loading
Hi everyone! This is Michael with Elemental LED!
This has been a long awaited project of mine and I am so excited to show it to you all! Hooking the lights up is fairly simple on this project but it is the chandelier frame that can be a little tricky. I suggest coming up with a design you like and going with it. I will provide my dimensions for reference, but ultimately it will be up to you to handle that part.
Material You Will Need:
Chandelier Frame
Acrylic for Under Display (Check out Tap Plastics, they are an excellent source for acrylic!)
Steel Chain (for Suspending the Chandelier)
Chain Locks (Quick Links) - Like These
Beer Bottles and Caps (Clear bottles work best for the colors, but the look of saving up your favorites is really nice too)
Lighting Material You Will Need:
6x ft. High Density RGB Strip Light
3x High Density RGB Bending Extension
4x ft. High Density Warm White Strip Light
3x High Density Bending Extension
Wireless Color Controller
REIGN Touch Dimmer Switch
8/2 Clear Lamp Wire
60 Watt Plug-In Adapter
1x DC Wire Plug - Female
All right! Lets do this thing!!
Step 1: Chandelier Base Measurements
You will have to start by building a chandelier base. I have a previous experience in the sheet metal field so that was my method of choice. I used Aluminium for its lighter material weight yet super durable strength.
I wish I could be a little more helpful in this part of the tutorial, but there is not to much I can do as I put this together in my uncles sheet metal shop and most users will not have access to these tools.
You could build this out of wood just as strong. Just make sure to use strong screws and wood glue between your pieces. A nice wood stain could really give this a whole new look.
Step 2: Prep for Paint
Once you have your chandelier base ready, use a drill to make holes on the top for corners to attach chain / chain locks. After the holes are made you will put your chain on the chain clips and attach the locking clip to your pre-drilled hole.
After all the chains are attached hang your chandelier to be painted.
Paint the chandelier with whatever method you choose. I used copper colored metal paint and applied 2 coats.
Step 3: Power and Wiring
Prep your power supply by either plugging it in or not. Either way is fine as you are working with safe voltages (12v DC).
Plug in the DC wire plug to the power supply so you can attach raw wire to it.
Before attaching any wire to the DC plug, first be sure of what you need. I recommend to join the two wire runs of whatever length you need together and weave it trough the chain ahead of time. Leave about 1 - 2 feet in the chandelier for powering the color controller and the display lights.
For the wire being hooked up to the REIGN switch make a mark ahead of time of some sort so you don't have to figure it out after they are weaved together.
You will need to determine how much wire you need to go from the chandelier to the REIGN switch and to the DC plug.
Now, back at the power source, join the two wires positives and negatives together and attach them to the DC plug for power.
Step 4: Installing the Lights
Take your tape light and attach all the connectors ahead of time. Once all the connectors are attached peel back the adhesive covering and lay it on the chandelier base. For the RGB I put it under the top lip to shine down on the bottles. The warm white display lights I put at the bottom of the cap keeper. (I'm sorry, I forgot to take pictures of this step, see this video tutorial to get an idea on how the strip works)
Using your mark to determine what wire is for what, take the wires you have left some slack on in the chandelier and attach them to the color controllers power and the display lights.
Then just try and hide the color controller best you can. It is radio frequency so it can pretty much go anywhere.
Step 5: Place the Acrylic Base, Then Bottles and Caps
Place the acrylic piece on the flanges in the cap keeper. You can glue it or seal it some how if you like, but I just prefer to have it rest on the flanges.
Then place your bottles in the cut outs, followed by saved up caps if you have them. if you don't have any bottles or caps yet, through a party and start building up!
Step 6: Enjoy Your Lighting!
You should now have your lighting all hooked up and ready to enjoy.
The color modes you can use on the controller are in the images on this step.
Step 7: Enjoy Your Beer!
Now grab a beer! Save the cap! Enjoy good times!
this is so cool. i bet if it were enlarged, you could use wine bottles too. <br> <br>though that's a hell of a lot of wine to drink. ;D
AWESOME, another excuse to drink more beer :-) <br> <br>How bright is it for providing light to work by (ie is it enough to light a bit of a pub?)
It does provide quite a bit of light upward, but the caps do prevent light going down. If you want to light upwards it will do the job!! :-) <br> <br>-Michael
I really want to do this but I dont want to spend 50 bucks on the RGB controller and another 50 on a dimmer. Could I just do this with white led strips and forget about the rgb controller and just wire it to an on/off switch? This way it would only have white light but it would save me a ton of cash.
Sorry for the late reply. Of course you could! The best part of DIY's are that you get to create things how you want them. When you're ready to get some product call customer service and they can help you figure it out. Send us pictures when its done! Have fun! :-) <br> <br>-MIchael
RGB leds wth the beer bottle...i guess iam collecting now..:) <div> &nbsp;</div>
Alright! Let us know how your project goes :)
Great job! looks awesome. I didn't even know they had multi-color LEDs now.
Thank you! Yes, that's one awesome thing about LEDs and there are color controllers too, to pick exactly what you want. Or even lights that react to music.
Wow, you must really like beer.
who doesnt?
A good way to kick back.
Great looking design. I love the customizable colors with the RGB LEDs
Thank you! Yes it's really easy with color controllers now.
How about to use FULL bottles with peltier cooling?
About This Instructable
56,069views
310favorites
License:
Bio: Hi, we're Elemental LED. We are committed to the importance of LED lighting as a revolutionary technology that can help people integrate green practices ... More »
More by Elemental LED:SJ Sharks Light Box LED Light Box with Southwestern Design Milk Jug LED Lamp
Add instructable to:
