn this lining out.
it would help to heat the base with a propane plumbers torch to eliminate the work hardening created by teh manufacturing process. this would return the aluminium to a relaxed state and soften it up a bit.
I'm not too sure on the numbers for aluminum heat treat (I work mostly with tool steels) or the average temperatures produced by the various fuels used in this, but it's at least hot enough to boil water, and if allowed to air cool, should result in an annealing process every time it is used. I've made thinner gauge aluminum camp stoves, but have never had a problem with cracking due to work hardening, but like OP mentioned, it's best to avoid/remove any crease points or sharp edges to void tearing the metal, and a good overall sanding is a good idea to prevent any paint/plastic from coming into contact with high heat, especially when cooking.
Remember, kiddos: aluminum is typically normalized the opposite of steel. You need to heat and quench to get rid of internal stresses. That said, it's not necessary for this sort of thing.
could you please tell me the weight of this stove... im going ultra light and i love this plan but im looking to get a msr pocket rocket witch comes in at 3oz. if this is lighter or the same could you please let me know<br>
so I built this instructable and it works like a charm, I used the venom bottles like I mentioned earlier. It's not as pretty as the one shown, I was kind of getting impatient while making it, but it's functional. I used high temp silicone to seal all the seams. Still need to make the colonnade though.
The only place that stocks those aluminum bottles is Walmart.
Venom Energy drink has a thick gauge bottle
out of curiosity, why is it tht the mouth of the neck needs to touch the bottom.
Most likely for compression to aid in the evaporation of fuel.
Yeah I would love to buy one of these from somebody. As long as you can get it to work as well as is advertised and preferably looks the same also. Send me a message and let me know you price and we'll work something out.
Hey, I love this product, However I am having some trouble with the flow of the pieces. Is there a chance you could email me each individual part or attach an image of the whole stole pulled apart so as to better make sure that each piece is complete. Thank you
I've been all over town, from convenience stores, liquor stores, groceries and everything in between--looks like no one makes the longneck bottles anymore!
can't you just use an oil filter
Wow I just completed my first instructable build... and WOW.... are my hands bruised and swolen. Stretching the bottoms so that on could telescope into the other one was almost as hard as drinking the Bud Light (I'm a New Castle/Guinness/Chimay Beer Fan). Between the construction and sanding all of the paint off the bottles it took me 11hrs. Would have been less if I didn't live in an apartment, had access to power tools, and wasn't drinking while building. After completing I took the stove out to the back deck to try it out. I didn't have any alcohol so the only thing I could think of was charcoal lighter fluid. It appears to work.. but I wouldn't suggest ever using lighter fluid... Now I have a lot of black soot covering the top half of my stove that I previously sanded to a beautiful brushed aluminum look. The main problem that I encountered was as the stove warmed and the jets began to sputter it seemed to skip the jets and ignited the fuel that was evidently seeping from where the base and the jet deck meet. &nbsp;So the whole stove was on fire from the bottom joint to the top with a &nbsp;bright orange flame (probably from using the lighter fluid). &nbsp;Any suggestions besides not using lighter fluid?
I have never seen a metal bottle her in southern New York. No one carries metal bottles here. So I'm stuck without a paddle or a canoe. Maybee New Jersey has them? I'll look there next! Thanks for a great instructable!
I made a very simple/crude version of this stove for a 3 day hike that ended yesterday. The stove worked beautifully and only used about an ounce to bring ~1 liter of water to a boil.<br><br>I used an aluminum pepsi bottle and it only contains 2 pieces. I used mine to boil water in an MSR 1.1L pot with no discoloration.
That is a new stuff shown here we all know that alcohol is a flammable but its can be used in such a way is really some thing amazing thanks for sharing this<br><br><a href="http://www.biblehealth.com/alcoholism/alcohol-abuse-facts-the-whys-and-hows-of-it.html">alcoholism disease</a>
About This Instructable
250,262views
1,103favorites
License:
More by hpstoutharrow:New Year's Tree Print Waterproof Plastic Maps Volcano Picnic Plate
Add instructable to:
