Amazon Echo Controlled IR Remote
5,625
44
Posted
Introduction: Amazon Echo Controlled IR Remote
The Amazon Echo system can control a lot of aspects of a smart home, but a smart outlet can only turn off and on. Many devices do not instantly turn on by simple being plugged in and require additional steps, such as pressing buttons on a remote or the physical device to power on or get the desired settings.
In this guide, a Raspberry Pi Zero W will be configured to act as a smart home device that can be controlled by Amazon Echo, and send any desired IR commands to a device when requested to power on or off.
In this specific case, the Pi will be configured to learn the IR commands of a remote provided with a "ClassicFlame 23II310GRA 23" Infrared Quartz Fireplace Insert". An IR LED will then be used to send out the IR commands on demand, and finally the Pi configured to emulate a Philips Hue device that can be control be Echo.
Step 1: Materials
Required:
  • Raspberry Pi Zero Z
  • 4 GB or greater Micro SDHC Class 10 memory card (16 GB Example)
  • MicroUSB
  • 1 IR LED
  • MicroUSB Power Adapter (2.1 amps or higher recommended)
  • IR LED
  • IR Receiver VS/1838B
  • 100 ohm resistor
  • Misc. wire
Recommended:
To complete the initial configuration of a Raspberry Pi Zero W, a few additional peripherals will be required, but will not be in use full time by the completed project
  • Mini HDMI to HDMI Adapter: Used to connect Pi Zero W to a TV or monitor with a full sized HDMI cable
  • USB OTG Cable: Used to convert from micro-USB to full sized USB port(s) for connecting a keyboard and/or mouse
  • HDMI Cable: Used to connect to TV or monitor along with an adapter to mini HDMI
The first two items as well as a case are included various Pi Zero starter kits, such as: MakerSpot Mega Kit
Step 2: Setup Raspberry Pi
The Raspberry Pi website has an excellent walkthrough for setting up Raspbian OS on a Raspberry Pi. If you wish to have more Operating System options in the future, or a more simple setup, following the instructions for NOOBS will get you up and running in no time. This guide is based on Raspbian, which is included with NOOBS
https://www.raspberrypi.org/learning/software-guid...
Once Raspbian is running, enable SSH to allow remote connections to the device without needing a monitor/keyboard/mouse to be connected directly to the Pi. If you would like to optionally have remote access to the GUI, you can also enable VNC access
https://www.raspberrypi.org/documentation/remote-a...
It is also highly recommended you set a static IP on the wireless network configuration so it does not change over time. It is possible the IP may not change if new devices are not regularly connected to the wireless network, but configuring it as static will ensure it does not.
http://www.circuitbasics.com/how-to-set-up-a-stati...
Step 3: Learning IR Codes
The following steps are highly based on the excellent guide found here:
http://alexba.in/blog/2013/01/06/setting-up-lirc-o...
The Linux Infrared Remote Control (LIRC) library is used to handle receiving IR commands through the receiver module, saving them to a file, and then sending the commands when desired through the IR LED.
The first step is to record the IR signals from our existing remote using the IR Receiver and saving them to a file. The IR Receiver is only needed initially to learn the IR signals and then could be removed, so a temporary connection could be used.
    Connect the IR Receiver to the Raspberry Pi. Use the attached picture to identify the VCC, GND, and Signal pins. Using a breadboard, hookup wires, or creative bending of the pins to the following connections
    VCC connects to 5 volt pin
    GND to a ground pin
    Signal to Pin 23
    Power on and connect to the Raspberry Pi through either by opening the terminal on the local device, or creating an SSH connection using a program such as Putty for Windows. The remaining steps will be typed into the command line interface
    Install LIRC
    sudo apt-get install lirc
    Add required information to the modules file
    sudo nano /etc/modules
    Add the following lines to the end of the file
    lirc_dev
    lirc_rpi gpio_in_pin=23 gpio_out_pin=22
    When finished, press CTRL+X, then Y, then Enter to exit and Save
    Create/Modify the hardware.conf file with the following data
    sudo nano /etc/lirc/hardware.conf
    Copy and paste, or modify to contain the following lines:
    # /etc/lirc/hardware.conf
    # # Arguments which will be used when launching lircd
    LIRCD_ARGS="--uinput"
    #Don't start lircmd even if there seems to be a good config file
    #START_LIRCMD=false
    #Don't start irexec, even if a good config file seems to exist.
    #START_IREXEC=false
    #Try to load appropriate kernel modules
    LOAD_MODULES=true
    # Run "lircd --driver=help" for a list of supported drivers.
    #DRIVER="UNCONFIGURED"
    DRIVER="default"
    # usually /dev/lirc0 is the correct setting for systems using udev
    DEVICE="/dev/lirc0"
    MODULES="lirc_rpi"
    # Default configuration files for your hardware if any
    LIRCD_CONF=""
    LIRCMD_CONF=""
    Modify config.txt so the LIRC kernel module is loaded on boot. Add to the end of the file.
    sudo nano /boot/config.txt
    dtoverlay=lirc-rpi,gpio_in_pin=23,gpio_out_pin=22
    Reboot RaspberryPi
    sudo shutdown -r now
    Test IR Receiver by stopping LIRC and monitoring the input. First LIRC will be stopped
    Raspbian 8 Jessi: sudo /etc/init.d/lirc stop
    Raspbian 9 Stretch: sudo systemctl stop lircd
    Optional:Mount the LIRC device to confirm any input can be received. You may need to restart the Pi after this test is completed to make it available for later steps.
    mode2 -d /dev/lirc0
    Aim an IR remote control at the receiver and press a button and ensure data appears on the screen
    CTRL+C to stop
    At this point, the LIRC program is installed and we are able to view IR information. Now, either a remote profile can be downloaded from the LIRC website, or a custom profile can be created with your own remote.
    During this process, you will enter the name of the key you are recording. Only valid names are allowed, so run the following command to view all available names
    irrecord --list-namespace
    Example: I used the name KEY_POWER when I recorded the Power button on my remote and KEY_TIME when recording the timer button.
    If more than a few keys are being recorded, I recommend documenting the key names used and what button they map to, as there may not be a perfect name for the button being recorded. This will make it easier to reference in the future.
    Generate a Remote Configuration file
    # Stop lirc to free up /dev/lirc0
    # Create a new remote control configuration file (using /dev/lirc0) and save the output to ~/lircd.conf
    irrecord -d /dev/lirc0 ~/lircd.conf
    Follow the directions on the screen. Once the record is initialize, enter the key name you are going to used, and then press the button on the remote while pointing it at the receiver until several dots appear. Repeat this step for each button on the remote you wish to record.
    # Make a backup of the original lircd.conf file
    sudo mv /etc/lirc/lircd.conf /etc/lirc/lircd_original.conf
    # Copy over your new configuration file (Replace myremote with the name you gave during the configuration)
    sudo cp ~/myremote.lircd.conf /etc/lirc/lircd.conf
    # Start up lirc again
    Raspbian 8 Jessi: sudo /etc/init.d/lirc start
    Raspbian 9 Stretch: sudo systemctl start lircd
    At this point, remote codes have been recorded to a file.
      Step 4: Headphone Jack (Optional)
      To make running wires and modifying the Raspberry Pi more modular, I hot glued a 1/8 inch headphone audio jack to the case and connected wires to the jack. Headphone wires with the matching plug were used to connect the IR LED, so this wire could be routed to an inconspicuous locate to point at the IR receiver of the device I wanted to connect, but could easily be unplugged from the Pi without needing to remove all of the wires.
      This is purely optional, but has come in handy.
      Step 5: Connecting IR LED (Quick)
      Connecting the IR Emitting LED to the Raspberry Pi can be done multiple ways. This step shows the quick way I connected it, but which I found out later can exceed the current limit on the Pi's pins. So far I have not run into any problems, but a more ideal way of connecting is described in the next step
      Calculate the resistor needed for your IR LED. http://ledcalculator.net/ can assist with determining the proper resistor value if you have all specifications of your LED. In this case, the voltage of pin 22 is 3.3 volts, the LED voltage drop is 1.2 volts, current rating is 20 ma, and 1 LED was used, resulting in a value of 110 ohm resistor needed. I used a single 100 ohm resistor.
      Note: It was later brought to my attention that the max current of all pins at any given time is 16 ma, so this configuration could exceed that. A better configuration with a transistor and 5 volt supply is described in the next step, but after several weeks of running in this configuration, I have not encountered any problems yet.
      Pin 22 on the Raspberry Pi will be connected to the anode of the IR LED, which is the longer leg by default.
      The shorter pin of the LED connects to the resistor and then to the ground pin. I cut off most of the wire on the resistor and soldered it directly to a ground pin and to the ground wire going to the LED.
      Step 6: Connecting IR LED (correct Method)
      To properly connect the LED without exceeding the draw limit of the Raspberry Pi, connect the LEDs to the 5 volt supply with appropriate resistor, connect the cathode pin to the collector pin of a 2N2222 resistor, connect the Emitter pin of the transistor to ground, and connect pin 22 of the Pi to a 1K ohm resistor to the base pin of the transistor. This allow a very small current from pin 22 to connect the LED to ground, completing the circuit without over drawing the Pi.
