3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Aluminum Cracker Chucker
This is an Instructable detailing how to make an Aluminum (Aluminium) Cracker Chucker.
Thanks to Kiteman for his original instructable! It can be viewed here:
Q:What is a Cracker Chucker?
A:Well, it's only the best way to turn small 'Ritz' style crackers into skeet!
Here in northeast Ohio, we have the luxury of being able to spend countless hours trap shooting and preparing for the next time a small disk flies over head, so we can shoot it down quickly and safely. (Watch your back E.T.) Skeet shooting and Trap shooting are two separate sports employing the same technology. Namely: shotguns, clay pigeons, and a throwing device.
"Trap shooting has been a sport since at least 1793 when it used real birds, usually the Passenger Pigeon, which was extremely abundant at the time. Fake birds were introduced around the time of the American Civil War as the Passenger Pigeon was nearing extinction and sufficient numbers were not reliably available. Clay targets were introduced in the 1880's." source:
Presently, most commercially produced clay pigeons are made of asphalt pitch. Asphalt pitch is a derivative of asphalt tar, and it is not readily biodegradable. It is also harmful to many animals, though most commonly wild and domestic pigs.
So, searching one day for a more 'green' way to train in the shooting sports, I stumbled upon Kiteman's Cracker Chucker. After building one and successively going through a full box of crackers with it, and a full box of shells, it was mostly duct tape and sticks holding it together. Collaboratively, my brother-in-law and I decided that one made of metal would subsequently last quite a bit longer. We also thought aluminum would be the best choice for weight to strength ratio. Without any further ado, here is the process I used to build The Aluminum Cracker Chucker.
Cost: Very little. (mine was free)
Difficulty: Very easy.
You will need:
1 piece of scrap aluminum 3 inches by 2 feet
Tape measure
Marker
Tin Snips
Drill
String or rope to use as a lanyard (I used 550 cord)
Rubber or Friction tape
Shrink Tube (optional)
Something to make a 1/8 inch to 1/4 inch bend (I used our shop's brake, but you can use a pair of sheet metal tongs or vise grips, it just takes considerably longer.)
As with all throwing devices and shooting sports, safety is the number one priority. I take no responsibility for anyone injured or killed in the use or construction of this tool.
Step 1The Mark
The Mark
As in everything, put the first thing first. Select your metal.
I chose a scrap of aluminum from our drops bin that was 3 inches by 2 feet.
Next, on the end of the strip that you want to become the top, you will place five marks. I placed one mark in the center, 1 1/2 inches in. Then put two more marks on the top end. From the left, they are at 1 and 3/8 inches and 1 and 5/8 inches, leaving 1/4 inch in between. Then put one mark on each long side 1 and 3/8 inches from the top. Then put three marks on the bottom end that correspond to the marks on the top edge as follows, from the left: 1 3/8 inches, 1 1/2 inches, 1 5/8 inches.
I then used a straight edge to make a line from the marks on the side to the marks on the top. (see photo 4) Next take a pair of snips and cut off the two top corners along the lines.
24 comments
Jan 23, 2011. 4:51 PMdesmondtheredx says:
aluminum rusts easily and it's soft. so you should actually use stainless steel or steel (if you have the proper equipment)
Jan 27, 2011. 2:22 PMklincecum says:
Aluminum doesn't rust at all.
Jan 10, 2011. 4:04 PMFrozenFlameInstructables says:
duuude, i thought this was a knife!
Mar 27, 2010. 10:57 AMjmatthew408 says:
this looks fun but, can you see the crackers better in real life than in the video, cuz eventhough im from the patron state of shooting stuff (TN) i cant shoot objects which i am unable to see :-)
Jul 11, 2009. 7:03 PMyopauly says:
LOL, this is cool! shoot all day for not much. A box of crackers don't weigh much. To be honest, the title made me think it was something racist! LMAO! You're saving the environment and hit or miss, the birds love you for it! KUDOS to you!
Jul 7, 2009. 10:28 AMclarkshooter says:
what do you shoot them with
Jun 18, 2009. 12:27 AMaddytheknowhowman says:
where did you get your metal from?
Apr 21, 2009. 3:50 PMKiteman says:
How did I miss this when you posted it?? Thanks for the shout - these look deadly. The wrist strap is an excellent modification.
Apr 21, 2009. 4:11 PMNachoMahma says:
. Good job. . Where's the video? I'd like to see it in action.
Apr 21, 2009. 5:53 PMGjdj3 says:
Sweet! And I agree with Nacho. We want a video!
Apr 22, 2009. 2:45 PMkelseymh says:
This is a terrific example of building upon another's work, while making in your own. Credit where credit is due, and a well written, well executed project! Rated and featured.
Apr 23, 2009. 12:13 PMfwjs28 says:
agreed...to me, it looks like a knife at first, then i read the description
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:hailtothkngbby
