I believe that well burned campfire charcoal could also be used. Backpackers could have an extremely lightweight, wholly renewable and non CO2 generating light source.
From Wikipedia:Aluminum Air Battery
Aluminium batteries or aluminum batteries are commonly known as aluminium-air batteries or Al-air batteries, since they produce electricity from the reaction of oxygen in the air with aluminium. They have one of the highest energy densities of all batteries, but they are not widely used because of previous problems with cost, shelf-life, start-up time and byproduct removal, which have restricted their use to mainly military applications. An electric vehicle with aluminium batteries could have potentially ten to fifteen times the range of lead-acid batteries with a far smaller total weightt.
Remove these ads by
Signing UpStep 1Bill of Materials
An aluminum can. I use a soda can.
A piece of sandpaper. I happen to have some sticky sandpaper for a sanding block. Very convenient. This is used to remove the surface treatments from the can. This actually may be optional. I will experiment and update the instructable appropriately.
A sponge. This will be cut to fit inside the battery. I used a cellulose sponge from a 6 pack my wife had under the sink. A natural sponge may be more conductive.
A charcoal briquet.
Several readers have suggested alternative, readily available carbon sources. The most scientific sites I've visited have recommended activated charcoal for the carbon electrode.
- Britta disposable filters
- Aquarium filter charcoal
Rolling pin or short piece of pipe for crushing charcoal
Duck Tape - That's right its called Duck Tape, not Duct Tape.
Some copper wire or copper mesh. The effectiveness of this device is directly linked to connectivity between the copper drain and the carbon cathode. Also it is not possible to solder a lead to the aluminum.
I am using copper mesh and foil from K&S Metals to obtain connectivity. In the first release I tried a simple copper mesh/carbon combination that generates power but I am working on second generation and will update the instructable when it's available.
Hammer
Sadly, it is not power from potatoes. It is power from the metals reacting. But its still fun.
Actually many commerical aluminum oxide devices use metal electrodes. In my projects I use carbon to ensure that no confusion arises about the operation or results.
The al-oxide rig in Salt-Water-and-Aluminum-Foil-Night-Light/ might be a better test bed for that sort of experiment.
I would be very pleased to hear how this experiment comes out. Don't forget to put a porous non-conductive layer ( such as paper towels or something ) between the aluminum and the carbon (or foam) electrode.
My wife does a lot of craft work so we often visit art and craft shops. In one I saw some perforated plastic sheet. Next time I visit the mainland I will buy some and see how that works out as the insulator.
I checked the black open cell foam, the semi transparent electronic items often come in and just to complete the checks also the pink closed cell foam.
All very high resistance >40Mohm over about 1/2".
Add some saline and you have a much tidier cell that could easily be wired in series to produce 3-6V.
http://en.wikipedia.org/wiki/Electrochemical_series
Now if I can just figure out what the entries mean I'll be set....
It is my understanding, from sources I can't quote offhand, that Al-Air fuel cells (replenishable) are the leading candidate to replace conventional rechargeables in netbooks and cellphones. The most common battery type used in hearing aids is Zinc-Air so this makes sense.
Wikipedia has the math but it doesn't explain it:
http://en.wikipedia.org/wiki/Aluminium_battery
"About 1.2 volts potential difference is created by these reactions"
I'm too stupid to figure out +2.71, +.40 and -2.31 produce a potential difference of 1.2.
