3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Amazing Ant Farm
Step 9Secure the top
Secure the top
Since the two sides and the bottom will be secured to the windows, they will be sealed against escaping ants. However the top is removable so to ensure no ants escape, it needs to have a method for being secured. In each of the side pieces, one or two pieces of threaded rod is embedded and a nut is tightened from the top to provide pressure to seal.
Start by clamping the top board in place and drilling pilot holes through the top board into the side boards, taking care to avoid the grooves for the windows. Next insert threaded rods into the pilot holes in the side pieces. Enlarge the holes in the top piece so the top piece can easily slide onto the threaded rods. Next put a washer on top of each threaded rod and then a nut. Wing nuts are nice for this because they can be more easily tightened by hand but regular nuts will work too.
The first picture shows the first two rods in for testing. The second picture shows the four threaded rods and the last picture is securing the top for the final test.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:catwood
I believe that a person can do just about anything within reason as long as they try hard enough.
