iImage Information
I found a few great instructables on here, and used a little info from each to create my own ambient shelf lighting. I'm not usually one to get too involved, but since I have taken so much from the site, I felt it was my duty to post my little project. :)
Step 1Step 1
iImage Information
Okay, I guess here is where I list the parts. Basically all you need are the LEDs, resistors, sewing pins, batteries and some speaker wire. For fancy's sake, I used a project box, switch and battery holder too. To put it all together, you will need wire cutters/strippers (scissors will work in a pinch) and a soldering iron (I suppose you could even just twist them together if you had no tools)
Pic1: I had this little project box that was dug up to practice some wood burning. Decided to use if for this instead.
Pic 2: As you can see in the next picture, i installed a rocker switch on the side, and drilled a hole for the speaker wire to run through,
Pic 3: I plopped the battery holder inside, and ran the wires to the switch, and out the back. (For some reason these cheapo batteries think that 1.5v x 4 = 6.4?? )
Also, where's the best place to get LEDs in California?
http://ledcalc.com/#series
