Thanks to Kiteman for his original instructable! It can be viewed here:
Q:What is a Cracker Chucker?
A:Well, it's only the best way to turn small 'Ritz' style crackers into skeet!
Here in northeast Ohio, we have the luxury of being able to spend countless hours trap shooting and preparing for the next time a small disk flies over head, so we can shoot it down quickly and safely. (Watch your back E.T.) Skeet shooting and Trap shooting are two separate sports employing the same technology. Namely: shotguns, clay pigeons, and a throwing device.
"Trap shooting has been a sport since at least 1793 when it used real birds, usually the Passenger Pigeon, which was extremely abundant at the time. Fake birds were introduced around the time of the American Civil War as the Passenger Pigeon was nearing extinction and sufficient numbers were not reliably available. Clay targets were introduced in the 1880's." source:
Presently, most commercially produced clay pigeons are made of asphalt pitch. Asphalt pitch is a derivative of asphalt tar, and it is not readily biodegradable. It is also harmful to many animals, though most commonly wild and domestic pigs.
So, searching one day for a more 'green' way to train in the shooting sports, I stumbled upon Kiteman's Cracker Chucker. After building one and successively going through a full box of crackers with it, and a full box of shells, it was mostly duct tape and sticks holding it together. Collaboratively, my brother-in-law and I decided that one made of metal would subsequently last quite a bit longer. We also thought aluminum would be the best choice for weight to strength ratio. Without any further ado, here is the process I used to build The Aluminum Cracker Chucker.
Cost: Very little. (mine was free)
Difficulty: Very easy.
You will need:
1 piece of scrap aluminum 3 inches by 2 feet
Tape measure
Marker
Tin Snips
Drill
String or rope to use as a lanyard (I used 550 cord)
Rubber or Friction tape
Shrink Tube (optional)
Something to make a 1/8 inch to 1/4 inch bend (I used our shop's brake, but you can use a pair of sheet metal tongs or vise grips, it just takes considerably longer.)
As with all throwing devices and shooting sports, safety is the number one priority. I take no responsibility for anyone injured or killed in the use or construction of this tool.
Remove these ads by
Signing UpStep 1The Mark
I chose a scrap of aluminum from our drops bin that was 3 inches by 2 feet.
Next, on the end of the strip that you want to become the top, you will place five marks. I placed one mark in the center, 1 1/2 inches in. Then put two more marks on the top end. From the left, they are at 1 and 3/8 inches and 1 and 5/8 inches, leaving 1/4 inch in between. Then put one mark on each long side 1 and 3/8 inches from the top. Then put three marks on the bottom end that correspond to the marks on the top edge as follows, from the left: 1 3/8 inches, 1 1/2 inches, 1 5/8 inches.
I then used a straight edge to make a line from the marks on the side to the marks on the top. (see photo 4) Next take a pair of snips and cut off the two top corners along the lines.
24
comments
Add Comment
Kiteman
says:
NachoMahma
says:
Gjdj3
says:
kelseymh
says:
Add Comment
