Introduction: Ambient Power Receiver(easy, Cheap, Green)
ENERGY , FREE ENERGY TO BE MORE SPECIFIC, IS AN INMPORTANT TOPIC NOWADAYS ,THE WAY TO OBTEIN FREE STUFF IS A THING THAT HUMANS TRY TO SEARCH AND INVESTIGATE
IN THIS INSTRUCTABLE I AM GOING TO SHOW YOU HOW TO GET A COUPLE OF VOLTS FROM A SMALL CIRCUIT THAT I FOUND.
Step 1: MATERIALS:
C2,C3 .047 μF, 50 volt
capacitor C1,C4 40 μF, 50 volt electrolytic capacitor
D1,D2 1N34 diodes
D3,D4 1N34 diodes
ANT 1M foot broadband monopole antenna
Misc PC board, wire, hardware, enclosure
ALL OF MATERIALS CAN BE FOUND ON YOUR LOCAL RADIOSHACK STORE
Step 2: OK LETS BUILD IT !
TO BUILD THIS DEVICE JUST FOLLOW THESE STEPS:
1) ASSEMBLE THE CIRCUIT, REMEMBER THAT THE NEGATIVE LEADE OF THE ELECTROLITIC CAPACITOR MUST GO ON THE NEGATIVE TERMINAL.
2) THE ANTENNA : TAKE SOME WIRE AND MAKE ONE OF AT LEAST 1 METER LENGTH , TRY TO PLAY WHIT THE FORMS OF THE ANTENNA .
3)FINALLY TAKE A CABLE AND CONECT IT TO YOU HOME ELECTRICAL CIRCUIT GROUND
4) ENJOY
Step 3: NOW YOU ARE RADY TO USE THE APM, BUT....
remember:
* this apm is good for small loads, small circuits, and charging a cell phone
* the anntena will only recive radio frequencis below 1Mhz
* THIS DEVICE IS NOT A 100% EFFICIENT.
AND FINALLY: BE CREATIVE TO BE ONE DAY AS MAX DILLON , TONY STARK OR ANTMAN.
LIKES , VOTES , COMMENTS PLZ
6 Comments
This project looks awesome, but there isn't really enough documentation of you actually making it for a complete Step-by-Step Instructable. There are two things which you could do.
1) If you happen to have images of you making your project you can create some more steps with more complete instructions and then republish your Instructable.
2) If you don't have any more pictures of you working on your project, that's okay too. That just means that your project is better suited to be submitted as a Photo Instructable. Your images are already in your photo library, and you can copy and paste the same text that you have already written for your Step-by-Step Instructable, so it should only take a few minutes to create a new Photo Instructable and show the world what you made!
Also, it's great that you have decided to share your photos with us, but we need an explanation of what you made and how you made it before it can be published. Please write up a description of your project and reply to this comment to let me know that you are done.
Thanks for your submission and let me know if you have any questions along the way.
This circuit is nothing more than a basic charge pump powered by weak incoming rf energy. Yes, it does work. It also takes ages to charge up even a small electrolytic capacitor. A single low efficiency solar cell operating for only a few hours in sunlight will harvest magnitudes more energy than this circuit can in a full day or longer. It is designed to capture mains leakage. And it is highly likely to capture the mains running through the house you set it in.
For any project that claims to harvest or generate electrical energy we really need to know the voltage and current, could you measure and post please?
jajaja that electro
could you add some real pictures of the project?
cooL and easy to make!!!
