3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Aluminum Can, Saltwater and Charcoal Battery
Step 3Preparing the cathode
The cathode is a carbon cathode with a copper lead to complete the circuit. The sponge is used to provide a bed to rest the carbon on. The copper mesh is secured to the grid and the carbon is heaped on top of it.
Take the sponge (dry is easier), invert the anode over it and draw a circle.the diameter of the can. Cut a circle from the sponge slightly smaller than the circle. The sponge will expand so you want to leave 1/8" or so all around.
Take the charcoal briquet and break it up into smaller and smaller pieces until you have a reasonably fine powder.
Put the briquet in a 1 gallon plastic garbage and break it with a hammer. Take care not to puncture the bag. I used a short length of PVC pipe as a rolling pin to grind down the charcoal. Remove any unburned particles of wood that you see.
The finer you make the powder the more power transfer will be available. Or at least that's my understanding. Its not clear at this point how much carbon is required in the cathode.
13 comments
May 26, 2009. 12:58 PMkennyhaa says:
Would it be possible to use activated carbon granules (i.e. aquarium filter carbon)? It may provide a carbon source that is more pure.
May 28, 2009. 7:57 AMshanmugammpl says:
yes get the charcoal tablets from the pharmacy, it is activated charcoal, powder it and use it. i tried it with aluminium foil and managed to get around 1 volt max.
May 28, 2009. 5:55 PMshanmugammpl says:
well this isn't a dietary supplement not its not the aquarium filter as well. It is used for treatment of food poisoning. as the activated charcoal adsorbs the "poison" from your stomach and renders it safe. so just ask them for activated charcoal. it is cheap, then you just powder it.
May 28, 2009. 8:17 PMshanmugammpl says:
it is in a form of a pill and you just crush it up. but you can also buy large chunks which are generally way more expensive than the equivalent weight of the tablet. the large chunks are use to deodorize rooms and purify water. P.S is it possible to use soot? like collect a lot of soot as it is very porus?
May 28, 2009. 11:15 PMshanmugammpl says:
yes i guess the hot glue method will work but then i am not sure if the tablet will absorb enough brine to ensure good connection.
May 29, 2009. 6:23 PMshanmugammpl says:
but when i did this i didnt use a sponge, maybe the sponge is a bad idea? it increases the distance between the aluminium and air so reaction slower?
May 29, 2009. 11:15 PMshanmugammpl says:
i used aluminium foil, and i placed a heap of the powder then poured brine till it was slightly wet but not too wet that it started flowing. Why do you have to separate the anode and cathode? it worked for me...
May 30, 2009. 11:27 PMshanmugammpl says:
Well no they dont short, it might seem ironical but they actually increase the rate of reaction. I dont know the power but i managed to get about 1 volt. i could even power a small motor out of it! you can hook up a joule thief to make a neat little lamp that runs on scrap aluminium. i will go test how long it will las.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
155
Author:egbertfitzwilly(More about me at LinkedIn....)