      In my example, I wired up 2 IR LEDs, so I could control ambient lighting as well as the electric fireplace.
      Step 7: Testing Sending IR Commands
      To send an IR command, the program irsend is used.
      Syntax: irsend
      Example: irsend SEND_ONCE Spectrafire KEY_POWER
      This sends the power button command from the Spectrafire remote once. Replace Spectrafire with whatever you named your remote. Repeat with other key names used when recording the file.
      At this stage, you are able to send any commands previously recorded using the IR LED connected to the Raspberry Pi.
      Step 8: Installing Ha-bridge
      To allow the Echo to be able to control our device, we will emulate a Philips Hue bulb using ha-bridge. Once configured, the Echo will be able to detect this device and send power on/off commands to it.
      The website for ha-bridge clearly outlines the process for the current version and is highly recommended to review.
      https://github.com/bwssytems/ha-bridge
      Install HA-Bridge
      sudo apt-get install oracle-java8-jdk
      mkdir /home/pi/habridge
      cd /home/pi/habridge/
      wget https://github.com/bwssytems/ha-bridge/releases/download/v4.5.6/ha-bridge-4.5.6.jar
      Rename file and run HA-Bridge
      mv ha-bridge-4.5.6.jar ha-bridge.jar
      sudo java -jar /home/pi/habridge/ha-bridge.jar
      To setup ha-bridge to run on startup using Systemctl
      cd /etc/systemd/system
      sudo nano habridge.service
      Copy and paste the following lines
      [Unit]
      Description=HA Bridge
      Wants=network.target
      After=network.target
      [Service]
      Type=simple
      WorkingDirectory=/home/pi/habridge
      ExecStart=/usr/bin/java -jar -Dconfig.file=/home/pi/habridge/data/habridge.config /home/pi/habridge/ha-bridge.jar
      [Install]
      WantedBy=multi-user.target
      Save and Exit (CTRL+X then Y and Enter)
      Reload system control
      sudo systemctl daemon-reload
      Start the service
      sudo systemctl start habridge.service
      Configure service to start on boot
      sudo systemctl enable habridge.service
      Step 9: Emulating a Philips Hue Bulb
      With ha-bridge running, open a web browser and enter the IP address of the Raspberry Pi, and the interface for ha-bridge should appear.
      Click the Add/Edit link at the top of the page
      Name: Enter the name you want to use when speaking commands
      At the section labeled "On Items" set the type "Execute Command/Script/Program and enter the command in the Target Item box. If multiple commands are desired, click the Add button to save the current line and enter another command. It is also possible to set a delay and repeat a command a certain number of times. In this case, the power button needed pressed first, then the Timer button pressed 3 times to set the auto-off timer for 3 hours.
      Repeat the same idea for the "Off Items" area, clicking Add when finished.
      At the top of the page, click "Add Bridge Device" to save it as a new item, or Update Bridge Device if modifying an existing one.
      Aim the IR LED at the device. On the Bridge Devices page, click the Test ON or Test OFF button to verify it is acting as desired.
      Step 10: Connecting to Amazon Echo
      The last step is to allow the Amazon Echo to communicate with this device. Note: Both devices must be the same network.
      Option 1) say "Alexa, discover smart home devices"
      Option 2) Open the Alexa app, tap on Menu>Smart Home and click the "Discover Devices" link
      After a few moment, the device should be recognized.
      Speak, "Alexa, turn the bedroom fireplace on" and verify that the device turns on as expected. Replace Bedroom Fireplace with whatever you name your device in ha-bridge. Repeat the process to turn off the device.
      If you haven't mounted the IR LED yet, find an inconspicuous place to mount it while allowing it to point in the general direction of the IR receiver in the device. You may need to move it around to point at different areas to find the best location.
      • Epilog Challenge 9
        Epilog Challenge 9
      • Sew Warm Contest 2018
      • Gluten Free Challenge
      This project is exactly what I'm looking for. I want to control an ir remote for my fan and have Alexa turn my Xbox "on" as part of my morning routine. Forgive my noobiness, but would you please either post or email a complete schematic of the project (including the transistor powered ir transmitters)? I appreciate the pictures in the project but I'm not clear on what I'm looking at, and I don't understand what the transister is "doing" in the circuit. Thanks so much for posting this project - I have the parts - just hoping for a little more assurance! Thanks again!
