3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Aluminum Pipe Bed
Aluminum Pipe Bed
This project serves as a guide for those who wish to build their own bed frame from pipe and modular fittings. The beginning sections are informational, regarding different approaches, preparation, and the resources required. The following sections are a reference for the do-it-yourselfer (DIY), and provides step-by-step directions.
My main motivation for doing this project was to build a modern queen-size canopy bed frame that was made from aluminum pipe and galvanized metal fittings and would accomodate a standard matress and box springs. Many years ago, I had seen a similar bed frame in magazine ads by a well-known fashion designer. Unfortunately, their version cost nearly $6,000!
We have been using this bed for about 7 years now. The pipe is comfortable to hold onto and very sturdy. :) We also think it's pretty stylish.
Step 1Foreward and Preparation
While this project is pretty easy to assemble, the components are industrial in nature. Make sure your bedroom has enough ceiling clearance for the assembled canopy frame. You will also need a truck or large van to transport the longer lengths of pipe.
The only tool you really need is a standard 5/16" (7.94mm) A.F. hex key. This assumes that you let your pipe supplier cut the pipe to length for you and that you outsource the small amount of welding. Most people don't have welding kits that work with aluminum.
Note: This project isn't what most people would call cheap. Parts alone will cost around $800. Still a far cry from the nearly $6,000 designer version.
71 comments
1-40 of 71next »
Jul 31, 2011. 10:34 AMoogiemama says:
This looks great, we recently had to get rid of all of our beds (matress and box springs due to black mold) We have been hunting for just the right diy to build a new frame when we get replacement matresses and I believe this one will be it. We are going to try and build though with out welding needs. And suggestions would be greatly appriciated!
Jan 11, 2008. 8:20 AMJStrider says:
very cool bed! I'd love to make it, and I like the idea of putting extra bars across the top for more places to grab on to. The only downer is the price... thats definitely more then I'd want to spend... Time to head to craigslist and see if I can find some used scaffolding pipe for cheaper.
Jun 1, 2011. 1:52 PMgossumx says:
Haha, that's exactly what I tried to do. Can't seem to find anything in the searches I've done.
Sep 1, 2010. 10:55 AMElvenChild says:
calvin this is santa no presents unless you cream susie with a snowman
Sep 1, 2010. 12:07 PMElvenChild says:
Isn't hobbes going to give you some lecture ask for a sandwich and walk away
Jul 22, 2010. 9:18 PMMurphys Laws says:
XL twin bunk & loft beds are expensive. This would be great & sturdy. Plus you can make it with as much head room as you need on the bottom bunk.
Jul 20, 2010. 2:02 AMtask41line says:
Lol I tried putting up something exactelly like this 2 months ago and it didn't went well but I think this time it will be much easier.
Jul 20, 2010. 3:16 AMjamesvertigo2 says:
yea this guide looks great I agree
Jul 19, 2010. 12:37 PMComputothought says:
Awesome idea for a bed.
Jul 7, 2010. 1:35 PMmutantpoptart says:
First off, this is awesome! Defineatly thinking outside the box! I love this and plan on making one this fall, as I am in need of a new and larger bed!
May 31, 2010. 5:25 PMstpierre2 says:
I love this project, and will be attempting something similar. Anybody have any idea where I can get Kee Klamps in Canada????
Apr 28, 2010. 3:42 PMstartree says:
Love it. Thanks for sharing! was just thinking how well this would work as a loft bed when i saw the other links...
Mar 4, 2010. 2:16 PMFretka says:
 I am not real handy when it comes to things like this, but wouldn't it make sense to make 2 cross bars, or even 3 from long side to long side to support the box spring? then you wouldn't have to weld at the foot and head bars at all. instead of using such long lengths of pipes, use 2 more T's and add the supports?
I love this bed, and would love to try it myself, but I guess I would appreciate some feedback if my idea would be feasible or not. GREAT IBLE !
Feb 17, 2010. 7:21 PMmjk1138 says:
 Huh?
Apr 16, 2009. 9:27 AMTattooedPirate1969 says:
My husband and I are currently building this bed. We modified it so it requires no welding, and bought the pipe locally, and the Fittings via EBAY. We spent a total of $350 for building this bed. Yay!
Feb 17, 2010. 7:12 PMmjk1138 says:
 I, too, would like to see this, and am curious how you did it without welding! Thanks!
Sep 19, 2009. 7:42 AMRaptorOwl1 says:
I think that I will modify this for a loft bed. Welding corner braces for a box spring will not be necessary if there are enough cross pipes. Additionally, a piece of plywood laid across the crosspipes with a memory foam mattress will do nicely. Consider using pipe insulation on the pipe where it is most likely to make contact with tender parts. There is a heavy rubberized type I found at Home Depot.
May 31, 2009. 9:31 PMporcupinemamma says:
It never fails to amaze me how many talented people there are in this community, and you certainly belong to that gang. Well done!!
May 12, 2009. 12:00 PMkeverill99 says:
Hoping to make this bed within the next 3 weeks :) Not doing the canopy, it interferes with the ceiling fan, which I can't do without in Phoenix. Thinking of doing 2 supports on the bottom, then a piece of plywood to support the mattress? I'm only doing a mattress, no box spring, so I will space the side supports closer together.
May 12, 2009. 1:20 PMkeverill99 says:
That makes sense...Thanks!
Mar 28, 2009. 6:11 PMjobradfield says:
oooh! this is so cool! It could easily be steam-punked-up. I'm also looking for cheaper alternatives. Other than steel, is there anything cheaper?
Mar 13, 2009. 12:01 PMnotahandyman says:
Hello Thank you so much for your trouble I have sourced the fittings and pipe, I am intending to build a Queen, no canopy version without welding, but with a headboard. Is there any tips you think I would need to know Thanks again for the help And congrats on such a great design
Jul 26, 2006. 2:38 PMtrebuchet03 says:
looks good :D Did you happen to forget that T in the bottom pipes? Just wondering because you mentioned it a few times :P
Feb 15, 2008. 9:16 AMedless74 says:
Found a cheaper brand to make the bed outta Interclamp about 30% cheaper than Keeklamps that Simplified sell. www.interclamp.com
Nov 30, 2008. 7:25 PMfoobaz utne says:
Unfortunately they are in England and there are no US retailers, at least, that carry that line. Not online anyway. 30% is not that great a discount in any case. Kee Klamp is expensive but it's the shipping that really kills you. If you can find it locally and go get it you will save a bundle. Grainger seems like the most available local source but you need to be affiliated with a business, even if it is your spouse's employer. If the company is a large corporation, they usually offer you a significant discount. Easyfit (http://tinyurl.com/6gxwtk) is about 40% cheaper but there was no info on shipping. I suspect it is similarly high. Harbor Freight (http://tinyurl.com/6hs3xh) has a very limited selection of fittings that would be adequate for this project but the sizes are really strange. The price is dirt cheap but they look rough. Does anyone know a cheap source of these connectors from a company that is either local or has good shipping prices?
Sep 9, 2008. 5:26 PMamatuerconstructicon says:
just wondering how much it cost to build this bed for you aside from the box spring and mattress, just the frame. Wondering what im to expect trying this myself, as i am in love with this design.
Aug 10, 2008. 11:43 PMmfbuchanan says:
Wonderful! I'm thinking of adding a couple more bars across the headboard to make it a bit more "designish"; then covering pieces of foam or wood that are cut to fit the spaces betweeen the pipes with vinyl or leather and fitting them into the spaces. Would create a solid headboard. I also was thinking of adding a seating area or place to throw your clothes at the base of the bed extending past the foodboard. Using T's instead of L's at the base would allow this. Then just add two more legs. It can be left open for draping stuf on or you can add a top made of wood, glass, etc....
May 2, 2008. 9:55 AMCisneros.Evan says:
it goes really well with the wooden rafters in your room. i like it a lot.
Mar 15, 2008. 9:30 PMdrewdoog says:
excellent idea! I love the industrial look to it. This would be a great bedroom group. matching lamps, night table, tv stand, speaker stands, computer desk... its endless. ill be making something similar in upcoming days.
Jul 27, 2006. 2:53 PMalistair says:
I use Kee Klamps, both the galv iron and aluminium types for a variety of structures. They do work well but the untreated aluminium pipe leave black smudges. It doesn't look liek to anodised the pipe (quite expensive), did you try a coat of polyurethane?
Jul 27, 2006. 6:46 PMmrbob1000 says:
aluminum doesnt oxidize :I
1-40 of 71next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:DenVogel(Dennis Vogel)
