3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Aluminum Cracker Chucker
Step 2'Brake' Down
  • last photo ←
In this step, use whatever means you have to bend a 90 degree angle from the top 1 3/8 mark to the bottom 1 3/8 mark, and do the same from the top 1 5/8 to the bottom 1 5/8 mark.
Anyone who has used an old brake like this will tell you it's difficult to get a tight bend in a 'c' channel like this. The opening will tend to be on the wider side, mine was about an inch open, but the brake gave it some tight straight lines, so I was able to tap it a few times with a mallet to straighten it out.
If you're using tongs or vise grips to do the bending, run a straight line down from the top marks to the bottom, and bend along the lines. Precision is not required, as the whole thing can be a bit sloppy and still perform quite well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:hailtothkngbby
