Ambient Light Powered LED Flasher
757
9
Posted in TechnologyElectronics
Introduction: Ambient Light Powered LED Flasher
About: Music: my profession for over 40 years... Electronics: my beloved hobby always.
This LED flasher circuit is optimized to run from the ambient light present in your room and no other power source. A small photovoltaic cell converts the light to electricity and that weak current charges a 1000uF capacitor. After a time period of around 1.5 seconds, the stored energy is discharged through an LED.
Step 1: Overview
Step 2: Circuit Diagram & Main Components
FV cell: should deliver at least 2.5v (no load open circuit) and 0.5mA short circuit current (under room lighting)
Incandescent / halogen lighting is the most efficient for F.V.cells (after daylight) and fluorescent is the least.
Q1-Q2: BC549 npn transistors
Q3: 2N7000 N-channel mosfet. You may have to select it for lowest gate threshold voltage or use a low threshold BSH103
LED: use a high efficiencyred LED . (red LEDs have the lowest forward voltage (Vf) )
Step 3: Photovoltaic Cell
Step 4: LED
Step 5: Capacitor
Step 6: Astable Multivibrator
Step 7: FET
Step 8: Watch the Video - Thank You !
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    At first I was kinda disapppointed that it required an additional solar panel to work, I expected that the LED would be use as a mini solar cell. That duty cycle couldn't be aquired though.
    However I was curious about the actual power consumtion and efficiency, so I quickly scatched it in LTSpice. Since there was no solar cell available I "made" my own with a 2k impedence, I think that is a realistic value. Ive atache a the simulation below.
    green: system voltage
    blue: LED current consumption
    red: total system current consumption
    Hats off for archiving a standby cnsumption of 24uA, this is amazing considering you only used discrete components. I've played a bit with the values and figured out that (at least in the simulation) R1, R2, R3 can be set to 10M and R4 to 1.5M to decrease the standby current consumtion to only 2uA!
    Still a great design, love it!
    If anybody wants the LTSpice files to play around with just drop a PM.
    Nice to see you again ! . FET input has a relatively high capacitance, so increasing R4 to 1.5M will slow down rise time of gate voltage considerably, discharging C4 prematurely. Your simulation is awesome. Thank you!!!
