This instructable has been removed by the author.
18
comments
Add Comment
On second thought, however, if one puts holes only along the bottom of the tubing, it should still be strong enough and would also direct any theoretical air-flow downward, between the hanging items and themselves, where air-flow would most speed dehydration. Whether real airflow will actually help noticeably, I have no idea. It would probably be a lot easier and more efficient just to put a couple solar-powered fans on one end to blow air through the clothes.
I guess you could have put some valves or gauges to cap off the endpipes.
Something on the ends might be nice. I actually have some of these pipe benders - I take it you are talking about the assembly anchors here, but I kinda like the way they are flattened in their coil.
Thanks, Bongo.
I had to read it as soon as I noticed the indepth explanation.
I built a very similar device as a child, But out of sheer desparation.
I think the steam punk edge gives it a nice new look.
Your comment makes me think, and reveals the complexity of trying to be ethically/environmentally minded.
As a question of degrees, the energy required for a single use of the tumbling machine would keep that little battery drill going for a long time... And as a one off use, in the production of the AEAPD it didn't seem so terrible a thing.
Of course, as an alternative I could have taken the time to sand all the pipes by hand (and I did do a lot of them that way anyway), but with the smaller diameter pipes I couldn't resist, as they fit straight into the drill's chuck. Don't get me wrong, a bit of hand sanding is nourishment to my soul. But after a while I got excited by the idea of fast spinning and an end to the monotony.
The lacquer paint, was left overs from a van bodywork repair - the option was to use it (and thus also make the scrap copper pipes usable for this application) or leave it go to waste.
