Step 2Preparing the Anode
Cut the soda can by whatever means about 1.5 inches high or about 1 inch above the lower rim. Using your sandpaper sand the inside lightly to remove any anti-oxidant coating.
Prepare enough warm salt water solution to fill the container. Use warm water and enough salt that it won't dissolve. Stir the solution to faciltate dissolving the salt and set aside.
In the Mark II I will be attaching a copper lead to get a good electrical connection with the can. Since aluminum cannot be soldered we're going to secure our drain mechanically with tape. We're going to use Duck Tape which was invented during WW II by Johnson and Johnson when the U.S. Navy needed a durable waterproof tape for use in the field. I understand this position is akin to posing a solution to "who writ Shakespare" but there you have it.
So it's like you're cleaning the rust off _
This is just a hypothesis though, I'm no chemist!
