Step 4Assembling the battery..
Place the sponge inside the aluminum can and pour in the salt water gradually allowing the sponge to expand. When the water just comes to the top of the sponge place the copper mesh on top of the sponge making sure it lays flat.
Now carefully pour the crushed carbon onto the copper grid.
Attach one lead from the voltmeter to the can, attach the other to the copper mesh. In this particular shot you can see the multimeter showing 3.6 mA, the intro shot shows the .5V reading.
If I've been reading everything correctly I believe this can be hooked up to a "Joule Thief" to power an LED.
Look for continuing updates to this project to reflect the Mark II design.
Check out my Easy Carbon Electrode instructable. I got 900+ mV with a sponge, a piece of aluminum foil and a replacement brush for a Black & Decker power tool.
The theoretical maximum is 1.2V, I believe that scaling up increases the amps but not the volts. You are correct that higher voltages are obtained by using multiple cells in series.
You'll probably prefer this design:
